Old 11-16-2012, 08:00 PM
pranavf01's Avatar
pranavf01 pranavf01 is offline
Mein Auto: Bmw F01 750i
SPACERS!!! effects?
Hey guys i like the look of stock 7 but i want my front wheels to pop out a little bit, i was thinking about getting spacers but i have no knowledge of them so i thought you guys can help me out.
i have a stock 7 with no aftermarket wheels or suspension, my question is HOW MANY millimeters is best? and WHAT ARE THE BAD EFFECTS, IF ANY?
thank you
i found this one with 10mm in the front and 20mm in the back H&R on a 3 series
Old 11-17-2012, 12:54 AM
ChrisF01's Avatar
ChrisF01 ChrisF01 is offline
Gib mir Feurschutz!
Mein Auto: 2016 750i xDrive
Well if anything at least your front drivers and pass doors will get dirtier faster from it throwing dirt and any moisture up behind it...
2016 750i xDrive M-Sport (Current)
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 11-17-2012, 05:00 AM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is offline
Mein Auto: 2016 ///M5
My initial thoughts are that I like the wider stance; it gives it a "beefier" look. Guess I would need to see a 7 in real life to make the final call. Can you get any good advice from your dealer?
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 11-17-2012, 12:49 PM
Wolfman64 Wolfman64 is offline
Mein Auto: 750li, S550, SL550, ML350
I have used spacers on my MB for a wider stance and the (Brabus) wheels required them.
I think that it doesn't look good to get a wider stance without lowering the car though.
When lowered, a wider stance definitely requires you have a wheel alignment with the proper camber adjustment or you'll wear out the inside of the tires even faster than when just lowered (in 5k miles or less).
Also, you must use hub-centric spacers or your car will vibrate and give you a very poor ride.
Good luck!
Old 11-17-2012, 02:08 PM
Individual750LI's Avatar
Individual750LI Individual750LI is offline
BMW rocks!
Mein Auto: 2013 750I M
If you use spacers under 20MM, you are safer and won't feel any difference while driving.
If I was to put spacers on my stock 20's, I would do 10mm all around. Or 5mm front, 10mm rear.
2015 X6M, 2014 X1, 2015 Kia Sedona SX-Limited
Old 11-17-2012, 09:06 PM
pranavf01's Avatar
do you think that the offset would be disturbed if i get 10mm all-around for my 19s?
Old 11-17-2012, 09:08 PM
pranavf01's Avatar
i did not ask the dealer yet, wanted to just get some suggestion before i went that way.
Old 11-17-2012, 11:04 PM
BMW rocks!
10mm is pretty safe, just give the car a better stance but not affecting the suspension much.
Old 11-18-2012, 04:26 AM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
Could someone post pictures of a stock 7 with spacers?
2011 750i
Old 11-18-2012, 09:51 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
I just got new rims for the winter yesterday. I'll fit them before December and probably with spacers. So I'll post 'em when I fit 'em
