E90/E91/E92/E93 (2006 - 2013)
Old 11-16-2012, 08:17 PM
Imrandrew Imrandrew is offline
Mein Auto: 2010 335i e93
N54 or N55?
I own a BMW 335i convertible e93. 2010
How do I know if it's has a N54 or N55 engine?is it pre-lci or lci?
Old 11-16-2012, 08:24 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
http://en.wikipedia.org/wiki/335i
It's all there. Enjoy.
BMW CCA Member
Old 11-17-2012, 04:01 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Or type the last seven digits of your VIN here:
http://www.realoem.com/bmw/select.do
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 11-17-2012, 04:36 AM
bmw325 bmw325 is offline
Mein Auto: 335i
2010 was pre lci. You have the n54
http://nyccarblog.blogspot.com/
Old 11-17-2012, 07:46 AM
bear-avhistory bear-avhistory is offline
335is Coupe JB4-G5 ISO
Mein Auto: 2011 335is 7DCT Coupe
Or just count the turbos.
Kevin
2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO
2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star
2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash
Old 11-17-2012, 10:01 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Too direct and much too dirty.
I say: Fire a very strongly worded letter to BMWNA demanding clear designation of which engine you have.
Old 11-17-2012, 10:51 AM
andrew b's Avatar
andrew b andrew b is offline
flâneur en cabriolet
Mein Auto: 2007 E93 N54
One of them has big lettering on the engine cover that says "TwinPower Turbo".
That's the N55, with one turbo (although it does have twin scrolls).
The plain one is the N54, with twin turbos:
Old 11-17-2012, 11:14 AM
Bemo's Avatar
Bemo Bemo is online now
Mein Auto: 2011 328xi
According to the Bentley manual, several states received SULEV version, post LCI, labeled something like N52N (California, Connecticut....). Can anyone confirm this?
2011 328xi
2011 535xi GT
BMW CCA
Old 11-26-2012, 09:32 AM
Mein Auto: 335i
Sounds right but that would be the silver version of the n52 (used in the 328i)
Old 12-07-2012, 09:41 AM
farrout farrout is offline
Mein Auto: 2009 335i coupe
Take key to BMW Dealer. They can run a vehicle history report for you. When I was looking for a 335 to buy, I took numerous VIN numbers to the local dealer and they gave me details about the car itself.
Old 12-07-2012, 10:21 AM
Better late than never, sure, I'll confirm it.
Has a special pollution fighting radiator coating.....believe it....almighty expensive too.
Old 12-07-2012, 10:40 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: lci 335 e92
Old 12-07-2012, 09:15 PM
Originally Posted by chris328 View Post
What, me?
Dude! Better do a check - does indeed have the coating.
Old 12-07-2012, 09:51 PM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Miata NC2
The info from this amazed me. Was totally spot on http://bmwvin.com
Is there more lag on the single turbos? I Googled twin-scroll and it seems to be all about efficiency; still has one turbine so presumably it'll take longer to spool up
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 12-08-2012, 07:09 AM
This has been debated to death, not sure there is a solid answer on lag. Pretty much any lag can be tuned out of the N54. The one thing that is a fact based on development dyno tests by Burger Motorsports is the N54 is much more adaptable to power modification then the N55. With identical tunes the N55 will always lag behind the N54 on the dyno & at the track. Why this is I don't have any idea but it might be more then just the turbo because the top horsepower N54's, 650+whp, are all after market single turbos cars.
Kevin
Old 12-08-2012, 10:11 AM
MP3_E46's Avatar
Code/wrench Monkey
One day I have to buy a used 335 and boost to over 400hp just for kicks.. maybe in a year or two I'll find one with a clogged intake that someone is letting go for next to nothing. Many are starting to hit 100K now
Old 12-08-2012, 10:38 AM
SD Z4MR's Avatar
SD Z4MR SD Z4MR is offline
(formerly SD 335is)
Did you check the horsepower spec? My M was off by 84 HP and my wife's 335is was off by 60 HP. They must be using some metric spec.
- Tom
Old 12-08-2012, 11:00 AM
BMW cheats usually down on the BHP ratings for the less expensive versions. Keeps an artificial spread among the various lines.
Kevin
Old 12-08-2012, 12:28 PM
MP3_E46's Avatar
Code/wrench Monkey
It's kw. Darn Continental Europe.
