Old 06-30-2012, 05:33 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by cn555ic View Post
Asked him to check his CAFD files and he has yet to respond, so until he posts his findings, I will be quick to say BS
As soon as he posted that on 6/24, in the very next post I challenged his assertion as the Missing CAFD error is related to a PSDZdata file, not an E-Sys file, and asked him to confirm it, and he hasn't yet. He said he was going to check it last night though and confirm it, but still no update yet.
In any event, besides the fact that we go though this every single time a new ISTA/P comes out, and E-Sys v.3.18.4 has yet to not work with the new PSDZdata files, in this specific instance, we have already seen where both users DESI4life10 and RASHID007, using E-Sys 3.18.4 could not code the FEM_Body ECU on brand new F30's using the v.46.3 CAFD_00000794-002_020_026 file; however, when it was updated with the v.46.6 CAFD_00000794-002_020_029 file, they were able to successfully code FEM_Body ECU with E-Sys 3.18.4.
Old 06-30-2012, 06:58 PM
Losco Losco is offline
Mein Auto: 2010 528i M-Sport
Originally Posted by mjgood View Post
I just got my car back from dealer, I have some problems with BMW Assist...
They had it almost 2 weeks and have been working with BMW Engineers, and no fix yet..
Dealer was told to put latest update on to try and fix, but it will be a week or more before they get the update, so I have my car back until the updates come in.
What I'm reading from this is that 46.6 may not be at all the service departments yet, once it gets out there the PSDZDATA files will probably start showing up...
E-Sys is probably the program we should all pool together on....
we're slightly off topic, but yes, last year e-sys 3.13(one that had est crack) did not work with new 44.0(I think), hence no one could code new cars... we're good now but don't know what will happen from here. we need java gods in our forum now
Old 06-30-2012, 09:43 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
I still think it will work regardless of E-sys version. How does one obtain these newest versions of the ISTA data is where we need to channel our collective energy. WIth the community as large as it has grown, a group effort to get enough funds to get these updates should not be a problem. We need to find the source of where to get it from. Anyone have any ideas how and whom do we contact as a direct source to get this data???
Old 11-17-2012, 12:31 PM
dodeemad dodeemad is offline
Mein Auto: F15
Hello gu
I need your help. look i have the 48.0 data file but when im running the e-sys its giving me error which was coming with our firned Big Sarge !
Any one can help? im using I com and with 3.20 V
Old 11-17-2012, 04:04 PM
April1 April1 is offline
Mein Auto: X3 2011
READ FA ERROR:
Few have reported "READ FA Error........"
This kind of error you will get when after clicking the Connect button and picking up the right SELECTOR, you do not select "CONNECT via VIN".
You might get a messge that EYS connection established (..162) but infact it is NOT.
Old 11-17-2012, 06:13 PM
Originally Posted by April1 View Post
READ FA ERROR:
Or incorrectly selecting the target with the _DIRECT after it.
Old 01-11-2013, 01:59 PM
DaKoren DaKoren is offline
Mein Auto: 2006 Black Sapphire M6
I'm having some trouble connecting to my car all of a sudden.
I can run the ZGW search and it will find the car but esys gives me a grayed out box for connecting via vin and a message that says "No ZGW Available"
I have tried ripping out Esys and reinstalling to no avail. Firewall is off for this connection. and I am able to see the list of Targets just no connect bus.
I was also able to do some coding before on this laptop with no issues, this problem just cropped up.
Any ideas?
2013 - Monte Carlo Blue M5
2011 - X5 35d
------Retired----------------------
2007 - Jet Black 335i
2003 - Silver Gray Metallic M3
2006 - Black Sapphire M6
Old 01-11-2013, 02:06 PM
Any ideas?
And nothing is different about either your setup, or your car since when it was working with no issues?
Old 01-11-2013, 02:10 PM
Not that I am aware of on the laptop. The laptop is exactly the same it only gets used for coding.
The car was in for service and had an update run but I had been able to get in to it since then but only once.
Edit: got it working on another computer... odd but at least I can code again.
2011 - X5 35d
Old 04-24-2013, 07:02 PM
jeremy480 jeremy480 is offline
Mein Auto: na
connection problems
I was using E-Sys a while ago and had everything working fine. Fast forward a year, I took my 2012 328i to the dealer to take care of a recalled sensor and they reset everything I programmed. Well, I now have a new laptop so I had to download and re-install all the coding software.
The issue I'm having is that I cannot connect to the E-Sys software. In E-Sys the Connect via VIN box is grayed out and says No ZGW Available even though the ZGW software is clearly reading my VIN.
One of the first tips in this thread was to make sure the "dist" folder is located within each of the mainseries folders, which it is. I also made sure the EDIABAS.ini file has ENET listed next to interface as another thread suggested. Attached is a screenshot of the grayed out VIN connection.
Any thoughts? Am I not making a proper connection to my car somehow and if not how was the software even able to pull up my VIN if it isn't?
UPDATE: Turns our one of my network cable wires broke at the solder joint. I can connect just fine now.
Now I just need to find an updated HU_CIC data set or something because I cannot edit the file at all. O_o
HU_CIC [63] [F343228]
readCPS o.k.
cafd_000000f9-007_006_009 Fehler:
File for "cafd_000000f9-007_006_009" not found! [C012]
Name:	esys screenshot.jpg
Old 04-24-2013, 10:02 PM
readCPS o.k.
If you need that CAFD, you have ISTA/P 2.49.2 on your car. Besides needing cafd_000000f9-007_006_009 for the Head Unit, it also means you won't be able to code anything until you update both your E-Sys and PSdZData.
PM sent.
Old 04-24-2013, 10:14 PM
Mein Auto: na
PM sent.
Yeah, I'm learning all sorts of new things today. A lot has changed since I first did all this coding to my car about a year ago. I also just learned that I now need to pay for a patch/token this time which wasn't necessary before.
I guess someone wanted to get a piece of all this hacking action and pad their pocketbooks a bit with some extra $$!
Thanks for all your help, Shawn. You seem to be the resident expert around here.
Old 04-24-2013, 10:22 PM
Not exactly. BMW made some security chnages to the PSdZData beginning in version 48.2. This rendered the old E-Sys 3.18.4 everyone was using useless. Fortunately, someone developed a solution, and while it does come with a price, at least it is a very reasonable one.
Old 04-26-2013, 06:06 AM
dmattiazzi dmattiazzi is offline
Mein Auto: BMW 120D Sport F20
PM sent.
Hi, i have the same problem on my F20 after a bmw service....
now i have the psdzdata 2.49.1, is possible to have a link to 2.49.2
thank Donato
Old 04-26-2013, 07:15 AM
thank Donato
PM sent.
Old 04-27-2013, 12:14 AM
webb webb is offline
Mein Auto: korea
Hi my friend.
PM sent.
Hi Shawn,
I need the 49.2
Can you please PM me the links for 49.2
Thanks advance.
Old 04-27-2013, 04:38 AM
Originally Posted by webb View Post
Hi Shawn,
I need the 49.2
Thanks advance.
PM sent.
Old 09-05-2013, 02:15 PM
spynick spynick is offline
Mein Auto: BMW F01/750, F10/535
Hi Shawn,
had already coded my F01. It cam back today with new firmware on it, all my changes are gone. Tried to recode it again with 3.18.x and corresponding psdzdata files. But all i tried ended up in:
Transaktions-Report: Aktion: FDL Codieren
Abbruch!
Asynchrone Programmierung fehlgeschlagen! [C049]
openECUConnection for link AMP_TOP_37_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name AMP_TOP_37_ETHERNET doesn't map to an item [1694] - VEHICLE_ERROR
Looks like that psdzdata or e-sys is in an wrong way, any clues???
Thank you in advice
Kind regards
Stefan
Old 09-05-2013, 03:06 PM
Originally Posted by spynick View Post
Hi Shawn,
Abbruch!
Thank you in advice
Kind regards
Stefan
Yes. You need new PSdZData, which in turn necessitates newer E-Sys with Patch / Token.
PM sent.
Old 10-16-2013, 04:19 PM
jlwh jlwh is offline
Mein Auto: 520d M Sport
Hi
I've finally got my ENET cable, E-Sys software 3.23.4, PSDZ data 50.4 and token/patch. I then followed all the instructions to set up E-Sys etc and connected the cable from my Sept 2013 F10, to my Win7 64 bit laptop. Connection is eventually established (with yellow triangle). When opening E-Sys, then clicking the connection button, the 'Connection via VIN' option is greyed out, with "No ZGW available" in the box next to that option.
This is my first attempt at connecting, unlike other posts where they seem to have successfully connected before. I have turned off wireless - as well as disabled firewall. I'm not running through a VM and followed the instructions to the letter (checked for 'dist' folder, copied all 7 folders etc).
Any ideas welcome.
Old 10-16-2013, 06:57 PM
Originally Posted by jlwh View Post
Hi
Any ideas welcome.
If your Motor was not running, try again with it running. Proper Voltage is critical, and sometimes the Battery alone is not enough.
Old 10-17-2013, 01:21 AM
Just tried that - same thing.
The output from "ZGW_SEARCH" is as follows:
State = 1
RemoteHost = 169.254.255.255
RemoteHostIP =
RemotePort = 6811
LocalHostName= A1C-0818
LocalIP = 169.254.212.30
LocalPort = 49156
So it seems fine other than getting the IP of the remote host (the car).
I've tried uninstalling/reinstalling everything too.
Old 10-17-2013, 01:28 AM
State = 1
RemoteHostIP =
RemotePort = 6811
LocalPort = 49156
Maybe your ENET Cable is no good.
Old 10-17-2013, 01:42 AM
I thought that too so checked the solder/connections and they are fine. Nice cable in fact.
It looks like the network connection is working just fine (i.e. disconnecting the cable results in disconnection of network) - just that the software isn't aware of it.
Could there be a setting file somewhere that is overriding something else?
When "ZGW_SEARCH.exe" is run in compatibility mode, it shows the output window, but throws an error relating to "MSWINSCK.OCX" when run natively in Win7. Could that be related?
Does "E-sys.exe" need to run in compatibility mode too?
Old 10-17-2013, 07:04 AM
The problem with ZGW_Serach is you need to register MSWINSCK.ocx to your OS.
From the Command Line, enter:
regsvr32 /u "C:\EDIABAS\Hardware\ENET\MSWINSCK.OCX"
regsvr32 "C:\EDIABAS\Hardware\ENET\MSWINSCK.OCX"
But, this has nothing to do with your connection issue, and E-Sys does not have to be run in Compatibility mode.
Do you have the Windows Firewall enabled, or are your running any Virus or Spyware programs? If so, you need to disable them all.
