Old 11-17-2012, 11:32 AM
rubberducky203's Avatar
rubberducky203 rubberducky203 is offline
Mein Auto: F30
Exclamation Engine screech at start up
The problem started yesterday morning as when I started it up I got this horrible screech from the front of the engine any help is greatly appreciated.
F30 328xi
Old 11-17-2012, 11:53 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Sounds like a bad bearing in an idler, or one of the accessories, or a worn-out fan clutch. Don't drive it until it's fixed. The bearing could seize and cause more damage.
Old 11-17-2012, 12:06 PM
Mein Auto: F30
I'm replacing the fan clutch today to see if thats it
F30 328xi
Old 11-17-2012, 01:45 PM
Be sure to examine the idler wheels and accessory bearings by spinning them, looking for noise.
Old 11-17-2012, 04:02 PM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
i doubt its the fan clutch.suspect the water pump.
Old 11-17-2012, 04:21 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
take the belt off and see how all the pulleys turn.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 11-19-2012, 01:36 PM
Check this out:
- How to diagnose noises coming from the drive belt system (1)
Old 11-19-2012, 04:24 PM
Mein Auto: F30
Pulley b in the attached picture is making a odd noise
Also how do I get the pulley right above it off as its in the way of getting the noisy pulley off.
Here's a vid too.
F30 328xi
