Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 11-16-2012, 07:00 PM
pranavf01 pranavf01 is offline
Mein Auto: bmw 750i f01 2009
SPACERS!!! effects?
Hey guys i like the look of stock 7 but i want my front wheels to pop out a little bit, i was thinking about getting spacers but i have no knowledge of them so i thought you guys can help me out.
i have a stock 7 with no aftermarket wheels or suspension, my question is HOW MANY millimeters is best? and WHAT ARE THE BAD EFFECTS, IF ANY?
thank you
i found this one with 10mm in the front and 20mm in the back H&R on a 3 series
Old 11-16-2012, 11:54 PM
ChrisF01's Avatar
ChrisF01 ChrisF01 is online now
Gib mir Feurschutz!
Mein Auto: 2013 750i
Well if anything at least your front drivers and pass doors will get dirtier faster from it throwing dirt and any moisture up behind it...
2013 BMW 750 - Coded, Executive, Lighting, Cold Weather, M Sport, M 303 Wheels, 5% Tint, Conti DWS Tires, 3M Bra, Front DE Plate, Vinyl Black Gloss Roof Wrap.
Old 11-17-2012, 04:00 AM
Richard109's Avatar
Richard109 Richard109 is offline
Mein Auto: 2012 750Li
My initial thoughts are that I like the wider stance; it gives it a "beefier" look. Guess I would need to see a 7 in real life to make the final call. Can you get any good advice from your dealer?
Old 11-17-2012, 11:49 AM
Wolfman64 Wolfman64 is offline
Mein Auto: BMW 750li, Mercedes SL600
I have used spacers on my MB for a wider stance and the (Brabus) wheels required them.
I think that it doesn't look good to get a wider stance without lowering the car though.
When lowered, a wider stance definitely requires you have a wheel alignment with the proper camber adjustment or you'll wear out the inside of the tires even faster than when just lowered (in 5k miles or less).
Also, you must use hub-centric spacers or your car will vibrate and give you a very poor ride.
Good luck!
Old 11-17-2012, 01:08 PM
Individual750LI's Avatar
Individual750LI Individual750LI is offline
BMW rocks!
Mein Auto: 2013 750I M
If you use spacers under 20MM, you are safer and won't feel any difference while driving.
If I was to put spacers on my stock 20's, I would do 10mm all around. Or 5mm front, 10mm rear.
Old 11-17-2012, 08:06 PM
do you think that the offset would be disturbed if i get 10mm all-around for my 19s?
Old 11-17-2012, 08:08 PM
i did not ask the dealer yet, wanted to just get some suggestion before i went that way.
Old 11-17-2012, 10:04 PM
BMW rocks!
10mm is pretty safe, just give the car a better stance but not affecting the suspension much.
Old 11-18-2012, 03:26 AM
f01driver f01driver is online now
Mein Auto: 750i, S5
Could someone post pictures of a stock 7 with spacers?
2011 750i
Old 11-18-2012, 08:51 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
I just got new rims for the winter yesterday. I'll fit them before December and probably with spacers. So I'll post 'em when I fit 'em
