Old 11-17-2012, 05:53 PM
Simonnim916 Simonnim916 is offline
Mein Auto: 2004 530i
Adaptive headlight not working
I just replaced my xenon bulb on both headlights and now the adaptive headlights are not working.
I am not getting any malfunction messages or anything but the light where I switch on my headlights on the inside is blinking.
Any ideas?
Thanks.
Sent from my MB886 using Bimmer App
Old 11-17-2012, 09:09 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
If you do a seach you'll find that yes it is a warning about the adaptive lights.
Old 11-18-2012, 12:58 AM
But why!!
Old 11-18-2012, 02:46 AM
sanlouzao sanlouzao is offline
Mein Auto: BMW 530,E60 2004.
If you don't get any message, check your switch command, is the little LED green flashing or fixed? and your main bulb headlamp side right is in position right (looking forward) or turned left or turned right?
Sorry if I don't explain correct it.
Old 11-18-2012, 10:57 AM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
[QUOTE=Simonnim916;7200556]I just replaced my xenon bulb on both headlights and now the adaptive headlights are not working.
Any ideas?
Is it the OEM bulb or after market?
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |F/R Cameras | Escort 9500ix |
Old 11-18-2012, 03:24 PM
It's flashing.
This morning I had pulled out the headlights and put them back in. The light doesn't seem to be flashing anymore...I put a sock on the light sensor. I'll update tonight if it's working.
Old 11-18-2012, 03:25 PM
[QUOTE=Shahul_BMW;7201465]
Any ideas?
It's oem philips 85122 c1. I think I might have just put the headlights on crooked...I'll update tonight.
Old 11-18-2012, 09:12 PM
Ok so I just removed the headlight and put it back on. It's working now lol, no idea why but 2 major things I did was fully push up the clip on the passenger side light on the big plug and driver side I just loosened the screws and let the lights move back to its original spot.
I moved the headlight a little to better fit my aftermarket m5 tech bumper.
Nonetheless it works.
Thanks for all the help guys.
Old 11-19-2012, 01:18 AM
Congratulation, at the first I thought the headlight had lost the bend adaptive function (like in my car), but only it were a bad connection, an easy solution...
Old 11-24-2012, 01:43 PM
Thanks =)
