E30 (1982 - 1993)
Old 11-16-2012, 07:13 AM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
I have worked 1 day this week, Monday I didn't work because I had no car, tuesday was a rain day, wednesday I worked, but puked at the job site a few times, yesterday I didn't go in because I puked every 30-45 minutes, today I puked right when I woke up. hellooooooo 50 dollar paycheck. fuuuuuuuuuu.
AND I STILL DON'T HAVE MY DAMN E30 BACK FROM THE SHOP...it just gets worse and worse..
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 11-18-2012, 09:19 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
new sig waddup lol
E30 above Sold
Last updated 2nd January 2014
Old 11-25-2012, 05:33 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Hope everyone had a good holiday and survived black friday! I got the 6 drawer Stanley tool chest with bonus tools ( 85pc) for $100!!!
And a Kenwood with ipod conn/ 6" speakers for the E30 for $88!!
Old 12-04-2012, 06:14 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Old 12-06-2012, 04:15 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Smile Common tools explained
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned cleco calluses from fingers in about the time it takes you to say, "Oh sh*t!"
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VICE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bum per.
EIGHT-FOOT LONG YELLOW PINE 2X4:
Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminium sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also, most often, the next tool that you will need
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 12-06-2012, 09:41 PM
NSFW
E30 above Sold
Old 12-06-2012, 09:46 PM
DRILL PRESS:
WIRE WHEEL:
SKILL SAW:
PLIERS:
BELT SANDER:
HACKSAW:
VICE-GRIPS:
WELDING GLOVES:
OXYACETYLENE TORCH:
TABLE SAW:
BAND SAW:
See hacksaw.
PRY BAR:
HOSE CUTTER:
HAMMER:
MECHANIC'S KNIFE:
DAMMIT TOOL:
enjoyed that
E30 above Sold
Old 12-08-2012, 09:37 PM
dream chasin'
Need your help! non car related
Me, Steve and my fiance started up a reptile breeding company. We are trying to get the word out about it for when we start hatching out babies. So if you could like our facebook page, it'd be greatly appreciated. Please don't post anything obscene or something along those lines, this is our hobby and something we want to get into, and we don't want a bad rep from bad posts. Thanks!
www.facebook.com/keystonereptiles
Old 12-09-2012, 12:12 AM
done. now what
E30 above Sold
Old 12-09-2012, 12:18 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Originally Posted by _Ethrty-Andy_ View Post
done. now what
Buy a reptile!
Oh, wait, you may have some importation problems.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-09-2012, 11:07 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
done. now what
now you send us some big NZ eels
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 12-10-2012, 06:46 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
we've got eels in VA steve... but i checked out your reptile page, pretty sweet
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 12-10-2012, 08:44 AM
fcsteve's Avatar
610EUROs
we have eels in PA too, i want some massive NZ ones.
Old 12-10-2012, 04:30 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
for some reason...i liked your page. good luck.
poor e30 is starting to get some attention again. it's suspension time...yea !
Old 12-11-2012, 12:58 AM
Nick323's Avatar
Nick's Toys
Maybe I should just pack a Black mamba into the post & see how you handle the unpacking
Old 12-11-2012, 05:20 AM
On Top
Screw that! Nick have you ever been to the states?
Old 12-12-2012, 10:46 PM
Nick323's Avatar
Nick's Toys
SWISS, indeed I lived in the USA for a few years
I enjoyed it trumendously, but then I got homesick...
Also we have a personal freedom here in Namibia, that Americans will never achieve again
Old 12-12-2012, 11:46 PM
Theres a can of worms
E30 above Sold
Old 12-13-2012, 12:22 AM
Nick323's Avatar
Nick's Toys
Worms is what they are collecting
Old 12-13-2012, 07:49 AM
Tkaczuk's Avatar
Merica!!! I own a gun. What other freedoms do I need?
Old 12-13-2012, 09:18 AM
fcsteve's Avatar
610EUROs
the freedom to cut down a tree, to build a shed on my own property, the freedom to park an unregistered vehicle i own on my own property without having the city tow it .. i could go on for days about how nobody in the US has even the most basic forms of freedom.
Old 12-13-2012, 10:09 AM
Tkaczuk's Avatar
I don't have to deal with any of that. Just the occasional Ladder Day Saint coming to my door. 25sq mile area has 2 township police and the occational state trooper. Not many people even lock there house here. Its a big deal when someone steals some batterys from a local store.
Old 12-13-2012, 11:02 AM
fcsteve's Avatar
610EUROs
doesn't matter if you have those laws where you are "yet", the fact still remains they can enforce those types of laws on people in america. basic freedoms don't exist anymore. bethlehem doesnt even allow a home owner to widen their driveway apron .
freedom is a joke in america.
Old 12-13-2012, 09:23 PM
do we have big eels? well there you go, i never knew that.
ok i can park an unregistered vehicle on private property if i own or rent it, i can build a non-permanent structure and cut down most trees, but they cannot be Native trees and permanent strutures like housing and garages need to be certified/approved by the local council before construction.
you guys have a lot more freedom with your modifications in cars than I have here though
NZ as well as the USA is a very free country on the whole though. Bitch about your lack of freedom to a good 90% of the world and they will probably punch you in the face.
E30 above Sold
Old 12-13-2012, 09:51 PM
fcsteve's Avatar
610EUROs
Jeremy Wade from River Monsters went to NZ to fish for big eels. you guys have them in crazy caves and rivers and stuff. the eels there weren't scared of him and actually bit and latched onto him a bunch of times before he got out of the water quick
-*nga*-, e36 has best forum, e36 rules
