Old 04-26-2011, 10:51 PM
msj0506 msj0506 is offline
Mein Auto: BMW 750LI
Hood wont OPEN!
Another Problem! My hood will not open. I think the cable has broke or has came off. There is no tension on the pully to open the hood inside the car. I tried and tried to get it open but no luck. I kno it has a latch on each side of the hood but have no idea how to get it open. Any advice will help!
Tks in Advance
Old 04-27-2011, 12:49 AM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Keif is your saviour.....here's his excellent DIY here :
http://www.bimmerfest.com/forums/sho...d.php?t=403879
My BMW ACS7
Old 04-27-2011, 04:29 AM
wicky wicky is offline
Way East...
Mein Auto: To many cars..
My hood opens fine from the inside of the car....but the lever inside the grill is kind of strange...point in different directions all the time... and the hood doesnt stand up...falls back down....
Old 04-27-2011, 04:53 AM
745Japan 745Japan is offline
Mein Auto: 2005 745i
Dealer.........
Old 05-13-2011, 08:50 AM
4realguy 4realguy is offline
Mein Auto: 2007 750Li
You will need to have your Gas filled stuts replaced for the Engine hood.
2007 BMW 750Li w/ Comfort Access and Soft Close Doors
Luxury Seating Package w/massaging driver seat, ventilated front seats, a heated steering wheel and rear sunshades
Premium Sound Package w/ 13-speaker Logic 7 sound system with an in-dash CD changer
Staggered Chrome Rims/Michelin Pilots & BMW Centers
Old 05-13-2011, 09:34 AM
antam23 antam23 is offline
Mein Auto: 2002 BMW 745i
Tks in Advance
Same thing happened to mine. I learned there were three cables to open the hood mine turned out to be the one inside the car attached to the lever. I had to have that cable and the lever replaced.
Old 05-13-2011, 10:59 AM
Unfortunately it isn't my inside cable. I already took the stuff inside the car apart and it looks good. My problem is under the hood, but guess what???....I can't get the hood to pop. I can not access the locks like on Keifs post because the post is for 745. They added more things and it is not accessable on 750's. I hope there is another way. The dealer told me that tghey would have to cut the cables and it would cost $775.
Old 05-13-2011, 09:41 PM
hotwillz33 hotwillz33 is offline
Mein Auto: 2009 X5 4.8I, 2000 Vette
Easy Fix
I followed Keifs instructions to a the letter and it was pretty easy. Just a word of advice though be prepared to get your hands scraped a lot.
Old 05-13-2011, 09:43 PM
Hood Struts
The hood struts are easy as pie to change, just pull the ring and pop them off. Install is the same as removal.
Old 05-14-2011, 03:45 PM
Once again, Keif's instuctions work PEREFECTLY for 745's. It also worked for taking apart the inside under the dash by the handle. I have a 750 and it is too obstucted to get in there. There are bars, resevoirs, and metal plates in the way.
Old 05-14-2011, 06:21 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
If anyone in Houston has a 750 that I can look at, please let me know.
Sent from my ADR6400L using Bimmer App
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 11-19-2012, 06:02 AM
Bmw760li Bmw760li is offline
Account Under Review
Mein Auto: 760li
can anyone help,,,2003-760li,,,,how to bonnet open???
plz
Old 12-27-2012, 09:19 AM
Funky mark Funky mark is offline
Mein Auto: BMW e60 520i
Tks in Advance
Had same problem and took me 5 mins, got car on ramps and removed engine cover under car and located latch with torch and got long piece metal to push latch where cable come out
Old 07-03-2015, 09:22 AM
gabeinseattle gabeinseattle is offline
Mein Auto: E65 2007 750i
Mark,
I will have to try this tonight, it seam the 2007 and up E65 would have to follow this procedure. There is an additional air filter box that the earlier versions of this model did not have.
Old 07-04-2015, 05:59 PM
gehrco gehrco is offline
Mein Auto: 2006 750Li
Post Hood Won't Open
I have a 2006 750li with a hood I can't open. I think the cable may have stretched. The opening lever was always almost to the end before it opened, now you feel pleasure but it won't open. I've pulled the release lever all the way and pushed down on the hood to help it release. I've removed the internal lever and pulled directly on the cable. I've seen the posts for the 745, but after I removed the window washer reservoir per instructions, there are still to many things in the way to reach or even see the latch. My assumption is I must manually release the two latches from the front. I'm really at a loss, but before I start cutting into the sheet metal from the back, or something else really radical, I'd like to hear how others have solved the problem.
Old 07-05-2015, 03:58 PM
Same here, I have the front end of the car up with the engine cover off and cannot find the latch. I see but cannot get it to release the hood.
Old 07-05-2015, 04:14 PM
Is there anyone that can post a few pics from the top of the engine bay, that shows the position of the hood latch for a 2007 E65 750i? I would greatly appreciate it.
Old 07-05-2015, 09:24 PM
mybmw408's Avatar
mybmw408 mybmw408 is offline
Mein Auto: BMW 750i
Dude it's in here just search kief, he did it with pictures
Old 07-05-2015, 10:16 PM
Hood wont OPEN!
Not exactly, Kief had the 4.4 write up. The 2007 has the 4.8 with additional plates and an extra air filter box. Which makes it very difficult to get to the latch.
Old 09-28-2015, 11:23 PM
PGH750li PGH750li is offline
Nick
Mein Auto: 2007 750li
Has anyone figured this out? I'm having the same issue and also tried to use the process Kief posted. As gabeinseattle stated, the 07 is much different. I'm now at the point of my oil needing changed so bad that I can't let this go any longer. If anyone has any info, PLEASE HELP!!!
Old 09-29-2015, 12:37 PM
eric6869 eric6869 is offline
I've got an '06 and I released my hood by following Kief instructions on taking the inside apart and with pliers I pulled the cable head as hard as I could with my son gently pressing on hood and it released.
Old 09-29-2015, 01:03 PM
Nick
Thanks, Eric! I've taken apart the release handle as well as removed the kick panel to expose the cable and tugged on it pretty good, with and without someone applying pressure to the hood latch positions. I've put it in the air and removed both front wheels and the inner fender wells, with the washer resevoir removed and still was unable to access the cables. I also removed the bumper cover as much as possible without being able to remove the top bolts under the hood. The only thing I have yet to try is to remove the front grill which I havent had anyone confirm so I held off to avoid busting the clips on the grill. Sorry for the book, I wanted to cover the steps i've taken so far in hopes that someone can shed some light on what i'm missing. Any help is greatly appreciated!!
Old 10-02-2015, 05:53 PM
pedro2u pedro2u is offline
Mein Auto: 745i
Seems to me, if the difference between these models is some extra plates and air box, Keif's outstanding write up with pics shows the rest. My hood wouldn't open on my 02 e65 and once I removed the inner wheel liner, I could just barely reach the hood latch from below. So I took a thin long straight bar that wouldn't bend ( it was the bar on a 3' carpenters clamp) and slid it up from below against the latch where the cable connects (you can see the cable from below thru the slot). I pushed hard out towards the fenderand it popped open.
So on my 02, tonight I just replaced the inside rear cable, bracket and handle (didn't fix it), then the the middle cable that has the housing built into the end of it to connect to the rear cable. That housing was shot.. The housing containing the middle cable connects between the hood latch at the front and the inner cable. I bought a new hood latch as well. Manual says to pull the headlight out, but don't do it. That section is an easy swap with just 2 torque screws and the hood bracket and the cable w/housing come out together.
works slick now. At 208K miles, I have to open the hood more
Old 10-05-2015, 07:58 AM
erniejazz erniejazz is offline
Mein Auto: 745il
hood release/ indy shop scam!
Just had this happen. My shop installed a tranny in 2004. Great job by the way and only cost me 850. I had to track down the tranny. Anyway, first thing the shop says when i pick up is we could not get your hood open. Odd, why are you needing under the hood??? And, it worked fine before. He of course offers to fix it. I decline. I followed the awesome dyi here but was having a hell of a time with the cable and it was a bitch to get to. I have big forearms and it is tight in there. I took off the wheel well, windshield wiper fluid container bracket and made a tool. Worked so perfect.
Take a weed puller gardening tool. Looks like a 2 pronged fork about 12 inches long with wood handle. Put it in the vice and bend to 90. Stick it up to the latch and tug. 1st try it worked. My latch was pretty snug and I had no help so getting it with my fingers was impossible. This worked perfect.
Anyway on to the scam. On the driver side rail where the cable harness is there is a 4 inch plastic container with the diameter of a penny. I unlatched it and bam! there is the fn cable unhooked. No damage just lifted from the bracket. I snap it back in and everything works great. What a scumbag! There is no doubt after snapping it back in the Indy was trying to jam me. He pops the cable out of the bracket, offers to fix for 4-500, probably says it was broken and needed replaced. He pop that thing back in 10 secs and invoices.
Anyway PM me if you would like a pic of the tool I made.
Old 10-22-2015, 09:58 AM
I ended up taking to a friend's shop, he dismantled the latch handle on the inside footwell and yanked the cable with two pliers. I ended up replacing both hood cables to be safe.
