Old 11-17-2012, 11:21 AM
maggasp maggasp is offline
Mein Auto: E61 535 XiT
Bad water pump?
Yesterday my '08 535 overheated (40k mi). First I noticed that there was no heat through air vents, then the radiator fan turned on very high, then the overheat.
I've read a bunch about replacing the thermostat and water pump together, but I'm just trying to diagnose whether the pump is bad and I need to spend the $400 on that part.
I initiated the water pump bleed procedure, and the pump turns on and circulates some coolant, but it sounds very weak to me.
Please take a listen/look at my video and let me know if you think if the pump is working properly.
Old 11-17-2012, 08:18 PM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
Mine sounds exactly like yours. I am having it replaced along with the thermostat, on Monday. Parts and labor by an indy $800. My car has close to 36K miles on it. I noticed the noisy pump after replacing the coolant and during the bleeding procedure. Luckily noticed it before an overheating incident.
I would not start the car again unless pump and thermostat is replaced.
2008 535i Monaco Blue
PP, SP, SAT w/paddles, ARS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Trim,
Gray Dakota Leather
Old 11-19-2012, 09:16 AM
Thanks for the response. I just bought the parts ($500) online, so it sounds like $800 all in at your indie is a good deal.
