E36 (1991 - 1999)
Old 11-19-2012, 12:49 PM
93az325is 93az325is is offline
Mein Auto: 1993 325is
Fun with AZ emissions
A Craigslist crook suckered me for 1400 for this '93 325is a few weeks ago. I sure hope he made a profit! As for me, well... Not so much.
Lessee, I had to pass emissions to get the title and plates but I couldn't go to emissions because the car had already gone through it's allotted 3 trip permits this year. So I took my chances and no, it didn't pass.
So I replaced the cat, muffler, o2, put in iridium plugs, cleaned the maf, the icv, fixed a couple hoses.. Went back to emissions, it did worse than before.
Out of options, I decided to just get a waiver, since I'd already spent more than the minimum 450 trying to fix it. Today I was able to sweet talk the DMV lady into a 3 day trip permit. At the waiver testing, it was more than twice the allowed limit, so no waiver. No wavier, no title, no plates, no freaking idea.
The car pulls code 1222 - Air/fuel mix.. Most likely a vacuum hose. It runs like it's missing on one cylinder. It smell like gas. At one point I took all the plugs out and cranked the engine (when I was testing the coils and plugs) then when it was all back together It started up and ran like a champ. I drove it to emissions, 10 miles away, and about a mile away from the place it started it's crap again.
So I just took it to a mechanic and told him to figure it out.
I'm screwed. Thanks, Craigslist!
Old 11-19-2012, 12:52 PM
jonesin's Avatar
jonesin jonesin is online now
The Canadian Prick.
Mein Auto: '96 328is Cosmos
So you bought a car without knowing much about them, did no research, didn't get a PPI, yet somehow it's both the fault of Craigslist and the PO?
EDIT:
Not to come down hard on you, but c'mon man. Take at least a little responsibility.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 11-19-2012, 03:39 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i Hellrot Red
And this guy gets no help. Guess you really are out of opinions.
Wait: where'd his other comment go? The one where he told Ed to F off.
Patrick ///98 328i hellrot///BMWCCA#465139
Old 11-19-2012, 03:53 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Dude buys $1400 BMW and expects it to run...
Any idea what else is full of fail?
1998 BMW 328is
1966 Pontiac GTO
Old 11-19-2012, 06:22 PM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
well, i paid less than that for mine, when i got it, but i also worked on cars for 15 years as well....
anyway, to the op, if you purchased the car in this condition and then put all of these parts into it, without any sort of diagnostic proceedure other than guessing, then i really don't know what else to say.
however, without specs, there is little to know way i could even come close to giving you any sort of diagnostics on this.
throwing parts at it apparently has not worked.
so, backup and punt.
we'll start with the following...
what were the emissions readings?? what are the specs??
what were the readings at the second test??
was the cat an oe unit, or generic replacement??
iridium plugs pretty much are a waste in a daily driver.
do you have a vacuum guage?? what does the guage read @ idle??
df
Old 11-19-2012, 09:42 PM
clockthis1979 clockthis1979 is offline
Mein Auto: 94 325 IS
I got my 94 for 500 buck from i guy that was leaving the state all i did was plugs oil change and a coil, so you can buy a car for cheap and it run great mine is not perfect by no means. I also used to work on cars (Toyota) for 6 1/2 years before i joined the service but i agree with- drivinfasters - post on what the cords are saying and what the vac is like at idle and on the cat, i know i have change more than a fair share and a lot of times if its not the O.E it will not clean as well. other than that i dont know what to tell you except good luck man. just let us know what you find out
Old 11-20-2012, 04:25 AM
mgoods50 mgoods50 is offline
OBDI Junkie
Mein Auto: E36 M3
This doesn't make any sense. post all your numbers and exact parts replaced. I have a '95 with a stock cat, modified (see album)- and PASS with less than half allowance.
It's not what you buy, it's what you build- Unknown
EN90283 - Stabled for HG repair
DH06247 - Running like a champ
Old 11-20-2012, 08:27 AM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
Ahh so you are the one who bought that 93 is? Why is he a crook? Here in Phoenix AZ, if the car runs it is $1000 and more even for totaly thrashed junk. If the car does not run it is $700 minimum. Here in HOT Phoenix people overheat these engines, and that one you bought was overheated, cracked head, missfire. Engine is junk.
Old 11-20-2012, 09:48 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
It seems many comments in this thread were removed. Anyway, back on topic: Check all the intake hoses. Sometimes the boot before the throttle body will have a small crack in it that can cause it to run weird.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 11-20-2012, 09:57 AM
jonesin's Avatar
The Canadian Prick.
Nope, not that I can see. This is exactly the info I read in this thread when it was posted.
Old 11-20-2012, 10:06 AM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
e36 aint noise pollution
Mein Auto: 1996 328is
The op threw an F at you. Maybe he thought you were being a prick or something. If your feelings are hurt we can start a support group
96 328is preceded by 09 G8 GT... RIP 7/15/2011
Originally Posted by E36 Phantom View Post
We've tried this before and it never has really worked, but good luck bro.
Old 11-20-2012, 05:01 PM
i wish i had this kind of diag kilz, yo...
df
Old 11-27-2012, 08:35 AM
Well, my suspension's over, so I can add that I diagnosed and replaced the #4 coil pack and the car runs great. I passed emissions and got it licensed. To the guy who wished I had a cracked head- Thanks so much for the words of encouragement.
