Old 11-13-2012, 05:59 PM
Ffejdnalloh Ffejdnalloh is offline
Ffejdnalloh
Mein Auto: Z4
Question Center Console Removal Help
My doorlocks & hazard button got pushed down into the console and I would like to remove the section between the seats to attempt to restore them back to their original position. Can anyone tell me how to remove it? It looks as if there is a small rectangular trim piece under the E brake and then the shifter surround. Does it pop out w clips or is it screwed in? Any help would be greatly appreciated.
Old 11-18-2012, 05:49 PM
morrieschoice's Avatar
morrieschoice morrieschoice is online now
Mein Auto: 2001 3.0 Z-3 ROADSTER
center console removal
click on SEARCH FORUM on the Z-3 page and type "console removal" in the blank space and then click GO. There should be some threads that will have the information you need. Good Luck
Old 11-19-2012, 03:15 AM
wayne rose wayne rose is offline
Mein Auto: 2001 S/C Z3M Roadster
switch removal
Remove the trim around the shifter ( clipped to consol with about 6-8 clips-gently pry up on ring then when it starts it will come easily. Then you will be able to access the hazzard /window switches.
Hope this helps
Wayne
Old 11-19-2012, 01:45 PM
Guus Guus is offline
Mein Auto: BMW Z3 2.0 I
http://adkusters.hobby-site.com/BMW%...0handleidingen
Try this link its also got pictures they say so much.
gr. Guus
console, door lock switch, e85, hazard light switch, removal, z4
