E36 (1991 - 1999)
Old 11-19-2012, 02:21 AM
SpinfisherBob SpinfisherBob is offline
Mein Auto: bmw
sweet 1995 325i convertible
I bought a 1995 325i convertible for my Daugther July of this year. Has run great until this last week when it just stopped. Turns over and will fire with a drop of starting fluid. I let it sit a couple days and it fired and ran perfectly all day....then nothing the next day. I do not hear the fuel pump engage. Lifted the back seat and put a meter on the fuel pump plugs...with key on the white plug reads 12 volts, the black plug 0 volts. I had the key turn the engine over and still registered 0 volts on the black plug....the relays all click when the key is on... I applied 12 volts to the disconnected fuel pump...it runs....now what
Old 11-19-2012, 07:19 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Possible: Fuel pump relay. Clicking means nothing. They can click and still not work. More likely: crank position sensor.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 11-19-2012, 01:40 PM
Mein Auto: bmw
Any way to test crank position sensor?
I swapped Solenoids with the same numbers and colors... Light green ones with the number 464.....with no result. Not sure witch solenoid runs the fuel pump though...
I do not sense the fuel pump running with one hand on the key and the other on the pump.
When I powered the pump directly, it was pretty quiet. Did not rev very high to my mind. I tried powering the pump directly while my kid turned the key....nada, reversed polarity...nada
I was hoping for a straight up diagnostic, but this is part of the joy...mixed signals
Old 11-19-2012, 02:34 PM
Mein Auto: bmw
I have located the fuel pump relay...N0. 1 in the Haynes manual, cleaned contacts, replaced...nada
I know I have spark cause she fires with a drop of starting fluid...I'm strongly leaning to throwing a relay and the fuel pump at her....there is a circuit diagram on the side of the orange BMW relay....will try test the relay on the bench next....
