Can you put fog lights on 335is - Bimmerfest - BMW Forums
Old 11-19-2012, 03:36 PM
cluskin cluskin is offline
Mein Auto: 1995 BMW M3 Avus Blue
Hi. I apologize if this is asked before but I've searched and can't find an answer. I see after-market lights claiming to be fog lights for the 335is and was wondering if anyone has added fogs to theirs. I am looking for a used 335is now and am getting prepared..
Thanks!
Old 11-19-2012, 03:59 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2018 440M-Sport MPPSK/THP
Mein Auto: 2018 440M-Sport/MPPSK/THP
IIRC the IS Convertibles have the take a look to see if its just a parts swap. Main issue might be the oil/water coolers behind the grills. Also think they put them on the 2013 coupe
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/THP 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 11-19-2012, 04:13 PM
Yes, sorry - looking for a coupe. I would suffer w/o the fogs to get the transmissions but just can't do without the sunroof.
Old 11-20-2012, 12:45 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by cluskin View Post
Hi. I apologize if this is asked before but I've searched and can't find an answer. I see after-market lights claiming to be fog lights for the 335is and was wondering if anyone has added fogs to theirs. I am looking for a used 335is now and am getting prepared..!
Fogs don't add much, oddly. Not worth the effort IMHO.
Old 11-20-2012, 05:07 PM
vstM3's Avatar
vstM3 vstM3 is offline
Mein Auto: F80 M3
Don't ruin the special look the IS has...
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is
Other: 2014 Mini Cooper
Old 11-20-2012, 05:41 PM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
Thanks!
The original idea of fog lights delete on is was to allow unrestricted air flow for better cooling of additional oil cooler, and now you are trying to reverse it.
EDIT: don't really know why the convertible 335is has the fogs though...
Sent from my Galaxy Nexus using Bimmer App
BMW CCA Member 454031
Save the manuals
Old 11-20-2012, 06:01 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
This is partially correct. BMW deleted the fog lights to allow unrestricted air flow for better cooling and added an additional water cooler on the 335is (all 335i models with the Sport Package or the M Sport Package have an oil cooler but not the additional water cooler) but this was because US tracks are shorter and in warmer climates (Willow Springs, Streets of Willow, Buttonwillow, and Chuckwalla are all in the California desert) than those found in Europe and needed the additional airflow and cooling to keep the car from going into "limp mode" when run on short tracks and in hotter climates. Yes, BMW actually designed the 335is Coupe with better cooling specifically to be able to run on US tracks. The enhancements to the 335is over a 335i were designed by BMW NA and it is a North America only car, not available in Europe (the exhaust is too loud!).
Additionally, BMW determined that 335is Coupe owners would be more likely to track their car than 335is Convertible owners and so they deleted the fog lights on the Coupe and not on the Convertible.
OP: If you don't track the 335is you probably don't need the additional cooling, but as CALWATERBOY says, why bother? Fog lights won't make your 335is "kewler" than it already it, especially if you drive with your fog lights on all the time even when there isn't any fog. And as vst335is says, why ruin the special look of the 335is?
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 11-21-2012, 09:19 AM
Pasa-d Pasa-d is offline
Mein Auto: 335d
The first things I did on my old Audi S4 (B5 series twin turbo) was remove the fog lights and replace them with Canadian grills (no fog lights up there apparently). The intercoolers lived behind those openings so the more airflow the better.
Most foglights are useless anyway, including the ones on my current vehicle.
