X3 E83 (2004 - 2010)
#51
Pictures please. I'd like to see the drop/new stance.
#52
Also, yes you can use the stock springs with Bilstein shocks. Most ( including myself) use Eibach or H&R aftermarket springs because of the lower cost.
Mlukas that is what I thought. I put so many miles on my cars I usually reuse my springs (unless they break). I have a strut spring compressor for this.
#54
I have upgraded both the front and rear sway bar links. The existing ones were pretty loose.
#55
Did you need to compress the new front springs when installing them on the shock? Thanks for the write up, my wifes front shock exploded last night.
#56
Yes, the front springs need to be compressed to take off the old ones and also to put on the new ones. An impact wrench is usually a must have. It's somewhat dangerous so some choose to take the front assembly to a shop to swap out the springs.
I did not have to compress the new eibach springs whe installing on the bilsteins. I just tossed the old strut and spring away. I consider the orignal strut/spring as low quality if it cant even last 50k miles.
#58
So i got my wheel alignment done. It cost me $59.99 with 6 months warranty. I got it done at http://www.networkautomotive.com/. They did a splendid job. The sepcs used were 2004-2010 BMW X3. The toe needed to be adjusted on rear and front. The camber/caster was within spec.
#59
Awesome topic. I have been thinking about doing this exact thing to my '07. Thanks.
#60
x3mech,
where did you purchase the open socket so you could tighten the nut on the bilstein? I have an oxygen sensor socket but it's to wide to fit down the opening. |
#61
Here is my before and after photos of the Eibach Pro-Kit and Bilstein shocks. Dropped the suspension 1".
#62
Please reference the grinder pics. I just ground the oxygen sensor. If you still face issues let me know.
#63
X3mech. thanks for the in-depth thread. Last edited by 1stbmwx3; 06-01-2012 at 09:32 AM. |
#64
Is the ride smoother? Harder? In the middle?
#65
Thanks X3Mech and Mlukas161. Both of your threads were helpful. I had two busted rear springs. I just installed 4 Eibach springs on Sunday. I am swapping the struts and shocks at a later date. My ride height is at 17" from fender lip to wheel center at all four corners. Totally level. gzep23, the ride is more controlled than with the OEM springs. It takes way less effort to toss the car through sweepers and twists. The ride is less jarring. The car also seems to be more planted through whoops. I also installed cryo rotors and cermaic pads at all four corners. My style 192 wheels are on the way. I can't wait to feel the difference with the entire setup installed.
#66
My friend and I completed the spring and shock swap on my wife's '06 X3 with 70K miles. We used the details of this thread to start. Some changes for us:
Not all parts are still available from the same vendors. I had to mix and match a little and have ended up with some duplicates on the small parts. Used a GearWrench passthrough socket set instead of the ground down oxogen sensor to tighten the shock nut. The extension for the GearWrench set is long - requires a long allen wrench. Got a long allen set attached to sockets from Sears last minute to hold the shock shaft in place. My Bilsteins were 7mm not 8mm for the recessed allen bolt in the shock shaft. I could not verify 55 in-lb on the nut this way. Even with a torque wrench on the allen socket, the socket would begin to strip before the torque wrench clicked out. Front axels would not pop out. Needed an extra inch to get the fronts out. Had to use a spring compressor to give us the additional inch installing and removing the shocks. The compressors on the new shocks only fit in one way in the cavity - one with three spring turns and another at two. The spring compressor shafts touched the baseplate for the springs preventing fancy GearWrench set from being used We used a wedge to help pry apart the shock cup for removal and reinstallation.The shock caps did not fit my new bearing plates. I ended up using teflon pipe tape to make the caps bigger to fit the slightly larger holes of the new bearing plates. Using OEM bearing plates my have eliminated this. We tried grinding down an adjustable wrench for the sway bar end removal but it didn't work so well. We found a flat tool in the shop that worked. My buddy forgot to set the air gun to "not break" and tore the end of one link off when he accidentally tightened the nut that was already tight and sheared the bolt. For reinstallation of the new part, I ordered the Park Tools Cone Wrench Set - flat and in the correct size. There are thin wrench sets out there but I could not get them in time to be convenient for me. Both rear springs were broken and were the reason for the swap. We were prepared for the PITA spring removal. We found that by moving the jack out of the way from the suspension we were able to extend the suspension enough to work out the spring by hand and install the new one in the same way. One person on the spring the other pressing on the brake disk with your foot. We used a lubricant safe for rubber on the bottom plate to assist reinstallation. The X3 sits lower and is scheduled for an alignment. Major improvement felt so far. Thought the job was not easy but not impossible. Saving $1k and new tools was worth the time for me.
'13 VW JSW TDI until BMW brings a cheaper Diesel to the US '06 Flamenco Red X3 3.0i '06 Red R1200RT |
#67
X3Mech, Thanks for the great post!
I need to replace all the struts and shocks on my wife's 2004 X3 and I only have max 3 hours per Saturday to work on the car so the more I prepare in advance the better. I noticed that on 3/26 you mentioned not having to compress the new eibach springs when installing on the bilsteins: did you ever had to use a spring compressor at all? like when installing the whole strut + spring assembly? What size is the oxygen sensor socket you used ? Thanks! |
#68
If you buy new springs and all new strut hardware no spring compressor is required. You can assemble on your workbench and remove the entire old assembly as one piece and install new...
#69
2007 BMW X3 Suspension Upgrade: I was going to use this great post to fix my '06 x3 but at got a price adjustment from the local dealer to do the front pair. Seems this was a good call, though I love to get dirty, the Tech has spend 6 hours getting the old struts OFF ! Having spent many cold nights under my old Chevy bang'in and cussing I'm glad I passed.
#70
I just finished this upgrade over the last two weekends (Bilsteins & Eibachs) here are my observations:
Rear suspension: took me 4 hours total. Removing the rear interior panels is a tedious task which requires lots of patience. To remove the coils I used the OEM jack located at the exterior side of the upper arm pushing down. Some times the jack slipped so I used the spring rubber pad to provide a better anchoring surface. Gloves is a must. Need to be cautions not to hit the jack once springs are being pulled. Good time to check the RTAB's. The lowered suspension created more negative camber but I did not want to mess with the eccentric bolts, I rather pay for this and get it done good for once. Front suspension: took me 6 hours total (1.5 hours setting up and cleaning work area, 3 hours first strut, 1.5 hours second strut). PB Blaster and the 4 lb orange dead blow hammer from HF Tools are your best friends. I found that removing the calipers makes inserting the struts easier since you don't have to worry about putting too much tension on the brakes flexible lines. Inserting the strut into the bearing carrier takes time, the key is to make sure the tripod on the axle gets pushed into the tulip housing. Lifting the bearing carrier with the jack and hitting it with the orange hammer where the bolt goes made the insertion faster. Special tools: you need to get a 7/8" oxygen sensor and grind it so it can fit the ID of the strut bearing plate. 7 MM hex wrench is an odd size, once again HF Tools has a complete set for $4.99 can't beat that! Coincidentally it was time to replace the turanza EL42's so I switched to Michelin Defenders. The car drives superb now! total Freude am Fahren!. This is my wife's daily driver and she is very please with the new set up. |
