Old 11-19-2012, 05:08 AM
Ivanhoe1997 Ivanhoe1997 is offline
Mein Auto: '97 Z3
Great, I have a similar trailer and did not think it would go on it without some jacking etc. Keep us posted on the project, pictures for sure. ic
Old 11-19-2012, 09:39 AM
SC2003Z4 SC2003Z4 is offline
Mein Auto: '03 Z4 2.5i Silver/Black
Mhopper, car looks awesome. We are all excited for you!
I went back and looked till I found this post from a guy here in the forum. You may have seen it alrerady...
If you ever lose motivation on your restoration project, just look at what great shape your car's in to start with.
1997 Z3 2.8 rebuilding - father-and-son photo blog
http://www.bimmerfest.com/forums/sho...d.php?t=651234
http://www.facebook.com/media/set/?s...1&l=e28c92328c
Javier
2003 Z4 2.5i Silver/Black
Old 11-19-2012, 10:52 AM
mhopper mhopper is offline
Mein Auto: cars--many!
i just heard from my mechanic. A rat or something had chewed on some stuff. Two oil gaskets leaking. Serpentine belt is in rough shape. wires to brake and abs sensors and abs module chewed through. replace a couple of things in the cooling system. bad airbag sensor. change all fluids. pcv valve/oil seperator... tune up w/spark plugs and coil packs and a ton of other miscellany including wiper blades, detailing, etc....$1649. He is fixing everything I need minus tires and a top. For a free car, I can handle that. i hope that next time repairs are needed I will be knowledgeable enough to handle it. He said the motor is strong and the suspension is all good!
Old 11-19-2012, 11:05 AM
watchurself watchurself is offline
George
Mein Auto: 2002 bmw 4.4i x5 sprts pg
Not bad at all hopper!!!
GEORGE
"EVERY FORM OF REFUGE HAS IT'S PRICE"
2002 4.4i BMW X5 - 166K Topaz Blue Ext/ Tan/Beige Leather Int
1994 Nissan Pathfinder SE 132K Black Ext / Grey Leather Int
Old 11-19-2012, 12:02 PM
Mein Auto: '97 Z3
yeah, those mice like a Bimmer. I had some of the same wires chewed. The former owner forgot to tell me but I found and fixed the issues myself. I have a lift in the shop and that helps with junk like that. Took off the inner fender on the left side and found some chew damage behind there. All is good now. I am in the middle of top replacement. Got the old off now if I can get the new one on! ic
Old 11-19-2012, 07:26 PM
Which top did you go with?
Old 11-19-2012, 09:16 PM
Bucko521 Bucko521 is offline
Mein Auto: 2006 BMW Z4 3.0i
Fantastic find.... well worth it. Keep us posted on the progress... excited to see the progression.
2006 BMW Z4 3.0i Black/Tan/Black
Old 11-20-2012, 05:05 AM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
Mhopper, I totally understand the "critter" thing as in mice and chipmunks. Mine was kept in a shed/garage before me buying it and the rodents made nests in my air intate for the vents and under the driver's side foot rest. I'm still blowing out house insulation from the vents from time to time when switching between defrost, vents, and heater. I also found a wad of snake skins inside the rear console between the seats. The perfect slithery home, lunch served upfront and condos in the rear. LOL Use caution when using the air conditioning, etc. I spent several trips down the road with the top down and the blower on high trying to blow most of it out. Good luck. Again, fantastic find.
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
Old 11-20-2012, 05:17 AM
Mein Auto: '97 Z3
got my top from Quality Tops and Interior off of ebay. They had them on sale for $228 delivered. The top is fine. I will finish the installation today. ic
Old 11-20-2012, 11:11 AM
top ordered!
Old 11-20-2012, 12:26 PM
BStanton BStanton is online now
Mein Auto: 1998 BMW Z3
Excellent Find!!!! You will love the color.. clean it up, give it a good polish and it will look like stainless steel in the sun light..
This is my toy. 1998 (2.8)
Old 11-20-2012, 12:28 PM
Great Find. You will love the color.. clean it, polish it and it will shine just like stainless steel.
Old 11-27-2012, 04:30 PM
car comes home tomorrow! i just hope the owner of the snakeskin the mechanic found isn't hiding in their somewhere!
Old 11-27-2012, 05:06 PM
Mein Auto: '97 Z3
Had mine out today, love to drive it. I am sure you are going to be pleased. Let us know how it drives. ic
Old 11-30-2012, 04:07 PM
How big of a deal is it to change the center drive shaft support. Mechanic said it would need to be done soon.
Old 11-30-2012, 05:59 PM
Mhopper, it's no major issue. Did mine a couple months ago and also changed out the u-joint vs. changing the drive shaft. Drop the exhaust, pull the heat shield, and unbolt (4) ujoint bolts at differntial, (4) bolts at transmission, and (2) nuts at the carrier bearing. Be carefull to match mark the driveshaft before separating it and check the center u-joint while you have it that far apart. The most difficult part for me was getting the old bearing off the shaft. I ended up cutting mine off since I had a complete new carrier ready to go on. BTW, when I get a chance I'll upload you the photo of all the "skins" I found in my rear console. LOL Glad to hear there is another reptile based speed buggy out there. LOL
Old 12-01-2012, 05:07 PM
Finally got to pick up the car today. This thing drive great!
Old 12-01-2012, 05:44 PM
Hopper, you ever detail that thing? We want pictures of the final product!
Congrats once again.
Javier
Old 12-01-2012, 06:42 PM
Not yet. I gotta find time to put the top on it before I finish clean her up!
Old 12-03-2012, 04:49 PM
Ok...I have perused the forum for two hours and not found an answer. My seats do not move.... Either of the... At allll. The motors make no sound. I don't think they are getting any power. Is there a relay? Fuses are good.
Old 12-03-2012, 09:49 PM
WisM WisM is offline
John
Mein Auto: 2000 M roadster
First- Very cool. Congrats!
Second - Are you able to check the wiring under the seats? Seems like under the seats or another part of the seats electrical system could have fallen victim to your rodent friends given the other issues.
If it helps you any for tracking down that possibility, as mentioned the Bentley manual is a must. You can also check here:
http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
By the way, love the area around York/ Rock Hill. I have lots of relatives there.
Old 12-04-2012, 07:01 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I would remove the seats, I suspect rodent chewed wires.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-04-2012, 09:46 AM
ghpup ghpup is offline
Glfbggy
Mein Auto: 07 X3si, 00 528, 00 MZ3
Originally Posted by mhopper View Post
The body and paint are pretty good. There are a few hail dings, but nothing major.
You are a very foturnate man to locate it. I would have to say, as long as the engine doesn't need to be replaced, you will be way ahead in the game. You did mention hail damage though. Was this a salvage title car due to hail?
Regardless, you'll enjoy the drive.
GLFBGGY
'00 MRoadster, '00 528, '07X3si
Old 12-04-2012, 10:52 AM
Bimmer1995318ti's Avatar
Bimmer1995318ti Bimmer1995318ti is offline
Mein Auto: 1995 bimmer 318ti
Wow so jealous man ! Have fun with it ! An good luck with fixing it up! Shouldn't be anything to drastic !
Old 12-04-2012, 11:22 AM
Thanks!,,, those diagrams are great!!!
