E36 (1991 - 1999)
Old 11-19-2012, 12:52 AM
Statust Statust is offline
Mein Auto: 325i
Pouring antifreeze into a 1992 325i
What is the proper way of pouring some antifreeze into my car? Becuase when I pour it and the car is off, then when I turn it on it always gets air and then I have to bleed it,
So what would be the best way to.pour it into my car? With the car turned on and the bleeding screw unscrewed just a lil or with the bleeding screw tight on and just the regular radiarder cap off? While the car on?
Old 11-19-2012, 04:06 PM
john kaminski john kaminski is online now
Mein Auto: 1994 325i
Unless the expansion tank is empty you should be able to add antifreeze to the expansion tank. Don't add it to the radiator when just topping up.
Cheap Trick
Old 11-19-2012, 04:14 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Car cold: Top up the reservoir to the full line, run the car to circulate the coolant for a minute and continue adding fluid to maintain fill line. Bleed the system. From now on as long as you don't let the reservoir get completely empty you can open the reservoir any time you need to add coolant.
If you need to bleed every time you fill coolant you're either letting it get completely empty and suck air in or you've never completely bled it to begin with.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 11-19-2012, 04:17 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
What? How would you add coolant to the radiator via the radiator in the first place? E36 radiators do not have caps to fill with - only the expansion tank does. Also, it doesn't make a difference if the expansion tank is empty or not. How do you think people fill their cooling systems with coolant after they've replaced everything during a comprehensive overhaul? Hint: they just install everything and pour coolant into the empty expansion tank, which then fills the radiator, etc.
Regardless, you can add coolant with the engine on or off, but I certainly recommend doing it with the engine off and cool so you don't risk burning yourself with hot coolant and/or steam. If you're getting air in your system, it is not due to adding coolant to the expansion tank with the engine off. You must have other issues, which I'm presuming is why you have to add coolant to your car in the first place.
1998 BMW 328is
1966 Pontiac GTO
Old 11-19-2012, 11:28 PM
Mein Auto: 325i
Well no its just winter is gettin close and I need to dump my water out and put antifreeze, well im doing it ryte now and I just turned on the car and my freken heater doesnt work no more!!! Like it was just working and now it doeant!!!!!
Old 11-19-2012, 11:29 PM
Mein Auto: 325i
What do u guys think happend??
Old 11-19-2012, 11:33 PM
ZeGerman's Avatar
Warm Leatherette
Dear god... I gather that you are not aware of the fact that you are not supposed to run straight water in your cooling system for a number of reasons.
Based on what I've read, you need your car to be maintained by a trained professional, not by you.
1998 BMW 328is
1966 Pontiac GTO
Old 11-19-2012, 11:34 PM
I Am The Machine
Whaaaa? Doesn't matter what season, you need to have 50/50 distilled water and coolant. Period.
Heater probably isn't working due to air bubbles.
// Chad //
You're a derbanana
Old 11-19-2012, 11:42 PM
Mein Auto: 325i
I only had a lil bit of water in it u ****en idiot I had it becuase a specialist told me to pour water instead of antifreeze so I dnt waste it when I bleed it, my car already had this problem and I fixed it, I.just poured out the water two days ago and put new antifreeze, before this my car was fine and didnt heat up, it just started heating up, Im just gona bleed it again till I get it
Old 11-19-2012, 11:47 PM
I Am The Machine
Cool it, if I'm spending MY time to come on here and help YOU, what business do you have to act like a prick? If you're so smart and I'm a "f*cken" (sic) idiot, you shouldn't be asking for help, eh smart guy?
// Chad //
You're a derbanana
Old 11-19-2012, 11:48 PM
BustedE36 BustedE36 is offline
E36 ///M3 Clone 328iS
Mein Auto: E36 M3 Clone 328iS
That "Specialist" you speak off should be fired if he told you to run straight water, or straight antifreeze..read up on your car online to get all the correct info, heres a tip as well dont bad mouth the people posting to help your dumba**...
Old 11-19-2012, 11:53 PM
Mein Auto: 325i
No not u bro, I appreciate ur words and help, but im talking bout zgerman.
Old 11-19-2012, 11:55 PM
Mein Auto: 325i
Well if hes ment to be fired idk but he told me that,
Old 11-19-2012, 11:58 PM
I Am The Machine
Same deal. We're on here to help you, he's extremely knowledgeable. We can be abrasive at times but that's the way it is. You'll do well to be polite to the people that know what they're talking about, or you can kiss your opportunities at getting help goodbye.
How have you been bleeding the system? Front raised up high?
// Chad //
You're a derbanana
Old 11-20-2012, 12:02 AM
Mein Auto: 325i
Well when I talked to the specialist he told me to loosen the little bleeding screw until there was no more bubbles, to turn it on after each time I unscrewed and bibbles would come out, and turn on the °car again for about 5-7 minutes and turn the heater on blast, but now my heater doesnt turn on lol and it was just on haha
Old 11-20-2012, 12:03 AM
I Am The Machine
Was the car on an incline with the front up high?
// Chad //
You're a derbanana
Old 11-20-2012, 12:04 AM
Some mechanics think they know everything..until they have really got to know a BMW...i would just trust forums and internet help sites like pellican.
ZeGerman's Avatar
Warm Leatherette
This guy... Don't act so butthurt. How, oh wise one, could anyone possibly deduce that you had only added "a lil bit" of water from the following statement?
And if you only added "a lil bit" of water, keep in mind that 50% of your cooling system's capacity is supposed to be distilled water.
1998 BMW 328is
1966 Pontiac GTO
Old 11-20-2012, 12:05 AM
Mein Auto: 325i
No it was not, it was just on a regular road u know.
Old 11-20-2012, 12:08 AM
Mein Auto: 325i
Dude f off dnt want ur help
Old 11-20-2012, 12:10 AM
I Am The Machine
Needs to be front up high, and follow the instructions in my first post about adding while the engine is cold and running. And yes, heater should be on full blast during this.
// Chad //
You're a derbanana
Old 11-20-2012, 12:15 AM
Mein Auto: 325i
Ok so I put it on ramps ryte?
Ok sounds good? But what am I gona do about my heater it doesnt work member?
Old 11-20-2012, 12:18 AM
I Am The Machine
Define doesn't work. Does air blow but it isn't hot? Or nothing blows at all on any setting? And yes, on ramps.
// Chad //
You're a derbanana
Old 11-20-2012, 12:23 AM
Mein Auto: 325i
Yah it doesnt blow nothing at all nor hot or cold.
Old 11-20-2012, 12:30 AM
if no air is blowing at all, odds are you blew a fuse..but if it is sometimes blowing hot or not at all you got air into your system and need to drain it all....including the drain plug on the side of the block which holds a fair amount of coolant....usually people jack up the front, but goodluck with ramps i know i cant drive up onto ramps and i have stock springs.
