E36 (1991 - 1999)
#26
Ok sounds dumb but where is the fuse for the heater? Which one is it? And ok yah think ill just drain the whole thing
#27
do you still have the top to your fuse box? it should have a diagram showing what fuse is for what component.
Yah I think I should have it ill check tomorpw thanks for the help
#29
Enough help here already-- I'll only add that these cars are a beotch to bleed. Whenever I work on the cooling system I carry a gallon of water around with me for a week before I get the thing bled fully. And, that's with letting the farfegnugen screw bleed coolant everywhere, squeezing hoses, raising idle, raising front end-- maybe I just have a goofy car.
![]() Good luck with the attitude- regardless. You're not defining things well enough for ppl to help without being smart a$$ at the same time. I'm a REAL smart a$$- I'm just in a jolly mood right now on some pain killers from an accident
It's not what you buy, it's what you build- Unknown EN90283 - Stabled for HG repair DH06247 - Running like a champ |
#30
Ok i just turned on my car and its still on the ramps, turned it on at 5:32pm & till now I see no increase of heating, but my heater still does not throw air out. In the morning I turned it on and still no air throwing, turmed it off, then I turned it on again like 1 minute later and still no air throwing but then all of a sudden it just starts throwing air again and I turn it off nd try turning it on and again no air throwing. Any ideas?
#32
Well thank God it's not just mine! Sometimes my wife drives mine, and I learned QUICK-- Not until at least a week after I've done anything to the coolant system!
One day I'm going to do the euro reservoir mod just because I'm tired of hassling about with it.
#33
Possibly final stage unit going bad.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
#34
I'm seriously gonna try to help, but I have problems with assumptions.
1. what is turned on (no jokes please) 2. what is throwing air I don't know if you have a blower motor problem, or a coolant bleeding problem, so I'm going to suggest the following: 1. Put car in park, ign in position 2. 2. Actuate blower control from lowest to highest fan setting- do you hear or feel ANYTHING? Is it moving air? Is the HVAC blower working? IF not, fuse, resistor etc. 3. I don't know what year your car is (not in profile), so I cant give you advice on the panel control, or whether potentially it's just a resistor, or a fuse. Fuses generally blow for a reason, so don't get too excited if there's one blown. 4. OP referenced where the fuses are-- near firewall driver's side under plastic cover. Table is there-- if yours is gone, reply and I'll bust out my Bentley manual-- not going outside, it's cold. Regardless, a good visual check will reveal if fuses are obviously blown-- but that will not take into account hidden corrosion (which I have seen personally prevent a circuit from closing). As a course of habit, I will remove the fuse, test it, or replace with a known-good fuse after verifying contacts (above AND below) are clean of any corrosion. 5. report back ![]() But, my money's on the FSU
It's not what you buy, it's what you build- Unknown EN90283 - Stabled for HG repair DH06247 - Running like a champ Last edited by mgoods50; 11-20-2012 at 06:14 PM. |
#35
Mgood, here's the answers to a few of your questions:
Year is in the thread title Quote:
#36
Ok took my car for a spin, turned it on at 5:32, had it parked on ramps till 5:47pm-still no increase of heating up, 5:48pm took it for a spin till 6:05pm still no increase of heat but as I was driving I can feel heat very slow coming out of the vents, so some air is now starting to come out but not alot , u can feel it if u press ur hand agains the vents, so the air isnt coming out with alot of pressure, but yah now it started to throw lil lil hot air on level 4 of the heating settings, my car is 1992 325i 4 door sedan
#37
OM-G I just saw your quote "Not all quotes you see on the internet are genuine. -Abraham Lincoln"![]() -sorry- i'm VERY ADD-- I'm betting that darn blower resistor then. Especially since its a '92-- got a lot of service out of it- more than most! Here's a link- don't bother with a used one- not worth the trouble. I've tested a few now and then, sometimes they partially work, sometimes not. http://www.pelicanparts.com/bmw/tech...r_Resistor.htm Easy fix. Be warned-- this thing will be HOT if the HVAC controls are on.
#38
![]() fahreelzyo.... df
What lol? what u meen?
#40
wachoo meen, wachoo meen?? snap, yo, ah be gittin all up in thiz biz an yo punk head gotsta be all like 'wachoomeen n stuffz, so whatevz, yo, i be splittin this place anywayz cuz dats how i rollz, foreelz...![]() out df
Ladies & gentlemen, buckle your seatbelts, we gon' have a wild ride. Sent from my LG Revolution 4G using BimmerApp
#42
i b str8 now, yo...we good. ![]() df
