Where are my ccv hoses?? - Bimmerfest - BMW Forums
Old 11-14-2012, 01:46 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Question Where are my ccv hoses??
I just realized my car doesn't have hoses coming from the ccv on either side of the motor. I don't believe it is supposed to be like that. Any input?
Old 11-14-2012, 02:15 PM
mrbmwx5 mrbmwx5 is offline
Banned
Mein Auto: 06 750Li
In that case you just have the caps( some came with hoses and some doesn't)
Old 11-14-2012, 03:29 PM
samadkins29's Avatar
samadkins29 samadkins29 is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i
Non turbo cars will just have CCV vents. No hoses attached.
Old 11-14-2012, 04:20 PM
That's probably what it is. Thanks!
Old 11-14-2012, 07:43 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
edit: Never mind i see what youre saying, some cars have hoses come from their CCV's and some don't, I wonder why they changed it
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 11-15-2012, 11:17 AM
It has the nipples for the hoses but none there. That's why I wasn't sure
Old 11-15-2012, 04:01 PM
I might have to edit my original statement. The ones with nipples (connectors) are the old style. That was modified to the new style, that still has the vent but its just more integrated into the plastics so you dont notice it as much (nothing sticking out).
Old 11-15-2012, 04:35 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
New ones dont have nipples, looks the same just no nipples..
Old 11-20-2012, 09:20 AM
7forty5er 7forty5er is offline
Mein Auto: BMW 745I
Has anyone changed their air pump hoses? The ones that go connected to the CCV valves and air pump? I was changing my CCV and broke one of the hoses. I called the dealer and they said it was 2 hoses. On mine it looks like it's just 1 that connects to the CCV valves and 1 to the air pump and 1 to the engine. Total 4 connections. Please help
Old 11-20-2012, 03:34 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Are you referring to the secondary air pump? they dont connect to the CCV?
Early versions have a hose assembly that fits to each CCV valve on the top of the rocker covers and are joined together and connect to two ports on top and below of the throttle body on the inlet manifold.
Later version use two individual insulated hoses
If your referring to the secondary air pump, the hoses go to two metal valves at the rear of the cylinder heads, they are not called CCV's.
Stuart
Old 11-25-2012, 10:07 AM
Mein Auto: BMW 745I
im not sure if it's the secondary. I replaced the CCV and broke 1 of the brittle hoses. Now I need to replace. It looks like it's 1hose with 4 connections?
