Magnaflow Cats question - Bimmerfest - BMW Forums
Old 11-20-2012, 04:17 AM
HBomb B3 HBomb B3 is offline
Mein Auto: BMW 540i
Hi guys. I need to replace my cats. I live in Massachusetts. Does anyone know which cats work (model number) with my 1998 540i? I've read different posts, and are not sure which are the right ones. Thanks!
Old 11-20-2012, 10:07 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Try the Magnaflow web site and get a recommendation. http://www.magnaflow.com/02catalytic...ayproducts.asp
I installed a pair of the CA cats. Very pleased with the construction and increased throttle response. Replace all four sensors at the same time.
http://www.realoem.com/bmw/showparts...00&hg=18&fg=10
If you choose to replace with direct fit units, you'll need eight items 4 and 5, and four item 3. You may need other parts, depending on how many parts you break removing them. Mine did require a small adjustment to fit, so you may just want to buy the weld-in units.
