Old 10-03-2010, 09:33 PM
starrock starrock is offline
Mein Auto: e39
wow, really?
Old 09-03-2011, 05:57 PM
For the cross-linked record, today, JimLev provided nice aux fan test info:
- E39 (1997 - 2003) > Aux Fan Help
Originally Posted by JimLev View Post
The fan is controlled by the dual temp switch on the side of the radiator and the HVAC system.
Stage 1 is low speed from the HVAC panel or the 91 deg switch on the radiator and relay K21.
Stage 2 is controlled by the AC high pressure switch and relay K22.
Stage 3 (high) is controlled by the 104 C deg switch on the side of the radiator and relay K201, which gets power from fuse F75 (50 amp) behind the glove box. F20 and F105 powers K201.
You said the fan comes on when you turn the AC on so Stage 1 (low) is working which means the 2 resistors are good.
Pull the connector off the dual temp switch and jump it to see if you can get.
Jumping pins 1 to 2 should make it run at high speed and pins 1 to 3 for low speed.
Old 08-03-2012, 09:57 PM
For the crosslinked record, QSilver7 posted some nice aux fan information over here today:
-> E39 (1997 - 2003) > please explain!!!
Originally Posted by QSilver7 View Post
It depends on which engine you have...in your case...it's the M52TU...
Old 11-18-2012, 11:24 PM
akillies akillies is offline
99 540i Make Over
Mein Auto: 99 540i
I'm having a problem with my aux fan too. My aux turns on and goes off but when it kicks on it makes a very loud noise and sounds like it is straining and the car doesn't over heat. Does anyone have any idea what it could be or what I should do???
Old 11-20-2012, 10:00 AM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Mine did that just before it died, mine would turn on, but would stay on the highest fan speed setting. Sounds ridiculously loud right? The cheapest OEM fan i've found is from ecstuning, or just get a used one for cheap.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 11-20-2012, 03:56 PM
99 540i Make Over
Mein Auto: 99 540i
Ok, can I replace the motor itself to maybe save some money??
Old 04-15-2013, 05:05 AM
For the crosslinked record, JimLev offers good advice here for discerning aux fan types:
Did your fan motor look like this with these color wires coming out of it?
If so, you have a PWM fan.
The older fans are 3 speed that only have 2 wires ans use relays and resistors to switch speeds.
The resistors are mounted to the fan frame.
See also:
- DIY for how to replace the auxiliary fan (1) (2) (3) & how to test the cooling system auxiliary electrical fan (1) (2) & the infamous fuse 75 (1) & the aux fan relay (1) & an exploding aux fan noise situation (1)
Old 08-27-2013, 03:37 AM
For the crosslinked record, a screenshot from the Bentley on the aux fan operation is here today:
Originally Posted by Burning2nd View Post
Me7.2
See also:
- How to test the cooling system auxiliary electrical aux fan (1) (2) (3) (4)
Old 09-17-2013, 10:10 PM
For the record, this is good information added recently:
If the temp gauge gets up to 3/4'ers the fan should be on high speed! Which is stage 3. There are no resistors in the circuit for high speed.
You could have blown fuses, bad relays, or the aux fan motor itself could be bad.
You could also have bad resistors or a bad temp switch in the side of the radiator, best to have someone trouble shoot and find out what parts are bad unless you just want to throw parts at it.
Here's the circuit for the 3 speeds. Ignore the notes, they were from helping another person.
See also:
> E39 (1997 - 2003) > E39 Auxiliary Fan DIY write up-With Pics.
Old 05-06-2015, 09:50 PM
There is a good aux fan discussion today over here:
> E39 (1997 - 2003) > Over heating
See also:
- How to test the cooling system auxiliary electrical fan (1) & a DIY how to replace the aux fan (1) & where is the auxiliary fan fuse F75 (1) & where is the aux fan relay (1) & an exploding aux fan noise situation (1) & what is the o-ring size for the coolant temperature aux fan thermoswitch (1)
Old 07-21-2015, 08:17 AM
emack23 emack23 is offline
Mein Auto: 1998 BMW 528i
Does the Aux fan make your car over heat
Old 07-21-2015, 08:27 AM
Jicafold Jicafold is offline
Mein Auto: 2002 540i
Heck no. It keeps your car from overheating. It's a fan. Although I'm not so sure how accurate that statement is either. It mostly helps the AC condenser. My fan didn't work for a year until I replaced the fuse, but I was never stuck in a traffic jam in the summer either.
Old 07-21-2015, 09:39 AM
My car over heated I towed it to my mechanic after a couple days he called and said my aux fan needed to be replaced because it wasn't pushing hot air out while my AC was on and he said the coolant was boiling in the radiator and that's what caused my hose to blow off as well. The hose to the thermostat housing blew off
Old 07-21-2015, 11:54 AM
My car over heated on the highway so I pulled over immediately. Opened the hood and saw that the bottom hose of the thermostat housing came off. I towed it back to my house called my mechanic he told me that there was air in the system. I took the steps to get the air out. I turned the car on and let it idle the needle went to the middle then went a tad bit over the middle and went back. It did this a couple times. Then it started to go over to the HOT area really fast I turned off the car then I see steam coming out. I opened the hood and saw that the hose blew off again. I tow it the next day to my mechanic he did a pressure test and everything was fine. He let the car cool off for the day and the next day called me and told me that the AUX fan wasn't working and this is what caused it to over heat. Mind you, while I was letting it idle I had the heater on and it was bleeping hot air then I turned the AC on. I'm thinking that's why it over heated and blew the hose off again???? Pls let me know what everyone thinks! Thank you
Old 07-21-2015, 12:25 PM
Dio///M's Avatar
Dio///M Dio///M is offline
Mein Auto: E36 M3(euro),E39,E46
As far as the Aux fan is concerned it's very easy for a mechanic to determine if it's working properly or not, I had overheating issues a few months ago on my E39 and it turned out to be a tiny leack /side crack on the radiator. Water was being running off. A couple of months later when it got hot the Aux fan ceased after working unexpected for a couple of weeks in a row...New fan and that was the end of that although to be fair it was a 15 year old original fan and summers in Cyprus are 35 -41 Celsius for days in a row.
Old 07-21-2015, 12:29 PM
Dio///M's Avatar
...sometimes some overlook simple but important things as well like for example using bmw grade coolant mixture... It makes a difference as Bmw's are very specific in the quality of parts used
Old 07-21-2015, 03:54 PM
Can I start using the BMW coolant if I have a different one in there now?
Old 07-21-2015, 09:36 PM
Dio///M's Avatar
Yes, but at some point have it drained from the system and refill with the oem coolant, it prevents scaling and better cooling.
Old 10-11-2015, 09:19 AM
GlynDanks GlynDanks is offline
Mein Auto: 2003 E39 Sport
Hi,my aux fan was not working when i bought the car (crafty seller had the climate control set so it wasn't noticeable),after struggling with the cooling system "dumping" hot air into the cabin even in our mild English temps. i decided to get it fixed and purchased a aux fan from ebay which i thought was new but i'm not too sure now because although it works okay- after a few months the fan blades seemed to be catching on the mesh part of the shroud(if i open the hood ! the noise stops but starts again after its closed, if i ease the bonnet up it goes away)I assumed that something had moved but my mechanic says its the bearing thats worn and the blades are out of line,anybody else had this problem ?Thanks Glyn.
Old 10-11-2015, 09:56 AM
777-300ER 777-300ER is offline
Just call me 777.
Mein Auto: 2003 BMW 540i M-Sport
Make your own thread. Please.
'03 540i ///M-Sport
Topaz Blue / Grey 6MT
September '02
Dynavin N6, Umnitza ICE LED Angel Eyes, Euro Armrest, Bridgestone Potenza S-04's.
Old 10-11-2015, 09:59 AM
Sorry only been on here about 48 hours.
