E36 (1991 - 1999)
#1676
Lol
Sent from my ADR6400L using Bimmer App |
#1677
makes me wonder what a cam'd M52 would do with only 10 pounds
Depends on the turbo Ken.
Here are the vids, looks really slow though, blah. ![]() Sent from my ADR6400L using Bimmer App Last edited by FenderBender; 11-06-2012 at 06:33 PM. |
#1679
Nice! Yeah, it does look slow on camera, but I bet it sure felt a lot faster behind the wheel. Even though you were in the low 13s, you've got an easy 12-second car, which I consider to be quick for a street car.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
#1681
![]() made me dizzy....but i dig very much. with some tires and a bit of reaction time training you could be quite fast. i thought that you had an f1 set up for the clutch, tho... ![]() df
F1 stage two, installed before I did any turbo stuff. IIRC correctly it's rated for 360 lbs of torque or so. I'm making plenty more than that at 20-22 psi.
#1684
One or the other lol.
I tried to slip the clutch and keep the turbo spooling off the line on my last run and that's when it really died. I did do 20 something runs and the car had ZERO issues other than the clutch. Motor and turbo kit will be removed soon and sold for new turbo parts. Sent from my ADR6400L using Bimmer App |
#1685
-CJ
#1686
Turbo, injectors, tune, MAF, wastegate, bov, intercooler, exhaust, piping, couplers, Tranny, clutch.
Nuttin really lol. Sent from my ADR6400L using Bimmer App |
#1687
Why don't you sell the motor with the turbo bolted to it?
New turbo top mount? Still trying to find a 6sp? Sent from my Desire HD using Bimmer App
nothing.
#1688
It's just an M50 with oil leaks and a leaking hg and S50 cams lol. Nobody wants that.
I want 6 speed meow so I can drop it in together. Yes top mount turbo. Sent from my ADR6400L using Bimmer App |
#1689
Help?
Ive been reading through all of this and I'm new to turbos. I still havent decided whether I want to turbo an M50 or an M20 engine. I like the M50's much better. I have a question about what i need to physically run the turbo system. I understand the hardware, but as far as tuning, can I get a chip to plug into the DME (OBD I) and then I'm set to go? I don't know how that controls spark advance/retard and fuel. Do I need to get a piggyback ECM or do I need a complete new ECM? Also, For a turbo controller, what does that even mean/ Ive tried doing research, and even on noob forums im a bit lost. Any good books to read on the topic? Im looking at one now called "Performance Fuel Injection Systems" by Matt Cramer/Jerry Hoffmann. Its mainly for V8 systems, and everything is specific to them.
Thanks in advance. SICK car man. Very well done. |
#1690
I don't know much about the M20s so I can't help you there.
Yes, if you are OBDI you just plop a chip in your factory computer. Easy as that. You'll want gauges to monitor things to make sure the tune is pretty close. As far as tuning you have many options. TRM Technica Technique tuning Miller Nick G Roadkill tuning Dunno about books, but I am looking to get into tuning sooner rather than later and I need to start reading up myself. Thanks! |
#1691
just make sure that the tuning books you are reading up on are in regarding engine management, not pianos...
![]() ![]() df
Evo shifter, DSSR, and clutch are here.
![]() ![]() ![]() ![]() You can see I have the updated flywheel with the machine work already done. Of course, it came with no instructions (the clutch) or torque measurements. |
#1693
105 ft/lbs on the flywheel and 25 on the PP.
Or so I've read! You should double check.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
#1694
![]() Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
#1695
![]() matt, that flywheel is awesomesauce!! never saw anything like it!! essplain me...naowh!!! btw, reading this makes me salivate all over again....this sort of thread *really* makes me pause at what i really want to do with the ti....turbo m52 w/cams, or small block swappy... ![]() luckily, i haz plenty of time.... df
Thanks df!
Uuc twin disk feramic. They haven't been out long. There are people running them with 1000 (way higher than what I'll be aiming for) Sent from my SCH-I605 using Bimmer App |
#1697
No real updates, still need to get the 6 speed sorted out.
In the mean time, I put my shifter together. ![]() ![]() ![]() ![]()
#1698
It's backwards. The shift lever should lean towards the pointed end of the shift arm.
#1699
It swivels :}
#1700
Indeed.
| Tags |
| :3 |
