Old 11-18-2012, 09:07 AM
hyper_x3 hyper_x3 is offline
Mein Auto: 2005 E83 X3 2.5i
Burn smell x3 2.5i
I have noticed that when i roll down the windows and accelerate heavily, there is a burn smell that appears (fire works smell). I am not sure where its coming from and it only appears when i full throttle it or heavily accelerate. Any one has this problem or knows the solution?
Old 11-18-2012, 09:23 AM
alpinweiss alpinweiss is online now
Mein Auto: E46, E83, E90 (all MT)
Could you give us a bit more information on your X3?
1. What is the year model?
2. How many miles (kilometers) on the odometer?
3. Is it manual or automatic transmission?
4. Have you had any recent repair work done on your X3?
5. Is there any unusual noise when you accelerate and have the burning smell?
Hello, and welcome to Bimmerfest!
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25 (missing third pedal)
BMW CCA member
Old 11-18-2012, 09:26 AM
its a 2005 automatic. Has 147,000km. no mechanical repairs and no sounds. just smell.
Old 11-18-2012, 10:10 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
I would guess its a leaking valve cover gasket. Oil may be leaking out and burning. Look for oil on the passanger side if the valve cover.
Old 11-18-2012, 11:05 AM
To the OP: If your valve cover gasket set has never been replaced, it is overdue. It will now be hard and brittle. The set includes the valve cover gasket plus the seals that go around the spark plugs. This will cause a burning oil smell, if it is leaking. You may also want to replace your spark plugs as a part of this job.
Since you mentioned the smell is present only when you accelerate, I wonder if there may be something driveline-related. Have you had the fluids changed on the transfer case and both differentials? The transfer case is especially critical. Follow this link:
http://www.bimmerfest.com/forums/sho...d.php?t=463848
It is a bit hard to diagnose a smell by long distance, but I hope this helps on your problem.
Alpinwei▀
BMW CCA member
Old 11-18-2012, 10:24 PM
thank you very much for your help. I haven't changed the cover neither the spark plugs. I will check with the diferential oil. I hope this solves my problem thank you againg.
Sent from my GT-I9300 using Bimmer App
Old 11-18-2012, 10:25 PM
thank you for your help, I will see if that solves my problem.
Old 11-20-2012, 08:18 PM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is online now
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
I would guess its a leaking valve cover gasket. Oil may be leaking out and burning. Look for oil on the passenger side if the valve cover.
X2 on the Valve Cover Gasket!
At that mileage, you need to get serious on catching up on maintenance!
-All fluids (Transfer case, transmission, both differentials)
-Valve Cover Gasket
-Spark Plugs
-02 sensors
-Fuel Filter
-Air Filter
-Brake fluid flush
-Coolant flush
-Power steering fluid flush
-Shocks and struts must be screaming for help too!
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
2.5i, burn, e83, x3
