E34 (1989 - 1995)
Old 11-19-2012, 04:44 PM
ZakM ZakM is offline
Mein Auto: E34 535i
Injector Wiring Duct
Hey guys, hoping you can help.
535i production date 10/92, Getting at the injector wires the frail brittle plastic has broken on this injector wiring housing duct. Now when the car goes over a bump it lifts up because the clip is broken and the one of the injectors is not firing. This box is located right on top of the fuel rail above the intake manifold. I have searched all OVER real oem, and there is nothing listed for this part, I cannot find a part number to order a replacement. I have attached an image below.
Old 11-19-2012, 05:48 PM
Banned
Mein Auto: car
Could you post a few very close up shots in good light ?
Old 11-20-2012, 12:42 AM
BMWFatherFigure's Avatar
Old School
What a stunning engine! I wish mine looked like that.
Current:
E38 Parts Car
Previous:
Old 11-20-2012, 11:10 PM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
Hard to find brand new. BEtter to check your local junkyard.
The injector wiring duct should have some square 'C' shaped clips that hold the injector plug onto the injector connector. If those are absent then that can cause your problem. Maybe all you need is the little metal square 'C' clip.
You sure the clips are all there?
