#26
Wow. Lot's of good information in your response!
I'm sorry for being confused. Can we replace 'just' that thinner vacuum-leak-related o-ring without removing the fuel injector itself? Or, do we have to remove the fuel injector - which would then necessitate replacing both the thin (air leak) and fat (liquid leak) o-rings? Should we add this filter to the VERY best of E39 Links list of items to periodically clean? - Maintenance checklist of filters and components to be periodically checked & cleaned in the BMW E39 (1) Quote:
I researched the witchhunter $120 service about a year ago over in post #42 here: - Techron Concentrate Plus is fixing my fuel gauge Quote:
See above report from and below marketing blurb from the aforementioned Techron thread: Quote:
#27
Why would you do that (replace only 1 O-ring)? Once the injector is removed, you can access both O-rings. I would not do a 1/2 job. Also, the "rebuilding" of an injector consists of:
-replacing both O-rings -replacing the filter (it's on the top, you could remove it, but you can also destroy the injector if you don't know how - some people advise removing it with a wood screw, and I am against: chance to destroy the injector are too big) -cleaning and re-calibrating the injector. The report we got from our injector cleaning facility is similar to one you posted, only in more detail. The downtime for any customer at that specific facility is 1 day max. which is reasonable (here in Calgary). One can book an appointment, bring them in in the morning and pick them up in the afternoon. Also, FYI, if you bring the car to the dealership for Service II, cleaning of injectors & engine is included in this. It's a chemical cleaning performed with something similar to Techron I think (Lubro-Moly chemicals). How do I know? I had it performed on my car in 2008. They also tell you NOT to fill up until you almost empty the tank.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
#28
I don't know. I'm asking you!
![]() My 'thought' was that I was only trying to identify & resolve 'vacuum leaks' (I don't have a fuel leak); so if I only wanted to solve a vacuum problem, I'd only replace the vacuum o-ring. At least that's the 'why' for asking the question. If it makes no sense to just replace one o-ring, then I guess, the procedure is this: a) Do the water-and-the-straw trick to identify a vacuum leak at the thin FI o-ring. b) If you 'do' have a vacuum leak, then replace BOTH o-rings Does that sound reasonable as your recommended procedure? |
#29
I would service the injectors @ 100k miles by replacing both O-rings, and have them cleaned at a licensed facility (mechanical cleaning, re-calibrating & new filters). The ensuing report will also tell you IF there is any injector beyond repair.
If you have no driveability issue, there is no sense opening everything up only for curiosity sake, or doing a half job. You can mess up more things then doing any good. 0.02
#30
I have early morning misfire codes (lots and lots of 'em) all due to lean conditions. - Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (1) The driveability is fine when warm; lousy when cold. BTW, with these codes: P1083 BMW 202, Fuel Control Limit Mixture Too Lean (Bank 1 Sensor 1) P1085 BMW 203, Fuel Control Limit Mixture Too Lean (Bank 2 Sensor 1) Given: Quote:
#31
Doru, thanks for putting this together. I'm currently under going the surgery but diy'ing the cleaning by letting it soak in carb cleaner (berrymans b12) over night. I will pulse it but only to let some solution through it in reverse. I bought the injector rebuild kit from Mr Injector on eBay for $25. THis is probably my last attempt at solving my probs before I give up on my own googling and the Indy and take it into BMW.
I've got a strange one which is BMW 235 & 236. Both banks too rich. The P1092 & p1093 paint a different picture however as that translates to Bank 2 is rich AND lean. Go figure! Bluebee - does John treat you to dinner and Babysit for you? Because you really are THE most valuable member of this forum. I have yet to see anyone as dedicated and as good at what you're doing on any other forum. Keep up the good work, we all really appreciate it!
2002 Sterling Gray M5 'nuff said |
#32
Each person contributes depending on their strengths - and the other team members make up for their weaknesses. My strength is NOT in knowledge (I know less about everything than anyone until/unless I have the problem myself). My strength is in documentation. Everyone else contributes in knowledge. It works because we work together as a team! |
#33
Yes, Jon Shafer is the Bimmerfest founder. Really good guy!
#34
Confirmed - the injectors were faulty
It's confirmed that my old injectors were faulty.
This morning it was very cold. The original injectors would start leaking at this temperature, and I would have that raw fuel smell in the cabin about 3-4 minutes after driving. No more of that and I am soooo happy!!!! Expensive but very easy repair.
#35
Great to hear this has worked out well for you--did the job fix the fuel mileage problem you were also working towards?--I know I have asked this before, but back then it was too early to tell.
#36
Runs normal, is all I can say. Hope it stays that way and I don't jinx it.
#37
From the "other" forum, a very good piece of information:
"Thanks for all the posts, and sorry for my delayed response...Snow storm and no power for the last 5 days. I let the car sit over night with everything together and vuala...no leaking...but i think it was the lack of lube lol...I had mine rebuilt because i was troubleshooting a misfire, that turned out to be a blown valve. I had a report taken, all of injectors have a 22% flow obstruction, and one was 35% @ wide open throttle...The guy said, anything over 10% could cause misfire and poor performance and rough idle. and now after the rebuild, no obstruction of flow, and the car runs better than when i bought it. 140k miles ago." Here is the post
#38
Replacing 6 injectors is going to cost someone about $600.
Not a cheap DIY, so this is one I would not do just for the sake of doing (without codes and problems) Last edited by EconoBox; 03-31-2012 at 06:36 AM. |
#39
Agreed, but, well, I had issues.
#40
How common is an injector failure?
If you had to put a mileage on it, when would you replace them as prev.maint? It's a $600 DIY, so what's the final word on simply cleaning your injectors? Better bang for the buck? |
#41
It looks like the 3 liter M54 OEM injectors have issues, and in cold weather only, you will see this happening. They leak somwhere at the mid-body. It's a manufacturing defect. The new Siemens ones are OK (or so I heard). If you don't have problems, don't do it. If you smell raw fuel in the cabin a few minutes after a cold startup in cold weather (the temp has to be below -20°C - this is below -4°F), and if you open the hood you see a big cloud of fuel vapors coming out from the fuel rail, that's it. You need new injectors, no if's and why's. The car can catch-on fire anytime.
#42
http://www.bimmerfest.com/forums/sho...274&highlight= I recommend going with brand new Siemens injectors. Yes, you will pay more, and save your self the head aches (no kidding with the gas fumes) of having to replace remanufactured a dozen times. See this thread for my experience. http://www.bimmerfest.com/forums/sho...067&highlight=
MorrisRoad Last edited by morrisroad; 04-16-2012 at 06:24 AM. |
#43
You can buy Siemens injectors online. Pelican Parts has been a good online supplier for me. But there are a few others.
MorrisRoad |
#45
Sent from my SGH-T679 using Bimmer App
#46
Thanks guys, I am sending Mr. Injector an email right now. I have a 2001 325 xi sedan bmw. Real oem says my car is a M54 engine. http://realoem.com/bmw/select.do?vin=EE78757. These Bosch type 3 will fit my BMW right?
The product number for these new guys are 13537546245. The ones that realoem pulls up for my cars vin is 13537546244 (I assume these are the Bosch type 2). Because I'm living in a cold state, it was the OP's recommendation to get the newer Type 3 ones. Just out of curiosity, where did this information come from? That the newer type was better for the cold? Thanks guys! I need to resolve this quickly because I really dont want my car to catch on fire in the morning. |
#47
#48
When ordering the o-rings for the fuel injectors, consider the following also:
- What is the complete list of o-rings to order for routine oil change maintenance tasks (1)
#49
For the record, this was asked today:
#50
If it's a "solid state" injector - it's no problem. The leak is developing at the O-ring level.
If it's a 2 part injector (like the Siemens for the M54), you have to assess the situation: It can leak at the O-rings, or the injector is toast and leaks where the 2 parts mate - like in my case. There's nothing you can do about that. You need new injector(s).
