Old 03-04-2011, 05:19 PM
kdubinwa kdubinwa is offline
Mein Auto: 2011 X5 35d & 535iX order
Glove Box Stuck Closed?
After emptying the contents of the glovebox on my 2011 X5 I closed the glovebox. When I returned to store my owners mannual I can't open the glovebox. I hear a definate "click" when I press the release button but the clamshell style doors don't open now?? Is there a reset? I need the emergency release cable secret!
Thanks for any help found here...
Old 03-04-2011, 09:11 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
"The emergency unlocking mechanism can be accessed from the front passenger's side.
Only the instrument-panel cover needs to be opened here. Behind this cover is a loop,
which, when pulled, unlocks and opens the glovebox."
http://www.bmwmotorsports.org/pdf/e7...20Glovebox.pdf
Page 10
Old 03-04-2011, 10:53 PM
Page 10
Thanks Penguin!
Now I'm looking at the diagram and stuck on how to "open the instrument panel cover".
I removed the panel underneath the glovebox and above the passenger footwell and no emergency unlocking mechanism is in sight. I can then access a couple of screws holding the main dash panel but that is a huge piece all accross the dash and I'm not thinking that is what they are referring to??? No way can I pry that up without hunting down all the fasteners accross the dash. From the picture it looks like the emergency loop should be hanging on the right hand side at about the same height of the box. I see no way to get near that w/o having the whole dash come off.
What am I missing here?
Old 03-05-2011, 12:17 AM
rattmann rattmann is offline
Mein Auto: 2011 TURBO X5 35i
It is from the door side on side of the dash
Old 03-05-2011, 07:13 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Why not swing by the dealer and let them do it for you? The door will have to be fixed anyway since it is under warranty. That way there will be no question that in some way you caused the problem.
Old 03-05-2011, 08:18 AM
In my area, service appointments are 3-4 days out. I just thought if there was a simple procedure then why not give it a try...
Old 03-05-2011, 08:20 AM
That's what the diagram shows, but I see no screws or any way to remove the end of the dash cover on the pasenger side. Does it pop off with push connectors?
Old 03-06-2011, 09:00 AM
In most cases something like this can be fixed (or the door opened) by a driveway visit to the dealer. Then, make the appointment for a permanent fix at a later time. When you start opening up and unscrewing things then it might cost you later. Just a thought.
Old 11-22-2012, 05:02 AM
reDDevil reDDevil is offline
Mein Auto: X6
Tell me please where is located "instrument-panel cover" to find emergency unlocking mechanism
http://www.static.estore-central.com...cymta2x3a=.jpg
(number 16)
I opened "Lateral trim panel" from the door side on side of the dash as recommended rattmann but I could not find a loop there.
http://wds.spaghetticoder.org/zi_ima..._FB6107050.png
P.S. I have X6 (E71). Glovebox should be the same as E70's
Page 10
_sl_
Old 11-22-2012, 06:27 AM
smyles smyles is offline
Mein Auto: X5
Blown fuse. Replace it (10A). If you don't have a spare, "borrrow" another to just open the glove box. There's recent post on xoutpost with pictures.
Old 04-13-2013, 06:09 PM
tonyscv tonyscv is offline
Mein Auto: 2014 M5
It's this pic:
"The fuse box is located underneath the passenger dash. There are three screws that you will to need to remove that will reveal the fuse box. After you remove the panel look up and to the right and you will see a panel (on the right hand side) with a green screw. Unscrew this and it will reveal the fuse panel. The fuse that I replaced was the mini 10 fuse in the below pic. I tired different type SMD LED bulbs and it kept popping the fuse. So I ended just putting the stock one back in."
Thanks to PCGRUR2K for figuring this out.
Additionally, this fuse panel tilts down when you loosen the green screw - it does not pull forward - it's very awkward to get to. There is a fuse removal tool in the fuse panel in the back liftgate fuse box if you need one.
Old 05-28-2013, 07:38 AM
Joe.Bertrani Joe.Bertrani is offline
Joe.Bertrani
Mein Auto: 2013 BMW X5 MPackage
Originally Posted by kdubinwa View Post
Thanks Penguin!
Hi, I have the same problem was you able to access that loop? I am having a world of trouble locating this loop?? Please help lol...
Thanks in advance
Joe.B
Old 02-22-2016, 12:10 PM
sewchand sewchand is offline
Mein Auto:
Which is the fuse.
Old 02-22-2016, 02:07 PM
bmwx5er's Avatar
bmwx5er bmwx5er is offline
Mein Auto: '12 X5 50i, '14 m235i MR
Originally Posted by sewchand View Post
Which is the fuse.
check fuse # 10
Old 02-22-2016, 02:10 PM
Mein Auto:
Ok thanks I will . Do you know the amp.
Old 02-22-2016, 02:13 PM
bmwx5er's Avatar
not at the top of my head. could be 10A.
The fuse diagram is located in a folded up sheet in the rear fuse box location in the trunk. Check your owners manual, it should be pretty easy to get to.
Old 02-22-2016, 02:15 PM
Mein Auto:
Ok the #10 and a 10A.
Old 02-22-2016, 02:16 PM
Mein Auto:
It screw up my light in the box also
Old 02-22-2016, 02:17 PM
bmwx5er's Avatar
looks like its 5A
http://www.bimmerfest.com/forums/att...9&d=1372018911
But, PLEASE check the fuse diagram sheet in your car.
Old 02-22-2016, 02:22 PM
Mein Auto:
Yes the image show 5 amp . Can I put 15 amp?
Old 02-22-2016, 02:24 PM
bmwx5er's Avatar
why? it's 5A for a reason..
Old 02-22-2016, 02:27 PM
Mein Auto:
Okay I don't have 5A.
Old 02-22-2016, 02:28 PM
Mein Auto:
It's the same fuse control the glove box and the light in it?
Old 02-22-2016, 02:30 PM
Doug Huffman's Avatar
Nuclear engineer
Mein Auto: 2012 Feb 11 X5 35d (E70)
See the description in post #2
Post hoc ergo propter hoc is a weak logic akin to arguing from ignorance, "I don't know, but ..." Better to be silent and thought a fool than to babble and remove all doubt.
Old 02-22-2016, 02:35 PM
bmwx5er's Avatar
Can't help you here. Any auto parts store should carry it.
