Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 11-21-2012, 12:16 PM
robertmspeakout robertmspeakout is offline
Mein Auto: 2007 525i
Tensioner pulley very loose (video)
Today after starting my car, I got a charge malfunction error and my power steering would not work on my 2007 525i. I looked under the hood and the serpentine belt was hanging. After getting into it, I noticed the tensioner pulley (or at least that's what I assume it is) is very wobbly and loose. However, I can't see a way to get the darn thing off to inspect it or how to tighten it back up. I've searched all over and can't find anything specific to an e60. Any help would be greatly appreciated.
Here's a video:
Also, does anyone know where I can find a serpentine belt diagram for anE60? I've found them for nearly every other model but an E60 for some reason.
Old 11-21-2012, 02:11 PM
pcy pcy is offline
That is definitely the belt tensioner. There is a bolt at the center of that belt tensioner assembly (not the center of pulley) to remove the tensioner assembly from timing cover.
Here is the picture showing how the belt is routed.
Old 11-21-2012, 03:11 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z3 2.8L, 545i
You video shows the bolt in the center of the spring that is the issue. Since I recently changed mine, what I see as the problem is you are missing the steel washer that goes under the bolt. Basically your hex bolt head is slipping into the shaft. You can look around your bottom pan for the washer or get a new one. There is probably nothing wrong with the tensioner itself.
My guess is the bolt came loose or someone had taken it off before and never properly installed the washer.
Old 11-21-2012, 03:12 PM
Interesting...you wouldn't happen to have a size or picture that I could work off of to possibly go grab a washer and see what happens?
Old 11-21-2012, 03:14 PM
Also, after re-routing the belt and starting the car, here's what happens to the belt on the tensioner...
Old 11-21-2012, 03:28 PM
pcy pcy is offline
I've replaced belt tensioner on N52. I don't remember removing or installing a washer on the tensioner assembly bolt. See the attached ...
Old 11-21-2012, 03:30 PM
pcy pcy is offline
Remove the belt, try tightening the center bolt on the tensioner and then put back the belt.
Old 11-21-2012, 03:31 PM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
The head of the bolt that is supposed to hold the tensioner in place has broken off from the rest of the bolt. You need #5 in this picture.
http://www.realoem.com/bmw/showparts...40&hg=11&fg=18
it's hard to tell from the video what is interfering with you being able to remove the tensioner assembly, but you might have to remove something else or maybe just try rotating the tensioner assembly to find the sweet spot to remove it. Worst case - you have to get a pair of vice grips or bolt extractor onto that bolt to remove that portion of it before you can remove the tensioner.
Inspect the tensioner carefully before reinstalling. i'd say there's a good chance that broken bolt is a symptom of something else, like maybe the bearing in the pulley seizing? Also, I think that's an aluminum bolt, which should never be reused for this exact reason - it weakens. To your knowledge, has that tenioner ever been removed and reinstalled?
Old 11-21-2012, 04:07 PM
To my knowledge the tensioner has never been removed.
Old 11-21-2012, 06:16 PM
[Update] I was actually able to tap a small flat head into a sharp corner of what was left over on the bolt and get it to turn enough to get some needle nose on them. I got it off. However, I was able to more fully see the small crease that is in the top right of the tensioner caused by the belt coming from the alternator to the right of it. Surely this is too close for comfort???
After further investigation, the bolt has in fact sheared off. There is not enough of the bolt left over to place any grip on. I'm not sure how to proceed to get the tensioner off.
Old 11-21-2012, 07:09 PM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
You could use a Dremel to cut a slot in the bolt shank. If you have to cut through the tensioner too, no biggie - replacements probably aren't too pricey.
Old 11-21-2012, 08:28 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
If its a soft metal a easyout reverse bit and penetrating oil might work.
Old 11-22-2012, 08:59 AM
Hogie's Avatar
With a new tensioner the new bolt and washer come with it. You can not run your engine without the tensioner.
Order one from www.autohausAZ.com
It will come with the new bolt and washer already installed. The other posts are correct, that the bolt head has sheared off, therefore lost the washer.
