Guide to replace Crankcase vent valve? - Bimmerfest - BMW Forums
Old 11-19-2012, 06:01 AM
Allies_X3 Allies_X3 is offline
BMW Rookie
Mein Auto: 2013 BMW X1 xDrive 28i
Hi Fest-ers!
I have scoured the Internets for a few hours now seeking out how to replace the crankcase valve vent. I have found a couple things for other BMW models, but not the X3. Any pointers?
Background:
My SES light illuminated on Saturday with no symptoms. While leaving the store on Sunday, my car shot out some white smoke from the tail pipe and idled roughly. The ODB codes were the System Too Lean errors, and the guy at the local tire shop thought it was just O2 sensors. Of course, when I started doing my research I found this:
http://chrisparente.com/Images/530/CCV-SIB110803.pdf
I live in Baltimore, so it isn't like Alberta, Canada cold. The symptoms match, and I had an oil stand leak that the mechanic fixed about seven months ago. My oil light comes on way more frequently than my husband's (he owns the same exact year/model, and we drive about the same distance), so maybe this has been an ongoing problem?
Anyway, any recs you X3ers can offer I'd appreciate. It doesn't seem (ha!) like it's that hard to replace.
Thanks in advance!
Allie
Allie
-=My Garage=-
2013 BMW X1 xDrive 28i, Premium Pkg, Cold Weather pkg, and Tech Pkg
2006 BMW X3 3.0i, Premium Pkg, Xenons, Cold weather pkg, Nav - RETIRED
2006 BMW X3 3.0i, Cold weather pkg, Nav
2000 Jeep Cherokee Sport
"Well behaved women rarely make history." - Lauren Thatcher Ulrich
Old 11-19-2012, 06:45 AM
BMW Rookie
Should have googled more carefully; BavAuto has a great guide
http://blog.bavauto.com/8003/diy-vid...lation-system/
Allie
-=My Garage=-
Old 11-19-2012, 06:52 AM
BMW Rookie
Looks a little too in-depth for me to do alone, so off to the shop I go. FWIW, dealer quoted me $1,180, and the local non-dealer bimmer shop said $330. Quite a difference, and I'm skeptical, but we'll see. Off to the shop; report back shortly.
Allie
-=My Garage=-
Old 11-19-2012, 07:34 AM
rdc8118 rdc8118 is offline
Mein Auto: 2008 X3 sport
I've done it on my 2003 530 with the M54 engine. The same engine in your x3. It was a pain in the butt to do but doable.
If you go to this link the ccv is #1 in the picture.
http://www.realoem.com/bmw/showparts...94&hg=11&fg=15
When i did mine I replaced all the associated hoses. They were brittle and the plastic connectors broke easily.
Old 11-19-2012, 08:17 AM
BMW Rookie
Yeah, I got halfway through the second bavauto video and thought this was a bit too much of a challenge. I like to get my hands dirty, but I've never been elbows-deep in an engine before
I wanted to watch them work on it, but they seem pretty busy today so I'll let them work in peace
Allie
-=My Garage=-
Old 11-19-2012, 10:06 AM
sflowers539 sflowers539 is offline
Mein Auto: 05' X3
Funny you post this now, I just had mine replaced last week with the valve cover gasket, after all the same symptoms, and have seen this pop up here more recently so maybe it is a common problem with age. I cost me about $1,000 at a indy shop for both repairs. So if a indy shop quoted you $330 it might be realistic. The parts were cheap for both repairs, but there were about 7 or 8 hours in labor, that is where the cost was. So if you are mechanically inclined you can probably do it yourself and save money, but if you just have the one issue, and can get it fixed for $330, that might be easier.
Old 11-19-2012, 12:53 PM
BMW Rookie
The guy quoted me $330 P&L over the phone and then when I got there and confirmed it was the CVV, the price jumped to $600.
I'm not surprised and I figured it would take about a half a day to do the work, so I gave them the okay to do it. I just hate it when mechanics misquote for this stuff.
I've taken it to this shop twice and this is the second time this has happened (one quote on the phone, another quote when you get there for the same work you were quoted over the phone). I figured the first time was a communication issue, but this is pretty cut and dry. I won't be going back to that shop again.
Kind of a bummer, honestly, but definitely still got a better price than the dealer ($1180).
Allie
-=My Garage=-
Old 11-22-2012, 11:56 AM
LRM403 LRM403 is offline
Mein Auto: 2006 X3 3.0
Hi Allie I am a new member I am having the exact problem as you now. What was the solution to your problem?
Old 11-22-2012, 01:23 PM
BMW Rookie
I ended up having the crankcase vent valve replaced. There is a video on bavauto if you want to DIY. I got it fixed at an Indy shop for 600 p&l. The parts aren't the expensive part for this, it was four hours of labor that drove the cost up. Make sure you get the cold weather replacement if you're up north.
Allie
-=My Garage=-
BMW Rookie
The link for bavauto is up higher onthe thread if you want it
Allie
-=My Garage=-
Old 11-23-2012, 12:12 AM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
600 parts and labor seems pretty normal, I think I paid right at 500 at a the only european specialty shop in Lawton OK lol.....
Old 12-06-2012, 07:11 AM
Hi Allie you were right! Thanks alot, I took m truck to a shop in Padonia, MD it was the crank case valve my car is running great. I went ahead and changed the spark plugs, 2 cylinders air filter brought from dealer, wasn't expensive. The labor was 4hrs which cost me a total of $700.00
Old 12-06-2012, 07:49 AM
BMW Rookie
Nice! Glad it worked out for you. Did you get the cold weather replacement that BMW came out with after the original was found to fail in cold weather? I am also in Maryland; which shop did you take it to?
Allie
-=My Garage=-
Old 12-06-2012, 09:56 AM
No I need to call about about that. What does the cold weather package include? I went to Brookman Motors off Padonia Road, they work on BMW's for Towson. How much did the cold weather package cost? If the original failed, shouldn't that be something covered such as a recall?
Old 12-06-2012, 10:00 AM
BMW Rookie
It's the same price or within $10. The "cold weather" replacement just has some insulation around it so the cold doesn't cause it to crack as easily.
As for a recall, there isn't one. I guess they consider this normal wear and tear.
Allie
-=My Garage=-
Old 12-06-2012, 10:43 AM
I am a little confused, I need to look that up, I never heard of that, and where does this go? Is it around the crank case valve?
Old 12-06-2012, 10:50 AM
BMW Rookie
The insulation goes around the hoses; see the image under CORRECTION on this link:
includes part numbers.
If they replaced it with the original OEM part, I am not sure I'd worry much about it (unless you spend a lot of time northward). Even then... it took six years to crack, so it's probable that you won't own the car when it fails again (if it does).
Nothing to really be that concerned about, IMO.
Allie
-=My Garage=-
Old 12-06-2012, 10:55 AM
Thks alot......
Old 12-06-2012, 03:07 PM
awdrev awdrev is offline
Mein Auto: 2004 BMW X3 3.0 Auto Tran
This is all great information... what shop did you guys used in MD? I'm in Silver Spring and would love to have a shop to go to that's not dealer priced...
Old 12-06-2012, 06:11 PM
I went to Brookman Motors in Timonium (410)666-0800 off of York Road. A old friend of mine use to work there he was good, unfortuantely he passed. However Mark is excellent, Joe will answer the phone. The are all pleasant. Good Luck!
Old 12-06-2012, 06:16 PM
Thanks, it's a solid hour from me but if the service is great and the prices are good. Business is business! I'll tell them I was referred by another BMW owner too!
Old 12-06-2012, 06:19 PM
your welcome
Old 09-28-2013, 12:14 PM
CapsLock911 CapsLock911 is offline
Mein Auto: X3
Allies X3 - Bavarian doesn't have information for the E83, 2007 BW X3 cvv or pcv. I've got my auto apart, and cannot locate the pcv that FCP listed as fitting my vehicle. I'm scratching my head right now. Any ideas / info would help if you have it.
Old 09-29-2013, 05:54 AM
x3brian x3brian is offline
Mein Auto: X3
The ccv referenced in this thread is for pre 07 models with the m54 motor. You have an 07 with the newer n52 motor that does not have this ccv and hoses/associated issues. It uses a different way to vent the crankcase.
Old 09-29-2013, 06:58 AM
Mein Auto: X3
x3briann - thanks. i did alot if reading again yesterday and this morning. i do have th n52. i've got seroius idle issues in neutral and while driving. the engine is skipping like a school girl on recess. i'm now trying to figure out where to start - and i will be selling a new, out of package cvv kit! do you know anything about the N52? my new obd is on the way and my auto is in pieces in the garage. riding the triumph is getting chilly in cleveland ohio, and i am needing to solve the problem. i read the control system is under the valve cover, but cant find any answers yet. any additional info will be greatly appreciated. thanks again! sorry for the lack of caps and any mis-spellings. im on my phone and managing those things with such a small screen is hard for an old man...lol
