E30 Build Thread - Page 3 - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 11-14-2012, 03:22 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Pressed in a new passenger ball joint today, I think I'm going to get one for the other side too, has a wee bit of play in the wheel. The passenger side had a ton of play.
I think I'm going to purchase these as well, thoughts?
http://www.ebay.com/itm/84-85-BMW-31...4b900b&vxp=mtr
Can't figure out the high and wompy idle either. I cannot find any vac leaks using the spray carb cleaner technique. Not sure what else it could be other than injectors.
Turbo Build Here
Old 11-14-2012, 10:53 PM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
My 318 had started that after I cleaned the icv. I think the spray killed it
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 11-15-2012, 04:07 AM
Needs Boost
Mein Auto: Red Sled
Hm interesting. I ordered those injectors. Maybe I need an icv.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 11-15-2012, 04:02 PM
Needs Boost
Mein Auto: Red Sled
Almost ready to put the interior together:
Applied bed liner to the driver's side after a clean and vacuum
Cleaned the used carpet I bought
Then used black spray paint (don't hate)
I put on a LOT of coats. Between them I would brush the carpet to make it a little softer and make sure everything was covered. I'm going to do another coat or two tomorrow when it's nice and completely dry. We'll see how it turns out.
Cleaned the door cards
Then used Duplicolor fabric dye in flat black
Should have it all done this weekend.
Turbo Build Here
Old 11-19-2012, 03:49 PM
Needs Boost
Mein Auto: Red Sled
Got a couple of things done today. First, started putting the interior back together, have the windows all wired up now (weren't before) and mostly everything done. I'm also trying to fix the leak around the fuel pump assembly, if I fill it up the whole way it spews out. I put a new o ring in and I'll fill it up tomorrow and see what happens.
Front of the interior is mostly done, needs a cleaning now for sure. I'd also like to redo the seats sometime, ideas? Products? Experience?
Again, low quality low light pictures.
Check out my new gas pedal yo, been driving it without one at all for the last month! lol
Injectors showed up, look very very nice. All new O rings and the like, not bad for 68 bucks shipped total.
Runs GREAT!! No miss at all, climbs all the way to redline. I figured something was up with the injectors, the rest of the fuel system is new (soft lines, filter, pump, pressure regulator) as is the spark plugs, wire, cap, and rotor. I also used up 3/4 ish of a tank and only got 94 miles. One or more of them were stuck open for sure. One other thing to note is the the injectors tested perfectly with a multimeter.
Now the only problem is idle, there is no miss anymore but it isn't quite right. Bumps up and down sometimes, and is always high (1500rpm if not more)
I cleaned the ICV but maybe I killed it in the process? Like I said I don't think there are any Vac leaks but who knows.
Turbo Build Here
Old 11-20-2012, 03:57 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Prob a vac leak or the ICV like you said.
Old 11-20-2012, 09:29 AM
Needs Boost
Mein Auto: Red Sled
How can I remove the Iac to check other things? I heard something about a penny with a hole in it?
Turbo Build Here
Old 11-21-2012, 05:12 AM
On Top
That's just a way to reduce the air volume and manually tame the idle. It will never work right and may cause the dme to make adjust fuel trims and make it run worse after adaptation. I would just unplug it to see if it functions it should spin and make a buzzing sound when running.
Check the engine for a large vacuum leak, smoke test is a great method to locate problem areas. While it may be the IACV, I would start with the basics.
Old 11-23-2012, 02:46 PM
Needs Boost
Mein Auto: Red Sled
Where/how could I do this smoke test?
Turbo Build Here
Old 11-23-2012, 03:21 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
well, first, you get the funny papers from the corner gas station. next, acquire some...oh, wait...not *that* kind of smoke test...
sorta like the smoke machine the dj's would use back in the day. pressurized with nitrogen, pumped into the intake. about 1psi is all it takes to fill the system, and then you look for the leaks.
any emissions shop would be able to do it.
df
Old 11-24-2012, 03:13 AM
On Top
df
Or for the folks in CA,WA and CO.
Remove mech fan and shroud
Fire up blunt
Fire up engine
blow smoke at motor and watch where it sucks the smoke.
Non smokers can replace blunt with an incense stick also.
Old 11-26-2012, 07:01 PM
BmwMan92's Avatar
I <3 my E34
^^^^hahahahahahahaha
Brandon
Old 11-27-2012, 12:28 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Lightbulb
I want to see the look on my customers face when they see under Workshop material:
1 Cohiba
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 11-27-2012, 06:13 AM
On Top
1 Cohiba
It would likely resemble something like this
The perks of being a tech.
Old 11-28-2012, 02:23 PM
Needs Boost
Mein Auto: Red Sled
Haven't fiddled with the surging yet, but I do have a mostly finished interior pic and such.
Turbo Build Here
Old 11-28-2012, 02:40 PM
hornhospital's Avatar
D'oh, You Kids!
Leatherique would do wonders for those seats. Probably fix everything but that worn-through bolster.
Looking good, none-the-less.
Quotes to live by:
BMW-CCA #441426
Old 11-28-2012, 02:51 PM
Needs Boost
Mein Auto: Red Sled
Thanks Ken. Is that a brand of leather conditioner or something better?
Turbo Build Here
Old 11-28-2012, 02:55 PM
D'oh, You Kids!
It's a whole system of restoration and preservation products and dyes.
http://www.leatherique.com/
Quotes to live by:
BMW-CCA #441426
Old 01-03-2013, 03:41 PM
Needs Boost
Mein Auto: Red Sled
Late Christmas present from the GF!
Also, bought an IAC, should be here tomorrow, hopefully that takes care of the idle issue.
Turbo Build Here
Old 01-04-2013, 04:39 PM
Needs Boost
Mein Auto: Red Sled
New IAC, idle is definitely better, some cases it's perfect, then other times it still bounces up and down. Does the computer have to adjust?
When I first fired it up it sounded no different. Then after probably 2 minutes the idle came down to 700 ish and sounded pretty good. Next time I fired it up it did the same thing. Then when I got home I let it idle and it didn't come down, stayed around 1000rpm and bounced slightly. Again later I fired it up and it came down to 700ish again and sounded good. Thoughts?
Also, my buddy said it smells pretty rich. Injectors are new as well as FPR, etc. Could it be the cold start injector sticking or would the IAC effect that?
Turbo Build Here
Old 01-04-2013, 04:48 PM
D'oh, You Kids!
More likely the engine temp sensor is marginal. That's what tells the ECU where to set the IAC and also sets the fuel map for the engine temp. If it fails to sense the engine is warmed up, it continues to pour more fuel to the engine and runs the IAC in warm-up mode. The temp sensor is test-able, but I don't have the figures in front of me. The E30 Bentley has the info you need.
Quotes to live by:
BMW-CCA #441426
Old 01-04-2013, 04:53 PM
Needs Boost
Mein Auto: Red Sled
Which sensor? Because I replaced one of the coolant temp sensors.
Turbo Build Here
Old 01-04-2013, 06:22 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
The temp switch that Is being mentioned is located closest to the FPR and closet to the valve cover (yellowish looking) here are the resistance values:
14 +/- 2 degrees F: 7000-11600 ohms
68 +/- 2 degrees F: 2100-2900 ohms
176 +/- 2 degrees F: 270-400 ohms
Old 01-04-2013, 06:26 PM
Needs Boost
Mein Auto: Red Sled
Replaced it. I do have a rad leak and have to fill every few days, maybe the coolant isn't fully reaching / pressurizing enough to get a good reading?
Sent from my SCH-I605 using Bimmer App
Turbo Build Here
Old 01-04-2013, 06:27 PM
First time's Avatar
This temp switch switches a ground circuit for the timing and idle control.
Oh forgot here is the test procedure:
-Disconnect the white wire(s) from the switch
-check for continuity between the switch terminal corresponding to the white wire and ground
-at coolant temps below 86 F there should be no continuity
-coolant temps above 118F there should be continuity (switch closed)
Any faults or values out of spec should be addressed by replacing sensor.
