Old 11-20-2012, 06:32 PM
Keith3679 Keith3679 is offline
Mein Auto: 2012 BMW X5 xDrive35i
2012 BMW X5 Moonroof will not close properly
Watch the video below...
I've been having this issue with my 2012 BMW X5 moonroof, primarily with the cold weather. It did this last winter, was fine all summer, then yesterday it acted up again.
Ive read some posts that a re-init fixes this issue? Can anybody confirm? Should I cancel my service appt with the dealer next week?
Keith
Old 11-20-2012, 09:36 PM
ard ard is online now
Resident Curmudgeon
Keith
Absolutely not. Get the failure ON RECORD. In fact, I'd make sure the SA confirms it doesnt close right and you get that in the work order. (Many times the work order says "C/S blah, blah" and the response doesnt confirm a failure....You want 'improper operation confirmed by M. Service Advisor" added to the work order.)
Just being thorough...
A
Old 11-23-2012, 02:30 PM
clinkinfo clinkinfo is offline
Mein Auto: x3,x5
A
I agree, this is a huge known issue with the roof (search on bmw pano roof problems) and generally very expensive to fix out of warranty. Get it on record.
Old 11-23-2012, 06:43 PM
SDBounty SDBounty is offline
Mein Auto: 2008 X5
I had the same issue after getting my X5 back a couple of weeks ago. They adjusted the roof because of some noise and i got it back having the issue u are seeing. Caught on vid too.
My post "X5 woes" tells the issues with my roof that now is in BMW's hands, a week of my car sitting in the shop. It seems its a can of worms and now they need to replace the rails? Is that a big job and what can happen when they do that? Oh well, just document often is my lesson.
Old 04-07-2013, 11:49 AM
sunnyj sunnyj is offline
Mein Auto: Mercedes
Hello Keith3679. I am having exactly the same problem with my sunroof, it started acting up today. How did you manage to sort your sunroof out.
Regards
Sunny
Old 04-07-2013, 12:46 PM
blue dragon blue dragon is offline
Mein Auto: X5 35D
Wow, talk about coincidence. Mine started to do the same thing today. First nice day out (17C), and I decided to use the tilt, now it will not close properly, its doing the same thing as yours
| ZCW | ZPP | ZPS | ZRC | ZSP | ZTP | 322 | 2VA | 456 | 4AD | 4UB | 610 | 655 | 6FF | 6FL | Combox + CIC retro |
Old 04-08-2013, 07:23 AM
yungkim78 yungkim78 is offline
Mein Auto: '12 X5 35i SA
Subscribed. Not a car expert so or give me for not using technical terms. Last time this happened wouldn't close from the tilted position no matter what I did. Examined the exterior of the sunroof and noticed the rubber seal bordering the glass was raised at two spots (approximate location of the spots were in between the two glass panes. Gotta go in for my first oil change here shortly so hopefully I'll be able to get smart on the issue before I have a nice long talk with the SA.
