Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 11-24-2012, 12:13 AM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Smile Oil Filter Housing Gasket - Replacement (M54)
Refer to the PDF and if anyone has any problem with the file, let me know and I will post it again. This DIY is for 2004 525i with M54 engine.
File Type: pdf DIY - Oil Filter Housing Gasket Replacement.pdf (1.66 MB, 7654 views)
Old 11-26-2012, 07:33 PM
langstisthebb langstisthebb is offline
Mein Auto: 535i
Very helpful! I was able to follow these steps and successfully complete the oil filter housing gasket replacement. Do you happen to have any instructions on replacing the heat exchange gasket? This is also leaking.
Old 11-28-2012, 04:10 PM
kskane's Avatar
From DownUnder
I'm afraid I don't, as I don't even know where is the heat exchange gasket? Are you referring to the cylinder head cover gasket?
Old 04-30-2013, 03:13 PM
aa240sx's Avatar
aa240sx aa240sx is offline
Mein Auto: 2001 BMW 530I
Thanks for the DIY. Planning to tackle this along with the VANOS. Is there an RTV Sealant used along with the gasket? Or is it simply,
1 remove old gasket (scrape)
2 clean area for new gasket
3 install new gasket
- 2008 R350 Mercedes Wagon
- 2003 M3 Coupe - Alpine SMG
- 2001 530i - 5 speed, Anthracite Metallic, Sport Package
Old 05-14-2013, 07:18 PM
kskane's Avatar
From DownUnder
No RTV sealant is needed for OFHG.
Old 06-11-2013, 11:07 PM
SmartSolution's Avatar
SmartSolution SmartSolution is offline
Mein Auto: BMW E39
Excellent DIY. When I did mine on my previous e39, I found that in removing alternator, spraying a bit of wd40 at the contact points to the engine block makes it come out nice and easy with no jerking necessary.
Old 06-12-2013, 12:24 AM
kskane's Avatar
From DownUnder
Thanks for letting us know, I will keep in mind for next time
Old 11-05-2013, 09:34 AM
mj888 mj888 is offline
Mein Auto: 2011 328I
nice diy... thanks.
Old 06-07-2014, 04:02 AM
grimma grimma is offline
Mein Auto: BMW E60 525i
One question , do you need to drain engine oil prior of this task?
Old 06-07-2014, 09:58 PM
BbradenMmillerW BbradenMmillerW is offline
Registered E39 User
Mein Auto: 2002 BMW 525i - Black e39
Slim Grim asks a good question...
Does anybody who has performed the OFHG R&R on m54 engine know if it's necessary to drain the oil? If so, is a typical drain from the oil pan plug legit enough?
Never done this job but am tomorrow. I have no idea how much oil is lost from removing, cleaning, etc... If the amount is negligible then that's that. But I could also see a drain & fill being possible.
2002 BMW 525i E39 w/ ZF Auto
"Change the way you look at things, and the things you look at begin to change." -Unknown
Old 06-14-2014, 04:52 AM
kskane's Avatar
From DownUnder
Hey boys, sorry for the late response, but I don't think you will loose any oil with this DIY as the all the oil sit in the pan at the bottom of the engine. I could be wrong, so to be on safe side, better drain the oil anyway. If you don't want to spend more and think the oil is good, use the old oil and topup with 1L if necessary.
Old 06-15-2014, 08:17 PM
jarhed1964 jarhed1964 is offline
Mein Auto: '99 528i Sport, '05 530i
You are pretty much spot on. Just pulled mine off of my 2005 530i. It's almost exactly the same as my two E39's, except that there are three bolts on the bottom of the housing that are connected to the power steering pump, in addition to the normal six bolts that you may be familiar with in an M52 or M52tu from an E39. Two up front and easy to reach, and one difficult one on the back rear. The pump literally mounts to the bottom of the housing. No oil lost other than the mess spilled all over the place when I pulled the housing out. Just open your oil filler cap so the oil will drain down from the filter housing. I'm doing an oil change anyway, so I drained the oil pan before I pulled the housing.
Old 12-26-2014, 04:44 PM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
I was following it just fine until I removed the 6 bolts---then I was like, this is way too much coming off compared to your DIY. Maybe I missed it, but with mine, removing those 6 bolts (all diff length), the power steering pump/assembly also comes loose/off (attached to OFH)?
I'm searching now, but man, not a good day to hit a snag. Also replacing CCV and bunch other stuff which I'm familiar with, but first time doing OFH. sigh.
Old 12-26-2014, 04:47 PM
Jarhed1964. Are you saying I have to remove 3 more bolts to separate the OFH from the power steering pump? If so, i would think a support is needed to keep pump and all the hoses from bending/falling?
UPDATE: I figured it out. I found another DIY that did mention the two PS bolts. :-) Man, OFH and CCV are a bear. But it was easier doing CCV with OFH. However, I've done CCV without doing the OFH. Having done both, yah, it's easier, but I'd still do the CCV alone if I had to do again (assuming OFH was ok).
Old 01-12-2015, 10:57 AM
fastforaslowguy fastforaslowguy is offline
Mein Auto: 530xi
My repair shop told me I needed to replace the bolts when doing the gasket swap - apparently the aluminum bolts they use are single-use and can snap off when re-torqued. Anyone else hear this? Sourcing those bolts is a PITA so far.
Old 01-12-2015, 10:58 AM
Had no issue re-using mine. Over a week and no leaking.
Old 01-12-2015, 01:17 PM
Mein Auto: BMW E39
+1
I think replacing the bolts may only apply to the earlier N52 engines. IIRC all bolts that are one time use are marked blue. On the M54 its ok to re-use the same bolts. I re-used on my previous E39 with no issues. My 04 just started leaking so I will be making the repair soon.
Old 02-24-2015, 04:37 PM
Bluehorse Bluehorse is offline
Mein Auto: 2014 X5 F15 35i
Appreciate your input re the following two questions:
1. Why do you need to jack up the car? Throughout the write up, it does not appear that you have to get beneath the car?
2. In my Bentley repair manual for M54 engine, the alternator is removed first, and only then the power steering pump is to be removed from the oil filter housing. This post however states to remove the power steering pump first? Would appreciate a picture of the power steering pump itself before and after the removal.
THANKS!
Old 02-26-2015, 05:00 AM
kskane's Avatar
From DownUnder
THANKS!
Hi there Bluehorse, I just happen to read this post and saw your questions. Here are the answers;
1. In order to get engine belt and AC belt, you need access to the car from below. Also, to get the power steering pump, you need the access from below. And step 1 and 2 of the write clearly shows to jack the car up.
2. On my car, when I did this DIY and wrote the guide, I had to remove the power steering pump which logically makes sense because you are not disconnecting any hoses, you are leaving the power steering pump as is. Since the power steering pump is bolted at the bottom of the alternator, you cannot remove the alternator without removing the power steering first.
Lastly, bentley books are good, but I have found that they have wrong information on them from time to time. Because most of the sections are copied from the previous model into the successor and only the updated new parts are correct. If you find this horse , then give it a go and see if you can remove the alternator without remove the power steering pump. If you get stuck, then follow my steps (provided you have the same car)
Old 02-27-2015, 01:08 PM
I have never removed the AC belt before. Do you unscrew to loosen the tensioner, or just turn it with a wrench and hold against its tension while using the other hand to remove the belt? Do you just release the wrench and the tensioner will spring back in place?
How do you find out the tightening torque of various bolts? Google it?
Plan to do it this weekend!
Old 02-27-2015, 11:05 PM
Hello, guys,
In urgent need for help. I started working on the car tonight and I am to remove the Accessory belt as next step.
1. Realized I don't have torx socket for the Accessory belt tensioner. Anybody knows its size? Is it metric? First photo shows the belt, tensioner and various pulleys, and second picture is the tensioner itself. I tried using a 6mm Hex bit and stripped the star shaped torx hole a bit (scared)
2. To remove the power steering pump, my Bentley manual asks to remove the power steering pulley as well as the alternator idler pulley, then remove the two bolts (of different lengths) behind the power steering pulley. Are these all necessary? I am to re-study the DIY instructions by the OP, but appreciate your quick input tonight!
3. On the bracket at the back of the power steering pump (3rd photo), it has one large bolt on the far back end of the bracket(away and higher from the pump) and two screws (probably torx, but I can't see directly to visually confirm) on the other end (closer to the pump). Do I remove the two screws or the single large bolt to free the pump? I assume I don't need remove all of these 3? What other bolts/screws I need to remove to free the power steering pump?
4. By the way, not sure if I broke it when lifting the cooling fan cowl, but the hose connector shown in the 4th photo leaks coolant when I wiggle it from beneath the car. Is this leak from wiggle when cold normal (i.e. leak will disappear when the coolant system is presurrized)? If needs fix, what part(s) need to be replaced - the connector itself, is there a gasket inside there, or the entire hose (made a few segments connected and sealed by metal bands? I will do some research soon, but your input will save time so I may fix all this weekend.
Thanks!
Old 02-27-2015, 11:07 PM
Sorry, pictures did not seem to have uploaded correctly. Here is the link to the album. Hope you can see them now (they are in reverse sequence of the questions asked above):
http://www.bimmerfest.com/forums/alb...?albumid=12571
Old 02-28-2015, 09:39 PM
Well, I figured it out and did the job today. Took about 6 hours including research.
My sequence is different from the OP. I had to remove the alternator BEFORE removing the power steering pump (vs. the OP's sequence is to loosen Power Steering pump's bolts first in step #10, and followed by Step #11 and #12). Only after removing the alternator, the two front bolts and one back bolt securing the power steering pump become fairly easy to access.
My alternator is hold in place by two bolts only, not three stated in OP's step #11.
I don't have to remove the "power steering pulley as well as the alternator idler pulley" suggested by my Bentley manual.
I disconnect the connector where coolant leaked if I wiggle the return hose by hand. There appears to be no o-ring, and no visible damage to the connector, hose (including both ends). Not sure how I can find out whether I should replace the coolant return hose or the rigid plastic piece it connects toward the ground and then into the cooler. Appreciate your insight here.
Old 03-31-2015, 01:05 PM
MUSCLEBOY's Avatar
MUSCLEBOY MUSCLEBOY is offline
Mein Auto: 528i
Is DIY applicable to 2000 528I?
Can this DIY also be used for a 2000 BMW 528I? How would you know if you need to change out this OFHG? Where would leaks be present or what is the key here?
Old 03-31-2015, 03:23 PM
How I know the leak - I am losing oil, and I know there is oil at the bottom undercover and oil pan. What is important is that I can tell the bottom of the oil filter housing was wet. For 2004 E60, it is far more likely that the oil filter housing gasket is leaking than the oil plan gasket (which is said to made of metal reinforced rubber).
And lastly, the indy shop told me so ;-)
The job I did stopped the leak. However, I think I still have some lead elsewhere. Trying to figuer out if it is oil pan gasket, or valve cover.
By the way, the loose connection (when cold) at the coolant hose (when wiggled by hand) is no an issue. I have driven 300 miles probably, and no loss of coolant observed.
