Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 11-23-2012, 02:37 PM
denticola denticola is offline
528xi
Mein Auto: 2008 BMW 528xi
Cold start screaching sound
I have a 2008 528xi (62k miles) manual transmission.
Very recently when temperature deeps below 37 degrees, engine won't start and I can hear screaching sound until I push the start/stop engine button to cut off electricity to crank the engine. I have to repeat 2 to 3 times and finally engine cranks and starts.
Problem just started this year, never happened before and I don't believe it's due to condition of the battery. Maybe an alternator?
Did anyone experienced similar incident in cold start?
Old 11-24-2012, 05:27 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Sounds like your starter is missing some teeth, or the flywheel. Or it could be the solenoid not pushing the starters teeth
up fast enough to catch the flywheel. Either way your starter should be looked at because its doing damage to the flywheel.
Repeatedly doing so can cause more damage. Get someone to look at it and diagnose further. I don't know what warranty
you have, but if you have CPO, that should be covered.
Check your mirrors as often as it takes for you to know where everyone is around you!
