Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 11-22-2012, 06:32 AM
VA525FREAK VA525FREAK is offline
Mein Auto: 2001 525i
Upgrade Time
My e39 lasted 207k miles, it was a good run but I am ready to upgrade. The transmission went out and I do not want to put all that money into it. I had a 2001 525i and now I am looking to get into a 530 or 535 in the year range of 2004 and above.
I am interested in the normal failures or headscratchers in these autos. For instance, the e39 is famous for the cooling system needing to be overhauled every 100k. I also had to replace all the pulleys and runners for the belt system. Not to mention leaking power steering and what seemed to be a constant struggle to find all oil leaks towards the end.
Are there any differences across years worth mentioning?
I am also a little puzzled why I am seeing many 545-550's for sale at relatively same price as some 530-535's. Any insight there?
Old 11-22-2012, 08:02 AM
b5rider b5rider is online now
Mein Auto: 535
My non-expert reply:
The things you should look for in a 535 are the fuel injectors and pump. These engines have a high pressure pump and apparently fragile injectors, so they seem to go out.
Just make sure it has been serviced regularly
The wagons have roof leaks that end up frying the electrics in the trunk
make sure you keep the drains in the track clear
There is also an oil leak at the front, top of the engine that is an easy fix
The 535 is the perfect balance of power and weight. The handling, in my opinion, is better due to the decreased weight over the front wheels.
You can easily tune the twin turbo engine to over 400hp.
Some reputable magazines have put the stock output closer to 340hp. BMW probably lowered the released number so as not to step on the previous M3s 333hp claims.
I have the 535 wagon and it is the BEST Grand Tourer I have ever owned. It is not a drag racer, but will take me to Vegas at 90 without blinking an angel eye.
Good luck
Old 11-24-2012, 09:26 AM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
FYI 5 series V8's are expensive to maintain/fix and most 545/550 usually have higher options packages which involve electronics which will and do fail and are expensive to fix the E60 is a more expensive car to deal with than the e39
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 11-24-2012, 10:28 AM
BickUW89's Avatar
BickUW89 BickUW89 is online now
Go Dawgs!
Mein Auto: E60 550i SP
YMMV
Now at 70,000 miles, my 550 has still had zero mechanical or electrical failures. By this point of ownership with my E39, I had already had several very expensive repairs (coolant system, driveline, front suspension, head gasket). The '08 550i V8 engine is just about bullet-proof if taken care of.
BMW Ergo Zoom
IMHO: E39 < E60 > F10
2011 F10 535xi (ED July 15, 2011)
2008 E60 550i (ED July 22, 2008)
2000 E39 540i (Retired)
Member BMWCCA #402733
