E36 (1991 - 1999)
Old 10-26-2011, 01:30 AM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
$50 camshaft upgrade solution for M50/M52 engines
Cheap camshaft upgrade solution for M50/M52 engines.
If you are on the budget and want to upgrade camshaft on your M50 engine, then there is a $50 solution to this.
Get intake camshaft from M54b30 engine. These are sold for cheap at E46 forums. People upgrade to ZHP cams all the time so their stock cams are on sale for $25 to $50.
Get the intake camshaft from 1992 M50 non vanos head and you will use it on the exhaust side. The timing tool block will not work, so before you remove your stock cam mark the points of the lobe peak location on the cam caps. You can find this at junk yards for $15 to $25.
Cam specs will be
Intake 240 duration 9.7 lift
Exhaust 240 duration 9.7 lift
Not as hot as S50/S52 cams but close enough(in my opinion S50/s52 cams are just too agressive for 2.5 and 2.8 L engines, they deliver more peak power but reduce power on low rpm)
For the intake cam you will need to get 96+ cam tray with lifters and caps, you can mod the M50 cam tray if you are realy cheap, M54 trays will work too. If you have the option of getting M54 intake camshaft sprocket with hardware, get it, it is lighter and better than M50/M52 intake sprocket hardware. Do not remove vanos gear from the cam, just shorten it down with the grinder 5mm. And cam tool will work with M54 intake cam.
This photo shows, M54b30 intake camshaft with hardware installed on the M50 head. M54 uses just one spring washer, it is made to reduce the vanos rattle and to tighten the vanos on/off thrust, similar to M52/S52 hardware but more simple and lighter.
Old 10-26-2011, 04:22 AM
LaCrosse540i6's Avatar
LaCrosse540i6 LaCrosse540i6 is offline
Smiling from gear to gear
Mein Auto: '03 540i M-sport
So ZHP cams would also be compatable for M50/M52's? Interesting.
Old 10-26-2011, 07:35 PM
CDirks's Avatar
CDirks CDirks is offline
Is a real boy
Mein Auto: White 1997 328i
I'm surprised more people didn't comment on this. Definitely interesting.
I'll keep it in mind. Thanks for posting.
Old 10-26-2011, 08:01 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Very nice. I'm glad somebody is willing to dig in and discover this kind of stuff.
-CJ
Old 10-26-2011, 08:53 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Hmm... I think I know what I'm doing for part of my turbo build...
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 10-26-2011, 09:52 PM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
Wow this looks awesome.
Thank you. This might work without vanos....
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 10-27-2011, 02:11 AM
rooster1986's Avatar
rooster1986 rooster1986 is offline
Mein Auto: 92 325i
Yes would this work for non vanos m50? Otherwise looks like ill be spending for a used s50 cam.
Primered Black 92' 325i. Ireland Engineering Header, Ireland Engineering Catback, TMS Underdrive pulleys, TMS chip, Bav auto fpr, Power Flow cai, Bav auto coil packs, Cool Carbon pads, Eiback springs, Bilstien Sport HD shocks/struts, 3.23 LSD, Understeer short shifter, 16'' Spal Fan, Goodridge Steel Brakelines, M3 Bumper, Black out grill, clear tails, M3 mirrors.
Old 10-27-2011, 04:10 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
diggin it.
just a question, though. what and where are you grinding othe vanos gear?? just the end (where it appears there used to be a torx bit??)
df
Old 07-21-2012, 06:12 PM
NMSDAD1 NMSDAD1 is offline
BMW Junkie
Mein Auto: 96 328I 99 328I
Very interested..
Could you post a video of this running?
Do you have any dyno numbers?
Old 11-23-2012, 04:01 PM
bosnianwog bosnianwog is offline
Mein Auto: 528i, 328is, 323i
So basically to get this to fit in my m52 i just have to grind down the m54 cam?
Old 11-24-2012, 09:46 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Cam specs will be
+ m54 rotating assembly
3.1 super stroke monster..
You have to remove 5mm from the business end.. (?)
Is this guesstimation.. or measurement?
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 11-24-2012, 01:47 PM
OrionsGate's Avatar
OrionsGate OrionsGate is offline
Forever Nerd!!
Mein Auto: 1995 325i
Nicely done, definitely interested in doing this when I get a chance.
1995 325i, 235K miles (yes!), 5sp, LSD, M3 cat back, halo projectors, H&R/Bilstein/etc. suspension overhaul, painted sideskirts...Oh now it's white...plasti-dip... snap.
Old 05-12-2013, 08:55 AM
jaguarx7 jaguarx7 is offline
DON'T PANIC
Send a message via AIM to jaguarx7
Mein Auto: 1994 325is
I'd like to know where to find one of these for $50, I've been looking for one for over a year and haven't found one for less than $350. I can find used M3 cams for less. Anyone know where I can find one for a decent price?
Cars are much more compact if you don't take them apart.
There is a theory which states that if anyone ever figures out how and why the universe came to exist it would instantly dissapear, and a less rational, more complicated one would replace it.
There is another theory which states that this has already happend...
Old 05-12-2013, 01:30 PM
ditoedt325 ditoedt325 is offline
Ragtopper
Mein Auto: 1995 325 i(c)
Thanks for the info
I thought e46 was more differenter.
Ragtopper
Old 07-30-2013, 03:22 PM
NZ NZ is offline
Mein Auto: E36 Race car
Hey, Im digging this old thread up as im keen on doing something like this.but....
I have a question about using 2 different cams.
Why would you not just use 2 non vanos cams? how come its an M54B30 intake and a M50nv intake cam?
The thread lists the duration and lift the same? doesn't that mean they ARE the same?
Would really be keen on some info on this.
thanks
Andrew
NZ
Old 07-30-2013, 05:12 PM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 96 318ti, 93 BMW 325IS
Non Vanos cam doesn't have the Vanos gear, which means no Vanos, which means bad.
Sent from my DROID2 GLOBAL using Bimmer App
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Old 07-30-2013, 05:16 PM
granlund granlund is offline
Mein Auto: -02 530 & -92 325is
You would be using the non-VANOS intake cam on the exhaust (which doesn't have VANOS) on the M50tu/M52.
Old 07-30-2013, 05:24 PM
I like pie.
I was responding to this question.
Old 07-31-2013, 10:39 AM
Alan777 Alan777 is offline
Mein Auto: 94 Mtechnic, 91 vette
I'd be curious about power gains and the powerband. After seeing s50 cams in an M50 I was severely disappointed.
Old 07-31-2013, 11:50 AM
SurreyBuddy SurreyBuddy is offline
Mein Auto: E36 320I
I don't want to be the guy that repeats the same question someone else has stated but; will this work on a non vanos m50 engine.
I understand non vanos is bad and i should sell my car but its not selling.
Old 07-31-2013, 01:51 PM
hornhospital's Avatar
D'oh, You Kids!
Non-Vanos isn't bad. It's only marginally less powerful than a single-vanos engine that has lots more things to go wrong.
I have no idea if it will work on a non-Vanos engine, but my guts tells me no. It also tells me it's time to eat.
Quotes to live by:
Old 08-02-2013, 02:57 PM
I like pie.
The only potential problem I see is the Vanos gear hitting the valve cover, but it screws off of the cam so I don't see why it wouldn't be doable .
Old 08-02-2013, 06:03 PM
DON'T PANIC
No one's answered my question yet though, where do you find one of these for a decent price?
Old 08-02-2013, 07:53 PM
D'oh, You Kids!
Re: $50 camshaft upgrade solution for M50/M52 engines
The for sale forum here or BImmerforums, Craigslist.
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Old 08-18-2013, 01:50 PM
highrev16v highrev16v is offline
Mein Auto: e36
i got my m54 cams at pick a part for 24 bucks and in good shape.
