Old 11-23-2012, 11:27 PM
BmwProject BmwProject is offline
The Shiz
Mein Auto: 2002 BMW 325i
Couple of dangling wires under front passenger side wheel well
So I have spent the past couple of days fixing all of my engine/radiator covers on the undercarriage, after hitting a semi's re-tread on the freeway.. (2002 325i) While I was replacing the wheel well cover on the passenger side, I noticed a couple of wires that had been stripped, (maybe by the tire tread) and I couldn't figure out what they were for. Is there another ambient air temp gauge on the passenger side? They are included in the wrapping of the fog lights, but don't appear to be for any lights. The wires are thin, and green. Thanks for helping guys!
Dan
Old 11-24-2012, 07:35 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Could be the fart sensor. Visit realoem.com and look up the part using the drill-down to be certain.
Sent from my DROID X2 using Bimmer
Jeff R.
Old 11-24-2012, 08:51 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Do you have self leveling bi-Zenons? Is so, it could be the wire for the sensor which is supposed to be attached to the front right control arm.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 11-24-2012, 11:40 PM
Mein Auto: '04 330Ci 6-speed
Snap a picture would give us a lot more to go on.
Old 09-16-2014, 03:47 PM
theidahosoprano theidahosoprano is offline
Mein Auto: 2001 325i
I have the same problem. I suspect that it is the ambient temperature sensor since my temperature has read -40 for about as long as I remember those wires being exposed. Wanted to be sure before I buy the parts. Can someone confirm?
Sorry for the quality of the second photo, hard to get under there. The blurry wire in the middle of the second picture is the wire I am talking about. There is also a black wrapped wire in the top left corner that I believe it is connected to. Hope someone can help me out!
Name:	2014-09-16 14.21.08.jpg
ID:	464839   Click image for larger version
Name:	2014-09-16 14.21.25.jpg
Old 09-17-2014, 09:47 AM
JKRIT JKRIT is offline
Mein Auto: '03 525i
The original two-year old post was probably in regard to PN 61318370747, Thermo Switch for Heatable Spray Nozzles for cars with foglights and headlamp washers. This switch is under the front bumper, similar to the ambient temperature sensor, but is on the passenger side (LH drive, north america) whereas the ambient temp sensor is on the driver's side. If you have -40 degrees showing, that is the classic indication for a missing or disconnected ambient temp sensor. Often the plastic underpanel that holds it (part of the LF front wheel well liner) is damaged or missing.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 09-17-2014, 12:53 PM
This is on the passenger side so it must be the thermo switch which isn't a feature my car has so I guess I just lost the place holder/cover. Guess the ambient temp sensor is a separate issue. Thank you for the reply, you saved me a lot of grief come installation time.
dangling wires, electrical connection
