Old 06-08-2011, 08:09 AM
mhs328Ci mhs328Ci is offline
3 Pedals of Course
Mein Auto: e46 328Ci & e84 X1 35i
llando, huge thank you for not only taking incredible care of your ZHP, but documenting it on the 'fest for everyone to benefit from.
I picked up a 2000 328Ci with 100k. The car was in great shape, I made sure of that. But now I'm going through the process of replacing all those bits and peices to keep the car running strong.
I'll be following along with this thread to do so.
Old 06-08-2011, 10:11 AM
spencers's Avatar
spencers spencers is offline
Mein Auto: 2006 330i
Originally Posted by Starless View Post
Do you consider this not cold enough and low on refrigerant? Why? I wish I could measure anything below 59F. I've always thought my ac was not cold enough...
Yeah, that doesn't seem right. My car usually hits between 4-8C (with IR thermometer at the vents), even in this Texas heat.
Old 06-08-2011, 06:53 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
No, not based on previous meaasurements. I believe I've gotten about 37 consistently when the system is full.
I also factor in it's been a considerable period since my last refill, plus the tell tale cavitation/hissing noise from the front right of the dashboard. I dunno, I guess I've gotten pretty close to reading this car after 8 years.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 06-08-2011, 06:55 PM
Great! It was always my intention that someone would benefit from all this stuff in "one" place for a "typical" car. Believe me, I am no expert mechanic, but I firmly believe with the 'fest, a few solid hand tools and some time, you can save quite a lot of money by maintaining these cars yourself.
- J.C. Watts Jr.
Old 06-08-2011, 08:22 PM
Starless Starless is offline
Mein Auto: 2002 325i Auto
The words of truth, I would not be able to afford the damn thing if it was not for this place.
Tell me please, do you fill it yourself or do you have it filled professionally?( I read horror stories about DIY approach dealing with filling refrigerant.) Now I'm sure I need a refill, 'cause it's kind of cold but at the same time I think it could be colder.
Old 06-10-2011, 06:43 PM
105,013 miles, 10 June 2011
Replaced both poly rib V-belts. I'd seen some cracking of the outer V-belt the other day. After I took them off, I noticed significant alligatoring of underside of ribs and dry/crackling sound upon removal.
BMW OEM Parts, bought at the dealer:
11 28 1 705 545 $51.33
11 28 7 512 762 $36.31
Procedure:
- Remove top of air box intake (3xplastic press fittings)
- Unplug electric fan connectors (2xconnectors)
- Remove electric fan assembly (Torx screw, 1xplastic press fitting) up and out of car
- Lever off 2xplastic covers on deflection rollers
- Use ratchet wrench with a Torx bit, deflect roller to unloosen outer belt, slip off
- Repeat for inner belt
- Installation is the reverse of removal, as they say.
- J.C. Watts Jr.
Old 06-10-2011, 06:48 PM
Starless - I fill it myself using a simple refill kit and bottle of refrigerant: http://www.bimmerfest.com/forums/sho...8&postcount=89
- J.C. Watts Jr.
Old 11-24-2012, 11:34 AM
Najamali Najamali is offline
Mein Auto: 07 525xi and 99 323i
How do I change the micro air filter and fuel filter on my 1999 32i E46?
Old 11-25-2012, 06:08 PM
Here is a video on the filter:
http://m.youtube.com/#/watch?v=i7Y2L...%3Di7Y2Ln6EJks
The cabin filter is covered by a plastic top secured by two 1/2 turn spring loaded fasteners. Undo the fasteners, lift the cover, replace the filter, secure the cover and fasteners.
- J.C. Watts Jr.
