Old 11-25-2012, 06:56 PM
Bigset3102 Bigset3102 is offline
Mein Auto: 528i
1998 528i lock issues
My keyless entry does not work I have tried reprogramming keys many times doesn't work. Also my alarm keeps going off randomly I believe it to be hood sensor any ideas?
Old 11-25-2012, 08:56 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Neither master key works? When was the last time you replaced the battery in the key?
Old 11-25-2012, 09:44 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Does the red LED on the key illuminate when the buttons are pressed? If no, then like edjack mentioned...have you changed the key's battery? (see text in red box in pic below)
Your model year probably requires a single 2016 battery:
Q {BMW CCA Member #191509}
(SOLD)
Old 11-26-2012, 03:34 AM
Mein Auto: 528i
Ok when I stick the key in the door it works but the led on the key does work I have replaced the battery and got a new key from dealer but it still doesn't work
Old 11-26-2012, 03:35 AM
Mein Auto: 528i
I've replaced it along with getting a new key from dealer I've also checked all fuses
Old 11-26-2012, 03:37 AM
Mein Auto: 528i
Yes the light illuminates I believe my hood sensor is faulty so ordered a new one and am going to try that
Old 11-27-2012, 06:58 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
re; alarm going off....
i concur....your hood switch could be the problem.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 11-27-2012, 12:39 PM
Mein Auto: 528i
Yes I hooked it up to computer and its shooting fault codes so I've ordered new switch. But not sure about why keyless entry isn't funtional
Old 11-27-2012, 03:29 PM
DBell DBell is offline
Mein Auto: 1999 528i
How are the chances of repairing the keyless entry buttons? ('99 528i)
My Lock and Trunk buttons work, but Unlock doesn't; wife's Lock fails, but Unlock works.
(Yeah, between us, we can enter and exit keylessly, but...)
Dave
Old 11-27-2012, 05:09 PM
Mein Auto: 528i
Dave
Are the rubber buttons worn out?
Old 11-27-2012, 05:49 PM
Mine are pretty worn down, yeah.
Old 11-27-2012, 05:51 PM
Mein Auto: 528i
I would order new rubber pieces off of eBay they're like 5-10 dollars
Old 11-27-2012, 05:57 PM
Mein Auto: 528i
New rubber on left old on right
ID:	351138   Click image for larger version
Old 11-27-2012, 05:58 PM
Great! I love it! Buy it Now for <$4 & free shipping...
Thanks!
Old 11-27-2012, 06:01 PM
Mein Auto: 528i
Yes then look it upon YouTube And it will show step by step how to do it
Old 11-27-2012, 06:24 PM
New batteries when I do it, too...
Old 11-27-2012, 07:07 PM
Mein Auto: 528i
Yes don't leave batteries out for more than 30 seconds
Old 12-11-2012, 06:00 PM
Replacing key buttons
Received new buttons and CR2016s.
Wife's key had nearly new buttons, as it turned out, but really weak battery. Works like new!
As for mine, repair levels I and II completed, but . . .
Can I go to level III and replace the contact film *under* the buttons?
Lock and Trunk are great, but Unlock was still dead.
Re-opened the patient, slipped off the film on the transmitter PCB and held it up to the light.
The carbon(?) film is totally gone under the Unlock bubble.
PCB pads look perfect, and the solder mask is intact except where the film makes contact.
N'mind! Eventually found the film on Ebay.
Not under BMW E39 key film, key repair (several shops, ALL in the UK?), but key parts.
Another whopping $2.84 w/free shipping!
Dave
