1998 528i lock issues
My keyless entry does not work I have tried reprogramming keys many times doesn't work. Also my alarm keeps going off randomly I believe it to be hood sensor any ideas?
Neither master key works? When was the last time you replaced the battery in the key?
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
Does the red LED on the key illuminate when the buttons are pressed? If no, then like edjack mentioned...have you changed the key's battery? (see text in red box in pic below)
Your model year probably requires a single 2016 battery: -![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
Ok when I stick the key in the door it works but the led on the key does work I have replaced the battery and got a new key from dealer but it still doesn't work
I've replaced it along with getting a new key from dealer I've also checked all fuses
Yes the light illuminates I believe my hood sensor is faulty so ordered a new one and am going to try that
re; alarm going off....
i concur....your hood switch could be the problem.
Yes I hooked it up to computer and its shooting fault codes so I've ordered new switch. But not sure about why keyless entry isn't funtional
How are the chances of repairing the keyless entry buttons? ('99 528i)
My Lock and Trunk buttons work, but Unlock doesn't; wife's Lock fails, but Unlock works. (Yeah, between us, we can enter and exit keylessly, but...) Dave |
Are the rubber buttons worn out?
Mine are pretty worn down, yeah.
I would order new rubber pieces off of eBay they're like 5-10 dollars
New rubber on left old on right
Thanks! |
Yes then look it upon YouTube And it will show step by step how to do it
New batteries when I do it, too...
Yes don't leave batteries out for more than 30 seconds
Replacing key buttons
Received new buttons and CR2016s.
Wife's key had nearly new buttons, as it turned out, but really weak battery. Works like new! As for mine, repair levels I and II completed, but . . . Can I go to level III and replace the contact film *under* the buttons? Lock and Trunk are great, but Unlock was still dead. Re-opened the patient, slipped off the film on the transmitter PCB and held it up to the light. The carbon(?) film is totally gone under the Unlock bubble. PCB pads look perfect, and the solder mask is intact except where the film makes contact. N'mind! Eventually found the film on Ebay. Not under BMW E39 key film, key repair (several shops, ALL in the UK?), but key parts. Another whopping $2.84 w/free shipping! Dave Last edited by DBell; 12-11-2012 at 06:11 PM. |
