5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
#101
For the record, someone was looking for this thread today:
- Looking For "Make your own Fan Tool" And this PDF (seemingly of the initial JPEG posted in this thread) came out: - How to make your own BMW special cooling system & drive belt counterhold tools - bimmerfest - BM.pdf (45.1 KB) |
#102
For the record, someone today didn't know about this thread where there are PLENTY of alternatives for holding the waterpump bolts in place while removing the fan clutch nut:
- E39 (1997 - 2003) > tools for a new owner Quote:
![]() Hopefully, that OP will do the job, and then write back here as to which tools he found best so that the NEXT person benefits, as always, from each of our repairs! |
#103
For the crosslinked record, today Dan reported that his cooling system overhaul went well ... and ... he didn't need anything more than a screwdriver to hold the waterpump pulley in place when removing the fan clutch nut:
- E39 (1997 - 2003) > Finished my cooling system, thanks guys! |
#104
For the record, make sure the counterhold tool you make is as strong as you can make it!
Why? GSA1 this weekend, had a problem with a counterhold tool that worked previously just fine, multiple times, - but two of them bent on this particular fourth vehicle: - Please help me!!.. Vanos seals install Quote:
- You may not need strong steel (mine, for example, was easy to remove) - But - you may need strong steel (so plan ahead). |
#105
For the record, for E46 M54 owners, this thread has good detail:
- Pictorial DIY: BMW E46 Fan Clutch Removal & Engine Belts Change For Automatic Cars
#106
For the record, this thread has helped others recently:
- E46 (1999 - 2006) > Help needed. Drive pulley nut stuck. Quote:
#107
For the record, today yet another E39 owner has had problems getting the viscous fan clutch off ...
- E39 (1997 - 2003) > e39 fan clutch removal, need help Quote:
EDIT: Fudman provided this ZDMack link in that thread, so others benefit: Last edited by bluebee; 09-20-2011 at 10:39 AM. |
#108
In addition, I just learned from this thread today of a NEW counterhold tool that holds the waterpump bolts steady by enveloping them on three sides: - E39 (1997 - 2003) > e39 fan clutch removal, need help
The beauty of this counterhold tool is that it appears to be even simpler to fabricate than the BMW-specific counterhold tool! Now what we need are the measurements for the rectangular cutout. Last edited by bluebee; 09-21-2011 at 04:51 AM. |
#109
Googling for the Ford counterhold tool set, I see that the wrench is included with the $15 set, as shown here:
My first question is the SIZE of the wrench (for example, if it's 32mm, it's ideal). It doesn't say in the advertisement above what the wrench size is. Here's another hit, but it also doesn't say what the wrench size is: Googling s'more, it appears that Ford has three sizes for the wrench. For example, see this reference for the Lisle 41800 Fan Clutch Wrench Set for Ford - 4 Piece: which tells us that Ford has two or three sizes.
Here's a KD Tools 3296 Ford Fan Clutch Wrench Set for 6.9- and 7.3-L Engines which says, unfortunately, that the wrench is 48mm, and not the 32mm that we need for the fan clutch nut itself.
A customer review of a similar tool said "The only problem is the short wrench or pulley holder is too big for the later model 7.3 diesel motors", so from that we can surmise there are at least three sizes in all for the Ford counterhold tool sets. Even Snap-On sells these tools: YA9325 Set, Ford Fan Clutch Wrench: Quote:
If any of you own a Ford, would you kindly let us know which of these are most applicable to the BMW E39? |
#110
Here, BTW, from this engine-components thread:
- What is this engine part? (Getting to know my M54 engine bay) Is a picture of my counterhold and fan clutch tools in place during my alternator replacement fiasco: - One users' example of total electrical failure (AAA towed away) alternator repair (1) x |
#111
For the cross-linked record, this thread about counterhold tools today:
- E39 (1997 - 2003) > How to replace the fan clutch? Contained this particularly nice fan-clutch removal video: |
#112
Yet another method was described today for immobilizing the water pump pulley while removing the fan clutch:
- E39 (1997 - 2003) > AUX Fan or AUX Fan Resistor A tennis ball! Quote:
Last edited by bluebee; 12-01-2011 at 02:37 AM. Reason: Added more information ... |
#113
Water pump pulley tool M54
I appreciate all the effort everyone puts into this forum. Thanks.
As for pulley holding tool, I've never had one. Now I have an 03 e39 w/ M54. Vehicle history stated one owner (3 yrs in NY, then they ended up in LA). I bought w/ 45K in 06. Now 120K and needed more than std attention. Apparently all that time wherever has really corroded some stuff up. (Rear disks frozen to hubs; will deal with that later). But pump pulley fan nut was incredibly frozen. I started to think "Maybe I've had a stoke and spazzed out and am just turning it the wrong way..." 3 days of PB blaster, large applied forces, and tears (As in from my eye; lol). Thought I was gonna have to buy a tool, didn't have time to wait. Tried the prybar trick (has always worked in past) and it only succeded in BUSTING the belt pulley AS THE M6 bolts BENT under pressur and craked the plastic pulley! WTF and plenty of bad words. So today I was going to make a tool like you all had drawn and got to thinking "All the pressure on the tool is on a 'clockwise' nut" so I drilled ONE hole and threaded one of the good M6 bolts thru it (center of hole - 1/4" drill bit - was approx 3/8" from bottom of piece of flat stock) and the 2" to the end of the bar was plain. The nut held pressure on LOTS of material, and open end-rested on top of pulley shaft (where you all had the debate about the size of the semi-circle). The other end (18" flat stock) I rested on a wood block where the air filter normally sits. Two of the M6's are STILL in the pulley; bent to hell. I was sort of shocked how little force it finally took to bust off finally. So hopefully in next few days I'll get VANOS seals, CCV junk, water pump, thermostat, going with new radiator (another cheap plastic replacement OEM; - this one lasted 9 yrs. Don't have 7bills for an all AL), fuel filter, new hoses (old ones only 3 yrs, but why risk it) and whatever else I ordered. Rebuilt alternator today. (/aside Saw somewhere on here 'The small rear bearing is usually okay'; not in my case. It makes noise spinning by hand. Of course, this air cooled alt is poor design. Needs a piece of screen over intake port to keep debris out. I had wasps, leaves, dirt caked on, bird feathers and tumbleweek sticks all cramed in the back of the housing. /endaside) |
#114
The attached document contain the drawing w exact dimension to scale.
Print the PDF (link below) using direction in document and use as a template to build your own tool. No need to measure in metric or English just print, cut and use as a template When u print from PDF make sure you select none for page scaling. Thanks Mhnd http://www.bimmerfest.com/forums/att...4&d=1326903921 |
#115
Interesting observation.
I'm having trouble visualizing this tool, and how a bolt on the end of it held the water pump pulley in place... but your novel invention appears to be such a well-engineered approach that it's a shame not to have a picture of the resulting tool!
#116
- Fan Clutch removal tool Scale Template print.pdf So that everyone can easily find it, I uploaded it to post #61 of the bestlinks thread, using a keyword-rich naming convention so that various search terms will find it in the future, long after we're gone.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-20-2012 at 02:54 AM. |
#117
For the record, someone who just did their cooling system said the 1¼ inch wrench is the wrong size for the 32mm nut:
- E39 (1997 - 2003) > Notes from my cooling system overhaul
#118
For the cross-linked record, apparently SOME BMWs 'can' use a standard Craftsman 32mm open-end wrench on the fan clutch nut.
For example, this DIY of a 2006 BMW X5 3.0 (M54) Automatic shows the standard wrench working just fine. - The Best of Bimmerfest! > Do-It-Yourself H.Q. > DIY: Water Pump, Thermostat, Hoses & Coolant Flush : X5 3.0
#119
For the record, some folks must be buying $50 wrenches for their cooling system overhauls!
#120
32mm = 1.259". Depending how much tolerance you have, this may, or may not work. Don't forget to add corrosion buildup on the nut
#121
Even after all these years, people are still trying to remove the fan clutch nut without any counterhold apparatus whatsoever!
EDIT: This was also posted today. Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-20-2012 at 08:18 AM. |
#122
For the record, this related pointer to the 32mm wrench was posted today:
#123
Thanks to all who posted! If I could have got the tools for $19 or $39 in time to do the fix and get the car running for Monday morning, i would have! The longer belt failed, taking the water pump out with it, and I needed the car back on the road to get to work! Thanks BlueBee for the suggestion of using a speed clamp, I even had a rusty one ready to sacrifice. However, since the pump was so broken it would not sit still enough to use the screw heads for leverage, I took a slightly different route, using bolts the same size/thread as those that hold the pulley on, I drilled only one hole in the metal stock from the clamp, bolted it to the pulley face, and then put another, slightly longer bolt in the adjacent hole, for the face of the clamp stock to press against, its end held firmly in place by the adjacent bolt. Without pics, this may be confusing; but in the real world, it worked! Two new belts and a water pump, under $100 total, and the car is on the road again! Oh yeah, a gallon of anti-freeze to boot.
#124
For the crosslinked record, this thread was opened today by someone asking about the fan clutch nut removal tool:
