E36 (1991 - 1999)
Old 09-25-2012, 06:39 PM
RGBMR RGBMR is offline
Mein Auto: 318i
Question p1222 code: Sputtering: how to resolve
Good evening. I have a 92 318 and it is sputtering badly. The code is P1222. I took it to a friend who said it is "missing" In other words, not all the cylinders are firing. The idle also moves back and forth from about 400 to 1200 RPM's. I am not a mechanic but it acts like one of the coil packs is not working or maybe the plug wires are malfunctioning. Does anyone have a suggested solution. Parts aint cheap so I am looking for the best targeted solution. If anyone has experience with this please let me know.
RGBMR
Old 09-25-2012, 06:59 PM
Dino1394's Avatar
Dino1394 Dino1394 is online now
M54 torkz babyyyy
Mein Auto: 04 330xi
ohhh man 1222 was the worst code ever
Have you checked for vacuum leaks?
How are your spark plugs?
How are the coils?
Is your maf clean?
ICV clean?
Injectors working?
How old is the o2 sensor?
Along with code 1222 is the code 1221 also present?
1222- Is the fault code for the DME seeing a very rich or very lean mixture for more than 10 seconds
I bet if you cleared that code itll drive normal until it come backs or this it would throw 1221 only
Old 09-25-2012, 07:11 PM
Mein Auto: 318i
I just purchased it and here is what I know:
Plugs were just replaced
I do hear it sucking air so I will check for obvious vacuum leaks tomorrow
Any idea how to check the coil packs to see WHICH ONE may be malfunctioning?
Should I just cave in and take it to a shop, get them to give me a specific diagnosis, then pay my shade tree to do the repair?
I am thinking IF they can pin point the issue, that will be cheaper to pay their diagnostic charge vs. replacing parts till I find the smoking gun..
Your thoughts?
Thanks,
RGBMR
Old 09-25-2012, 07:16 PM
Dino1394's Avatar
M54 torkz babyyyy
Mein Auto: 04 330xi
Honestly do the cheapest things first.
Did the car have this issue when you bought it?
(Speaking of experience with the I6s) Make sure 4 crappy 4 prong platinum plugs weren't installed.
But definitely check for a vacuum leak (Do this first)
Examine the coils to see if they are worn, cracked etc.
And are you positive 1222 is the only code present?
Old 11-27-2012, 05:50 AM
josephroberts75 josephroberts75 is offline
Mein Auto: e36 bmw
tried the plug boots? mine missed like hell even after replacing them just not so bad so i gutted the plug boot and installed springs in the core of the plug boots and its been perfect for 3 years now also check for water or oil in plug holes ive seen people wash under the hood and then there car miss only to find water had gotten under the coil pack grounding it out!
Old 02-23-2013, 05:34 PM
jricky74 jricky74 is offline
Mein Auto: 1995 BMW 325i
How do u clear codes
Old 02-23-2013, 07:00 PM
Dino1394's Avatar
M54 torkz babyyyy
Mein Auto: 04 330xi
hold the gas pedal for 10(?) seconds
i usually hold it for 30seconds just to make sure i did it right
Old 02-23-2013, 08:32 PM
with ignition on or off
Old 02-23-2013, 09:35 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
ON. You have to do it after you've gone through all the stored codes and get a 1000 (one long flash and then nothing) meaning "no more codes stored". Don't turn the key off until you've gotten that 1000 code and then HOLD THE PEDAL DOWN for at least ten seconds. After that turn the key off and then on again and redo the pedal trick. You should get a 1444 code, meaning "no codes stored".
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 02-23-2013, 10:13 PM
Gooby's Avatar
Gooby Gooby is offline
Kebab Lord / Sexy Sax Man
Mein Auto: 1995 M3
Code 1222 is faulty oxygen sensors.
Replace them...
Old 02-23-2013, 10:33 PM
Dino1394's Avatar
M54 torkz babyyyy
Mein Auto: 04 330xi
Replace them...
+1
This was the fix for my 1222 code
Old 02-24-2013, 12:05 PM
i had that 1222 code and replaced my oxygen sensor then tried to clear the code by pressing and holding the pedal down for 30 sec but didn't work for me. so i disconnected the battery and that worked fine. i then drove my car around for awhile and it popped back up again so i did the stomp test and same code reappeared, the code also stands for pedal sensor meaning tps. would this clear it
Old 02-24-2013, 12:27 PM
Dino1394's Avatar
M54 torkz babyyyy
Mein Auto: 04 330xi
If the new o2 didn't help check for vacuum leaks or something I didn't clear my code I just installed it and the code cleared itself in less than 5minutes of driving
Sent from my SPH-D710 using Bimmer App
Old 02-24-2013, 01:50 PM
D'oh, You kids!
If holding the pedal down didn't clear the code you either (1) still had at least one code still stored that you hadn't pulled up, or (2) you pulled all the codes but never got the 1000 code before attempting to clear the ecu.
Quotes to live by:
BMW-CCA #441426
Old 02-24-2013, 02:02 PM
when i did the test the same code kept repeating itself over and over and nothing else never ame out. now when u say code 1000 does that blink the same way or is it just a long flash
Old 02-24-2013, 05:08 PM
D'oh, You kids!
It will keep repeating a code until you repeat the "five stomps in five seconds". Then it will move to the next code. It may have the same code stored several times. Keep repeating that (and recording the codes!) until you get ONE long flash and then nothing. That is the 1000 code. THEN you are ready to clear the codes by holding the pedal down for at least 10 seconds.
Quotes to live by:
BMW-CCA #441426
Old 03-01-2013, 08:35 PM
rsims5series rsims5series is offline
Mein Auto: 740I
stomp test
Worked,,,Thank You,
I just purchased a week ago had smoke, changed the OSV and its running Great but the plugs had fouled , now all good....
Great Forum ALWAYS....
BTW I just changed the valve on the OSV back part seen it on youtube, just a screw driver PO was quoted 1100... I bought the car for 700...
rs
New to me today .95 740I w /96 Motor, have 2000 seville, 99 Catera,91 Alfa 164L,81 Alfa spider, 81 MB 380 SL...
Forget the Car Payment..
:3, help with resolution, p1222 issue
