E36 (1991 - 1999)
I have a 1998 328i with automatic transmission..basically wont shift out of 1st, but sometimes in 2nd with encourgement, no 3rd. tried in auto and manual...no codes.....any ideals I could try...fluid is fine...
thank you for ant help.. jamie |
I dont know much with the auto trans but I think yours may be shot.
How many miles on it?
150,000..wouldnt it show some codes
Not necessarily, You said the fluid was fine, Was it changed at all?
There are only a few faults in the auto tranny that will generate the transmission failure light on your dash. There are more codes however that are stored in the transmission computer that will not show up on the OBDII data port connector. The dealer and some indie shops have the code reader for the transmission. By the way, the transmission is supposed to not shift when you select the M position. That position tells the tranny to stay in the gear you have selected.
you are correct on the manual part, ok in first in manual and 2nd also with some encourgement and no 3rd in manual just like when in auto..anything else you could suggest...
thank you |
Try driving without manual at all
'Fluid is fine'. How fine? Is it bright red? Are you checking it hot with the engine running?
Could be a blockage in the valve body. Chances are that the tranny is gone.
Dude, that transmission is knackered.
![]() Sent from my MB860 using Bimmer App
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
clutch packs are shot!!!!!
