E36 (1991 - 1999)
fuel pump ?
it would seem the wifes 96 318ti wont start,it has been running like a top,no issues other than a minor oil leak.the car does turn over,i shot starting fluid into the throttle body and i could get it to bark abit,this wasnt a attempt to keep it running,just trying to do my best at diagnosing (spark,fuel and air )i can hear the fuel pump when i turn the key however i have no pressure on the injector rail ( the release valve ) next step was that i disconnected the fuel line at the fuel filter between tank and fuel filter.had no fuel come out of line when key switch was turn on,even though i could again hear the pump whine.questions
1)has anybody ever heard of fuel pump being bad and still audible,im thinking impellers may be bad ? i have replaced more than a few pumps over the years and either they were on or not,all or nothing. 2)while doing the previous i was taking breaks and looking through forums for some help,now im all stressed out over everything from cam,crank sensors to dme being fried from some bad windsheild seal... am i on the right track ??
yes, a pump can spin but not build pressure when the vanes are worn enough.
your guage isn't reading empty, or almost empty, is it?? you may have a faulty sender for the guage. df
gas gauge is reading about 3/4 full,what has me a bit baffled is the fact there was no warning whatsoever and that im still getting noises from the pump,even though like i said earlier no fuel is being pumped....new fuel pump on order,will pick-up and install in the a.m.
hope my guess is right,fairly expensive guess. wish me luck |
if there is power to the pump, and it is running, but nothing is coming out of the fuel line, then yeah, it sounds to me like a fuel pump.
df
yep fuel pump while at it replace filter
