BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Coding lighting
I coded some features today.
After coding, I noticed that when I switch off the car, the headlights switch off straightaway, instead of staying in for 40 seconds per the pathway lighting setting. Has anyone else experienced this? Also I coded the FLA_Aktiv feature to be on (M5 doesn't have this option) and this is also not working even though I changed the setting to automatisch. I don't know if these 2 things are related. The only other lighting mod I did was switching off side markers.
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP |
For AHB, BMW changed the behavior of FLA_AUTO_AKTIV from "aktiv" to "automatik", and now apparently the Lights need to be cycled before AHB works. You should read this thread if you haven't already: http://www.bimmerfest.com/forums/sho...d.php?t=644297 wdimagineer retrofitted the stalk in his M5, which if I understood him correctly he still needs to cycle the lights for AHB to work, but it is easier from the stalk.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Strange. I don't know of any other instance where this has happened.
Right Click in your FRM ECU (the ECU itself; not the underlying CAFD, and select CODE) to reset to your Footwell module, and see if it returns to normal.
I installed the 48.1 data you linked me yesterday. Then when connecting to the car, I selected F10. Is there a different selection for the M5? Also it doesn't have HU-CIC it has HU-something beginning with L. It did strike me as odd that the files are different.
What is the name of your CAS CAFD file?
I'll get back to you in 2 days. Just have a short trip to SAN.
This should be in the FRM module.
Stealth:
Make sure your light switch is set on automatic.
