E36 (1991 - 1999)
so car started overheating last week, putting water in and it was pouring out just as fast. Upon an inspection the water pump had cracked, replaced water pump and head gasket seals due to milky residue in top rocker, drained oil and coolant system, new oil filter. filled up with new oil and water, still overheating, and still has milky residue on inside of rocker. stumped please help!!!
1. Leak down test.
2. Compression test. 3. 9 for 10 you have pooched your head gasket and it will cost you ~$1200.
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
sigh
compression test done cylinders fine, have been reading something about a pcv valve?????
![]() Slow down.. you're doing E,F,G without doing A, B, & C, FIRST. Did you bleed the cooling system properly? its rather tricky on the E36. Condensation may be giving you the "milky" residue.. Bleed cooling system. HINT: get nose of car higher than engine
have spent hours releasing and unreleasing the bleeding screw and watching and hearing steam coming out where abouts is the bleed valve on the engine block?
have flushed out cooling system, only thing not checked is rad. Last edited by krisse84; 08-09-2012 at 11:46 AM. Reason: forgot a bit |
The bleed screw is here: ![]() DIY here: http://www.bimmerdiy.com/diy/e36coolingsystem/ AFAIK.. there isnt a "bleed" screw on the block. There is a drain plug. Where are you "hearing" steam escaping ?
lol
yes tightening then loosening and the steam is coming from bleed screw once it is loosened, and engine has run for a while.
Park on ramps in your driveway, nose up. Let the car idle for a few minutes, loosen the bleed screw until you get fluid coming out for a while. Steam just means you still have air in the system.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . Last edited by E36 Phantom; 08-09-2012 at 12:13 PM. |
Be sure to have your a/c turned to high and on heat setting.
96 328is preceded by 09 G8 GT... RIP 7/15/2011 |
Keep repeating me.. its a nice form of flattery. NO, you should not have "FLUID COMING OUT FOR A WHILE".. WTF? ![]() Act like you're NOT a polluter.. Little bubbles.. not streaming fluid.
well, i think that you may have a warped or cracked head. did you have a machine shop look at it?? if not, then stop right now and take a combustion gas leak test. you can get the kit from almost any parts house and it's simple to use and confirms the presence of co2 in the coolant. (this can only happen when combustion chamber gasses leak past the combustion chamber via headgasket or cracked head)
if it comes back positive, then bleeding will not do anything. take it apart. again. send the head out to get checked. go from there. the type of kit is like this one in the link below. http://www.arrowheadradiator.com/hea..._leak_test.htm good luck. df
start the car leave the tank cap off and see if large bubbles rise if so then a gauranteed cracked head! aluminum does not take heat very well!!! also white smoke out the exhaust after the car is warmed up to temp
Old thread...................
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
He's going back 2-3 months and replying to every dead thread on the forum. Why?
I mean, his advice is good, but a little late to be useful.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! Last edited by hornhospital; 11-27-2012 at 09:15 AM. |
