E36 (1991 - 1999)
Old 08-08-2012, 04:06 PM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
Welding Question
I need a question answered.
The lower shock bolt had stripped out of the trailing arm on my ride and I don’t want to have to replace my entire rear trailing arm. The hole is a blind hole and I can’t find a recoil kit with a bottoming tap to give a complete hole to rethread. So I thought filling it and retapping it seems like the best answer.
My question is would it be better to drill all the way through and fill from both sides, or try to get the wire feed in as deep as I can and try to fill it up that way? Or would it be prudent to drill though and then weld in a stud?
Yes I can weld. I am out of practice and It’s not the prettiest but my seams hold.
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 08-08-2012, 04:15 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Josh, search for CJ's "Broken Bolt thread".
He dealt with exactly this not long ago.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 08-08-2012, 05:20 PM
JoshuaG's Avatar
Natasha 95M3
Thanks!
My .02
Old 08-08-2012, 05:48 PM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
i believe that was for a conttrol arm mounting point, not the shock. unlessi am confused.
(it happens sometimes....)
anyway, i believe that you will need one of these...
http://www.wttool.com/index/page/pro...aps+(Heli-Coil)
it's just the tap, but it's a blind hole sti tap (sti = standard thread insert), which i do not believe comes with the kit. it only comes with a standard taper fit, which may even work, not sure. it depends on how deep the threads go, how much of the hole is left open.
the bolt s/b a 12x1.5x60mm. worst case scenario, use the regular tapered tap and add a washer onthe outside to take up the space from not bottoming out.
i'd not suggest welding, though. at least not regular steel to cast. unless you've got the set up to do so, in which case, the few bucks for the tap isn't going to be much anyway....
good luck.
df
Old 08-08-2012, 05:53 PM
jonesin's Avatar
The Canadian Prick.
Crap. I read too fast. I skipped 'shock' and read trailing arm.
Old 08-08-2012, 05:54 PM
JoshuaG's Avatar
Natasha 95M3
You sir are awesome! I was just about to say I had a different issue then you gave me this... This wonderful piece of epicness.
My .02
Old 08-08-2012, 06:02 PM
would you *PLEASE* let mrs. df know how epic-ly awesome i am so she'll be nice to me??
df
Old 08-08-2012, 06:03 PM
JoshuaG's Avatar
Natasha 95M3
Wait the bolt and coil kit I have are 12x1.75 I'll have to ask if they have it when I call in the morning.
My .02
Old 08-08-2012, 06:09 PM
the bolt that holds the shock is a 1.75 pitch?? i didn't look at an actual bolt, i just looked it up on real oem. could be a typo.
regardless, here...
http://www.wttool.com/index/page/pro...28Heli-Coil%29
yes, i know....
df
Old 11-27-2012, 07:11 AM
josephroberts75 josephroberts75 is offline
Mein Auto: e36 bmw
maybe you could drill though and put a bolt thru it with a nut and never have to worry about stripped treads?
Old 11-27-2012, 09:28 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
I had this but caught it in time to tap in new threads. I think they had to weld in an insert, though. MSW did it for like $50. They're so awesome.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
