BMW Coding and Programming
Discuss coding options and features on your BMW here. |
high beam camera same as SLI / LDW / KaFAS?
Does anyone know, on the f30, whether the automatic high beam assist camera is the same as the SLI (Speed Limit Info) / LDW (Lane Departure Warning) / KaFAS module?
If not, I'll have to scrap my dream of getting SLI / LDW through coding BTW, I searched realoem.com, but can't find the high beam camera: http://realoem.com/bmw/showparts.do?...80&hg=51&fg=40 http://realoem.com/bmw/showparts.do?...58&hg=66&fg=05 |
Isn't the High Beam sensor the little white square sensor on the back side of the rear view mirror?
No, that's for the auto dimming mirror
You need to read this post: http://www.bimmerfest.com/forums/sho...ight=high+beam
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
They are the same in that the Camera used is the same for AHB, LDW, and SLI, and the KAFAS Coding, if not identical will be very similar.
As I wrote there, besides adding 8TD and 8TH to the VO and coding the car, I am almost positive SLI requires an FSC code, which is why I don't think anyone has succeeded at this.
I can confirm that SLI does require an FSC code to activate.
![]() 2013 ///M5 Alpine White · Sakhir Orange Full Merino Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods |
Do you have SLI on your M5?
I do. It was part of the Driver Assistance package. But discussing my attempt to enable SLI on my 550 with my tech at the dealer he mentioned this.
Can you go into E-Sys, Comfort Mode, FSC, and run Check FSC Status, and send me the output?
Sure. I'll grab it tomorrow.
Thanks!
You back East for the holidays, or just forget to go to sleep?
Thanks |
I'm not 100% sure it's the same camera. I saw a BMW 7 Series LCI at the SF Auto Show the other day. It did not have a driver assistance package (LDW, etc.), just AHB. It was a separate camera mounted at the base of the mirror - not the "KAFAS" camera referenced above.
This is the standalone HBA camera: ![]() This is the KAFAS camera [representation only], that can do HBA, collision avoidance, LDW, SLI, etc. It's wedge-shaped and mounted above the mirror: ![]() Crazy enough, I've also seen cars with both with some early models.
No, not the same. If you have AHB, and you want SLI, you shouldn't need any additional hardware, but you do need an expensive FSC Code. SLI also requires Nav as it uses both the KAFAS Camera imagery and data from the Nav System. If you want to add LDW though, it does not require an expensive FSC Code, and you can code it to where it is always on, at least on the F10 you can, however, you really need to add the dash control switch and the vibration module / steering wheel to be OEM proper. So, one requires an FSC Code, and the other Requires some additional hardware.
Are you sure that is a standalone HBA Camera? I think it is something else. I do not think HBA exists without KAFAS camera.
Hmmm... The camera hanging down from the mirror is exactly how mine looks like... Definitely not the wedge shaped camera shown on the second picture (also on the realoem.com link on the 1st post)
@shawn: Yep. As ahmadr just confirmed, the HBA-only camera is different. It's designed solely to measure lighting and cannot do shape/number recognition. Without KAFAS, retrofitting LDW, SLI, etc. is impossible.
I have the KAFAS camera on my F30 with AHB, SLI, LDW and whatnot, it looks like this (my apologies for the crappy pictures, it was morning, the sun was in a weird position and I have pretty dirty windows lol):
![]() The other camera (with the cam on the bottom) looks a bit like how it is with the F30 of a friend of mine, he does have AHB but no SLI or LDW. The camera/sensor housing on my car is almost twice, if not triple, the size of that of my friend's F30. Btw, doesn't LDW also make use of the sensors/radar on the rear and side of the car? Taken from the BMW website (here (I know this article is for a 5 series but it should work all the same)): Quote:
I have no idea why the systems are not the same but I do know that there is a big difference in camera(housings) between the F30's that are only equipped with AHB and those who have SLI, LDW, Collision Warning and so on. It could have something to do with the system as a whole, or maybe more simple as in cost-reducing since AHB is fairly common while the driver assistance package isn't
'12 F30 328i w/ A17, LCLY, ZLL/7S2, ZCW, ZDA, ZPK, ZPP, ZPS, ZTP, 205, 2VL, 302, 3DZ, 415, 417, 522, 524, 5AC, 5AP, 5DP, 615, 6AA, 6AB, 6NF, 6NL, 6NR, 6UH, 6VA, 6WA, 8S4, 8TH (yes, that's all lol) Retired: '09 E70 X5, '04 E46 M3 Last edited by svache; 11-27-2012 at 10:59 AM. |
There are two technologies, and both are options. We get them as part of a package but in other markets you can opt for Lange Change Warning, Lane Departure Warning, or both. However both rely on KAFAS. In both KAFAS monitors lane markings to determine if you're drifting or changing lanes, and then in the case of LCW, uses the rear sensors to determine if there's another vehicle next to you.
In earlier generation cars, you could actually have BOTH cameras (KAFAS and AHB) depending on your packages, but KAFAS has improved now to where only a single camera is required if you have the options. Unfortunately with just AHB, the KAFAS module is too expensive so they still use the standalone camera.
Well, I am sure early F10's with AHB only had the standard KAFAS camera only, and people did retrofit LDW. I wonder now what the F10 uses with AHB Only? I guess BMW figured out a cheaper way to do it, or got wind of people enabling LDW and SLI, and took preventive measures.
BTW, The other thing one can see there is the IR transmitter / receiver for the rain sensing wipers. I have it too. |
You're correct. I misspoke.
And it all depends on the model whether they use KAFAS or not. There might be a technical or visibility reason in the F25.
