Tools and Miscellaneous
Tools, spare parts, any and everything else. |
****** RTAB, FCAB, vanos, peake tools, shim kits, etc
BMW tools for ****** RTAB, FCAB, vanos/timing, peake tools, shim kits, etc.
I’ve accumulated several BMW tools over the years from owning several BMWs and I’m offering them to loan. They’re a rip off to buy for a one time use, so here’s an opportunity to get the job done with the right tool. -Vanos/timing tools -RTAB (rear trailing arm bushing) tool -FCAB (Front control arm bushing) tool -Peake SRS tool -Peake scan tool -e46 M3 valve adjustment kit (shims, pick up tool, micrometer, 32m wrench) The details of each tool are listed below -RTAB tool. Loan includes both the removal tool as well as the installer tool. $25 outgoing shipping/handling. You are responsible for return shipping. $100 fully refundable deposit required in case of damage. ![]() ![]() -FCAB tool. Loan includes both the removal tool as well as the installer tool. $25 outgoing shipping/handling for 7 day loan once tool arrives. You are responsible for return shipping. $120 fully refundable deposit required in case of damage. Works on: e30, e36, e46 as well as 60mm on earlier 323 & 328 models. ![]() ![]() -FCAB Lollypop Tool. This tool allows you to remove and reinstall the FCAB into the lollypop/bushing carrier without the use of a 6 ton shop press. Loan includes both the removal tool as well as the installer tool. $25 outgoing shipping/handling for 7 day loan once tool arrives. You are responsible for return shipping. $100 fully refundable deposit required in case of damage. Works on: E30, E36, E46 (60mm only on 323/328/M3, and Z3 lollypops. ![]() ![]() ![]() -Vanos/timing tools: See picture for specific engine applications. Loan includes camshaft locking block, sprocket turner, crankshaft lock pin, camshaft tensioner lock pin. $25 outgoing shipping/handling for 7 day loan once tool arrives. You are responsible for return shipping. $120 refundable deposit required in case of damage. -The other Vanos tools (32 mm open wrench, fan clutch holder, & 17/18 MM modified sockets are available for an extra $10 shippping/handling (requires the next size larger flat rate shipping box). No additional deposit required if loaned with other tools. For the following motors (will not fit an s54): -M42 -M44 -M50 -M52 -M54 -M56 -S50 -S52 ![]() ![]() ![]() -E46 Rear Differential Bushing Tool: $25 outgoing shipping/handling for 7 day loan once tool arrives + $100 fully refundable deposit. For non-M vehicles only. This tool allows removal and installation of the bushing. You are responsible for return shipping. ![]() ![]() ![]() -Peake R5/FX-3 (scanner & reset tool): $25 outgoing shipping/handling for 7 day loan once tool arrives + $130 fully refundable deposit. You are responsible for return shipping. http://www.peakeresearch.com/fcx3.htm ![]() -Peake R5/SRS-2 (airbag tool): $25 outgoing shipping/handling for 7 day loan once tool arrives + $130 fully refundable deposit. For 2001 and older vehicles only. Outgoing shipping is $5. You are responsible for return shipping. http://www.peakeresearch.com/srstool.htm ![]() -AB03 Adapter: Comes with the loan with one of the above loans. Allows use of above tools with older style under hood connection. ![]() -e46 M3 adjustment kit: $50 outgoing insured shipping/handling for 7 day loan once tool arrives + $550 fully refundable deposit. You must replace shims with OEM units from the dealer prior to sending it back. You are responsible for return shipping (around $15 with insurance). If you only want the shim kit and pick up tool, subtract $10 from the shipping/handling cost & subtract $150 from the deposit. ![]() ![]()
This is such great news! I'll get back to you in early January to rent the valve shim kit. Thanks!
Need to Rent E46 Shim Kit Only
Is this rig still available for rent? I only need the shim kit - have the tool and micrometer.
How much, and how do you handle the money? Paypal? When can you ship to the Seattle area? Thanks. Steve |
