X5 E53 (1999 - 2006)
The X5 SAV Forum |
2006 X-5 Red Battery Symbol light
Today I experienced a red battery symbol light after starting the X-5. THere was plenty of juice to turn over the engine. I drove the vehicle a short distance and shut it down. A few hours later I restarted the engine without incident-no red battery light. All appears normal now.
Could the main computer reset the light? Could this be an early warning sign of a failing alternator? If so, how many labor hours does it reasonably take to change an E-53 alternator? Thanks. |
It depends on what engine you have. A red battery light does equate to early
signs of alternator trouble. I've also noticed that on many BMW's I've seen as they start to fail they make a high pitch sound. Mine went on my X5 like two months after I noticed the sound. It may not happen to all failing alternators. Labor and all was right around $1200 about four years ago on an M62 4.4i. So expect the same with a V8 and slightly less with the M54. The radiator fan has to be removed on the eight's, I don't think so on the six's.
Check your mirrors as often as it takes for you to know where everyone is around you! |
Is 3.5 hours labor reasonable for an E53 alternator change? Does the radiator need to be removed? Does it makes sense to replace the two drive belts during the replacement as a preventive measure being they are right there? |
It's a good idea to replace the belts while in there. I am not too familiar
with Valeo products (ive heard, but never associated) Here's a post to skim through about alternators. http://www.bimmerfest.com/forums/sho...d.php?t=514504 It is a tight fit to work with so radiator removal is necessary. 3.5 hours seems reasonable for an indy. Here's a brief how to on removal. http://tis.spaghetticoder.org/s/view.pl?1/07/45/83
If you've UNLOCKED your instrument cluster...you can monitor the output of your alternator/charging system when the engine is running if you open TEST 9. When the engine is NOT running and the ignition is in position 1 or 2...then it will reveal the battery's voltage.
A alternator in good working condition should be putting out 12.8volt to around 13.8 volts. If it is spiking consistently above 14 volts (that's too high). Have you checked your belts? A slipping belt or a belt that is cracked and about to split/rip...could also have caused your momentary red battery light...as well as one of the pulleys/belt tensioners. Here's the instructions on how to UNLOCK the OBC (instrument cluster) so you can access the 21 TESTs that are available: Click this link for a description of all 21 TESTs: http://www.cardomain.com/ride/313409...series/page-6/
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
