E90/E91/E92/E93 (2006 - 2013)
#26
Now I don't know if this is true or not, but a CA once told me that other BMW key fobs can wake your car. Because of how the handshake works (and I'm not sure if this is *all* cars or just the ones with CA), if someone else unlocks their BMW, all BMWs in the vicinity also 'wake up' to see if it is the correct key fob, and when yours sees that it isn't, it doesn't respond and goes back to sleep, but nonetheless some of the electronics do wake up momentarily. He said they have issues with the cars on the lot because of how often these little wake/sleep cycles occur. Could be BS, could be true, but sounds plausible.
#27
cars without the tcu module go to sleep in half the time (approximately) not sure why the tcu module extends the deep sleep time |
#28
What were the other problems and had you known about them?
#29
+1. All of our problems should be resolved so easily!
Tom |
#30
Other problems are not relevant to the thread.
And, yes, I had known about them and asked them to be addressed.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons |
#31
Yes. We have an ironclad rule about diverting from the original topic.
Obama is an incompetent liar! ![]() Porsche: Accept no substitute, unless you're poor! ![]() The E90 sedan is the last in the line of great 4 door 3 Series BMW's. Too bad. "The VW GTI remains and will likely continue to be one of the finest compact sports cars in the world." Christian Seabaugh, Motortrend, March 27, 2012. 06/02/2005-03/02/2013: 7 3/4 Great years on Bimmerfest!!! |
#32
But, apologies to Wihelm G if I came off rude there. It was nothing worth discussing, just some minor rattles and such.
#33
Deleted.
Obama is an incompetent liar! ![]() Porsche: Accept no substitute, unless you're poor! ![]() The E90 sedan is the last in the line of great 4 door 3 Series BMW's. Too bad. "The VW GTI remains and will likely continue to be one of the finest compact sports cars in the world." Christian Seabaugh, Motortrend, March 27, 2012. 06/02/2005-03/02/2013: 7 3/4 Great years on Bimmerfest!!! Last edited by hpowders; 06-01-2011 at 05:53 PM. |
#34
No hay pedo, homie, it was dumb question. That's what i get for posting after eating one of those Costco chocolate and almond covered Dove bars.
#35
Just glad it was a simple fix (couldn't believe a bat. would go out that soon).
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
#36
#37
Replaced brand new battery .... Light came on again
WTF
06 130i 07 320i 08 E92 325i Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton, Argon 18E114 NEXT CAR : Lexus
#38
Did you register the battery?
#39
How do I do that ? Tx
#40
#41
Oh... had it replaced at local batterty shop
bummer
#42
There is also software that allows you to do it with your own laptop.
Otherwise, you need to have a dealer or a BMW specialty shop do it. Good luck and sorry you have had a problem.
#43
can someone please make an iPhone app to register a new battery for my car
Please
#44
Am I in trouble ?
went to BM dealer asking them about register new battery... they said non genuine battery they won't help me they only recommend genuine BM battery non genuine $165 Genuine $353 what choice do I have Give up the non genuine and go for genuine and waste $165 ????
#45
Buy a coding cable and download the software
A coding cable should cost around 100 bucks at most less if you have an 06.
For info on how to do it go here http://www.e90post.com/forums/forumdisplay.php?f=368 this will also allow you to reprogram the car and do diagnostics. Also and Indy BMW shop may be able to do it for you. Last edited by ctuna; 11-29-2012 at 10:01 PM. |
#46
My local indy shop will do the registration for way less.
Laser ___________________________ 2011 535i Black Sapphire Metallic, Sport, Euro Del (ret) 2009 328i Black Sapphire Metallic 2007 Honda S2000 Berlina Black |
#47
SilverX3:
Go to a good independent BMW shop but call them first and tell them you need your battery registered. Coding cable and software is nice but that is all you need. Maybe 50 bucks. More than likely you have the wrong CCA too but that isn't as big a deal as BMW makes it out to be. Coding can adjust the CCA too but BMW only has so many choices and what you had installed is most likely not one of them but close. Remember it is a battery and the only reason for doing the registering is to help prolong battery life. However from what I have observed on most BMW forums it has not helped much. A battery tender helping 500% more than registering your battery... |
#48
OK... thanks for that
Rang local independent they said they can register it for $50 labour will bring the car to them
