Old 11-27-2012, 02:57 PM
DBell DBell is offline
Mein Auto: 1999 528i
'99 528i ABS/Spedo issues
This appears to be a common set of problems!
In my case, all works when the car is cold, then progressively fails as I drive and/or the weather heats up. First to fail is the Tracs/ABS, and if I happen to be braking when it dies, I get the brake system pulsing expected from an ABS stop. I take that (hopefully!) to indicate that a wheel speed sensor is opening up. Happens sooner in stop-n-go traffic, where there's a lot of braking effort, and in hot weather.
Some time later, say within a mile or two, the speedo quits. CEL never comes on under either failure. Along with the speedometer, I lose the odometer of course, and the MPG "gauge". The fuel-remaining computer still works, but there is no damping on tank slosh; with braking, the mileage goes up, and down under acceleration...
Which wheel sensors control which services?
Is there a way to electrically check the sensor (I imagine it's a coil, responding to a magnet on the hub)? What's the best place to plug in to check them?
Thanks!
Dave
Old 11-27-2012, 03:09 PM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '97 528i
LH rear wheel speed sensor is for the speedomeer.change it and you're done.
Fuelly
Old 11-27-2012, 03:24 PM
Thanks, Moots, but does that also control the ABS/Tracs?
It seems like the failure is progressive (1-10 minutes apart), so I figured there were two units failing.
Tonight, for example, after about 4-5 miles, the ABS/Tracs error light came on. 5 minutes later, the speedometer dropped to zero.
Dave
Old 11-27-2012, 09:54 PM
moots's Avatar
wat's dat noise
Mein Auto: '97 528i
these wheel speed sensors are dual function sensors.all 4 wheels have wheel speed sensors that inputs the ABS obviously.the lh rear also inputs the speedometer.the other sensors also inputs other systems but i can't remember.google is your best friend.
http://www.bimmerfest.com/forums/sho....php?p=3774725
Fuelly
