Old 11-27-2012, 08:09 AM
jmears jmears is offline
Biggles
Mein Auto: 520i
Wiper problem
Hi everyone, can any of you suggest why my wipers will not switch off unless I shut the ignition off?
I have a 98 520i auto with 133k on the clock and love everything about it except maybe the fuel consumption (Petrol) I get 35 on a good long run but only 26 at other times.
The only way I can stop them is to pull number 1 fuse but this is obviously a real pain.
I have scoured the forum but so far been unable to find a thread dealing with this particular fault.
Hope someone can help me.
Biggles
Old 11-27-2012, 09:23 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
It's possible that the park switch in the wiper gearbox is dirty or broken.
Old 11-27-2012, 09:42 AM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
The wiring diagram is a little vague as to the actual operation. There is a relay in the electronics box on the right side of the engine compartment in the back (under the microfilter housing I think). I suppose that relay could be stuck. I'd start there.
My original thought was that it was a fail-safe type of thing with the general module turning on the wipers because it didn't see the input from the switch. That could certainly be the case. The description of the circuit doesn't confirm that's the scheme of operation though.
Here's the wiring diagram I'm using. I don't know all the specifics of your car, but I'm assuming it's a right hand drive.
http://www.bmw-planet.com/diagrams/r...9old/index.htm
Old 11-28-2012, 02:02 AM
Biggles
Mein Auto: 520i
Thanks for your response guys.
However, (vavet5308) I cannot get the wiring diagram to open in the 'search' window. I think it may not work on a Mac?
Cheers,
John
Old 11-28-2012, 03:08 AM
NADAVAN
Cheers,
John
It might not be compatible with Mac. I find it works better in Internet Explorer than in Firefox. Try a different browser if you have one.
can't switch off, wipers
